Author Topic: [Testing] Manjaro Budgie 16.01 with budgie V10.2.2  (Read 15605 times)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« on: 04. January 2016, 11:25:40 »
Hi all , the manjaro community is proud to announce the first test release for budgie desktop
clean
  • Removed plank dock bar
    replaced smplayer with lollypop
    arc-theme active and full dark theming enable
    firefox/thunderbird
    manjaro printing setting and much more
    this release is based on our testing branch
Budgie-wm not provide a hot corner exposè effect now , it is implemented soon i think but not sure ... i have recompilated brightside and soon i upload in aur repository (in this iso not installed but you see in preview image) so a question :
do you like skippyxd with brightside or ........
Unfortunally my speed connection is not more fast , iso is in upload , when finish i add the link  ;)
Download : Manjaro BudgieDE Testing
Greetings
Stefano
« Last Edit: 05. January 2016, 10:52:52 by Ste74 »
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline robbi3
  • Jr. Mitglied
  • Branch: stable/unstable
  • Desktop: Manjaro KDE 16.06/pre3 /XFCE/pre3
  • GPU Card: Intel
  • GPU driver: Free
  • Kernel: Linux 4.4-x64
  • Skill: Intermediate
Re: [Testing] Manjaro Budgie 16.01 with budgie V10.2.2
« Reply #1 on: 04. January 2016, 14:43:55 »
I don't see a network / wifi icon on your screenshots, is that still a problem on budgie?
¨ If you can not do great things, do small things in a great way.¨
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #2 on: 04. January 2016, 16:54:04 »
Shouldn't be. It was fixed upstream and now appears--albeit sometimes randomly. Budgie is good enough to use as a fulltime DE/WM at this point (which I am doing in vanilla Arch). You can expect the Raven control center notification, clock, etc. panel icons to re-arrange themselves to their own liking on re-boot, however. What the heck--gives it character. ;)
Budgie is just too cool. And half the calories of GNOME (or Deepin)! :D
P.S. Ikey & Co. are really busy polishing Budgie. Since I installed, it's gone from vers. 10.1 to 10.2.2-2 in just a very few days. According to the 'chatter' Budgie will soon be in Arch main repos, rather than the AUR.
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #3 on: 04. January 2016, 16:55:23 »
That is soooo pretty, Stefano!
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #4 on: 04. January 2016, 18:05:41 »
Thank's man  :) :) :)
Canale IRC italiano
#manjaro-it
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #5 on: 04. January 2016, 18:12:00 »
I cannot withstand to test it, too. ;)
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #6 on: 04. January 2016, 18:21:41 »
Twiddles fingers, waiting for it to magically appear @ SourceForge... ;)
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #7 on: 04. January 2016, 18:26:58 »
not only .. even a faster connection to upload, even five hours more or less ufffffffff  ::) :P
Canale IRC italiano
#manjaro-it
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #8 on: 04. January 2016, 18:30:21 »
A bit off-topic here: Is it possible to get a right-click menu like in Openbox on Budgie?
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #9 on: 04. January 2016, 18:37:43 »
do you mean like this ?
https://github.com/solus-project/budgie-desktop/issues/253
Canale IRC italiano
#manjaro-it
Offline robbi3
  • Jr. Mitglied
  • GPU Card: Intel
  • GPU driver: Free
« Reply #10 on: 04. January 2016, 18:38:37 »
When I tried solus, I had same problem with missing network icon, installed evopop icons and the problem was gone.
I like the Budgie desktop, but not on solus, prefer a Manjaro based budgie.
Thanks Ste74 for all your good work. Waiting for your upload is finished.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #11 on: 04. January 2016, 18:43:05 »
No, I mean right-click on the desktop and you get an applications menu, like it is possible in Xfce, too. You get there one entry Applications which you can enable, this entry containts the applications menu. Such a solution I would like even more than Openbox style.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #12 on: 04. January 2016, 19:10:55 »
Ah , context menu i suppose .. not sure if implemented in gnome 3.18
Canale IRC italiano
#manjaro-it
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #13 on: 04. January 2016, 21:23:48 »
You (so far) get the same right-click menus as you would get in any GNOME 3.18 desktop. "New  Folder, New Document, Paste, Select All, blah blah.
Try adding Openbox as the WM?
Offline diVinae
  • Neuling
  • Branch: testing
  • Desktop: Xfce
  • GPU Card: intel/nvidia(optimus)
  • GPU driver: non-free
  • Kernel: linux44-x64
« Reply #14 on: 05. January 2016, 17:55:56 »
I cant login into x session
lightDM show "something goes wrong"
