Author Topic: Manjaro-Fluxbox 15.12  (Read 12866 times)
Offline Rocky-IV
  • Jr. Mitglied
  • Life is Good on Manjaro
  • Branch: Unstable
  • Desktop: Cinnamon, Fluxbox, Enlightenment
  • GPU Card: i7-4790S / ATI Radeon R7
  • GPU driver: Free
  • Kernel: 4.6RC-x64
  • Skill: Intermediate
Re: Manjaro-Fluxbox 15.12
« Reply #15 on: 07. January 2016, 15:41:15 »
  @eugen-b
Thanks for that article link on EXT4 to Btrfs < > much easier to just say Butter than these acronyms.
Sure hope Btrfs & OpenRC support reaches more Linux mainstream distributions this year >> at least in GUI installers.
I experiment distro hopping a lot but Manjaro "Rocks" my World.
             |"I'm under an NDA and cannot discuss Microsoft Windows" |
Greetings
Offline Losgann
  • Neuling
  • Branch: Stable
  • Desktop: XFCE, Fluxbox
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.1.15-1-MANJARO
« Reply #16 on: 07. January 2016, 17:02:53 »
Oberon, thanks for the reply. You are right, the default styles in /usr/share/fluxbox/styles are pretty ugh. Your manjaro-flux is by far the best of the bunch. I may just have to start learning how to create Fluxbox styles myself! So thanks for that link. ;)
Offline simgin
  • Held Mitglied
  • Branch: All.
  • Desktop: XFCE+Alpine Linux, Mate+Fedora, Ubuntu Server + Mate and NoX+LinuxBBQ
  • GPU Card: GeForce 8600M & GT 555M 2GB
« Reply #17 on: 08. January 2016, 15:50:54 »
Hey guys I have been reading up on Plank https://answers.launchpad.net/plank
Some odd bugs appear, especially so called 'dead zones', where windows and Plank clash ie. transparency etc.
There seems to be no solution for it, and they are pretty certain that it is a Fluxbox issue.
Maybe use Docky instead?
cheerio
simgin
PS: sorry to be a party pooper  ;D
Offline Rocky-IV
  • Jr. Mitglied
  • Branch: Unstable
  • GPU driver: Free
  • Kernel: 4.6RC-x64
« Reply #18 on: 08. January 2016, 19:49:21 »
             Hello simgin
       I'm baffled why no one uses Cairo-Dock nor recommends it.
I've used Cairo-Dock myself and find it has outstanding features compared to any other Dock.
https://wiki.archlinux.org/index.php/Cairo-Dock
Greetings
Offline dr-kart
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: Openbox LXQt
  • Kernel: 4.4
  • Skill: Novice
« Reply #19 on: 09. January 2016, 07:52:56 »
Laptop with radeon mobility x700.  i686 only.
systemd spin fills screen in red color after first reboot, right after install
openrc starts ok. But fails to add  Canon MP280 device. App can't find proper driver. Fixed after installing gutenprint.
Question: How to make autologin after suspend command with no password entering? What is that weird app started upon waking up?
« Last Edit: 09. January 2016, 09:54:08 by dr-kart »
Desktop Lxqt systemD x64 nvidia 650 xonar DS
Desktop Lxqt systemD x64 nvidia 520
Laptop openbox openrc x32 radeon x700
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #20 on: 09. January 2016, 11:56:10 »
Hi, dr-kart!
About the red sceeen thing, I have no idea - never heard of anything like that ??? Is the checksum of the ISO ok?
"weird app" ... Do you mean the blurred screen with the coloured circle? That's i3lock with blurlock.
Some things can be changed, others can't I'm afraid.
The latest version of oblogout locks the session automatically before suspend, so you'd have to use a shortcut for suspend only.
Code: [Select]
fluxboxexit suspendshould work for a command.
If you would like to use i3lock just with a blank screen and the circle (without the blurred screen image) you will have to invoke
Code: [Select]
oblogoutinstead of
Code: [Select]
oblogout_blurwhich the .desktop file in /usr/share/applications/oblogout.desktop does now for you if you use the dock entry.
To change that you can either create a keyboard shortcut, or edit the menu, or edit the .desktop file... ;)
« Last Edit: 09. January 2016, 11:58:32 by oberon »
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline dr-kart
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #21 on: 09. January 2016, 15:48:43 »
Hi, oberon
Thanks for reply.
Now I can see that I'm facing with manjaro-oblogout, but not the original oblogout.
And as I said, I neither need nor like its (manjaro's) dependency of i3lock app.  Since I have to enter password each time my system awakens after suspend.  IMHO.
Secondly, plank's icons configuration drives me wild (c).
Offline manjone
  • Jr. Mitglied
  • Skill: Novice
« Reply #22 on: 12. January 2016, 13:44:56 »
why releasing if the dock is broken!?
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #23 on: 12. January 2016, 14:35:21 »
It's not broken. There is just a better solution that we have discovered since.
If you are not satisfied with the way plank and fluxbox interact and if you want to use docky before the next release:
Remove plank, install docky and configure it yourself!
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #24 on: 12. January 2016, 14:39:31 »
As I was trying to say: It's oblogout that locks the session before suspend. i3lock is just my choice of a lock-command.
You can simply replace oblogout-manjaro with oblogout. Just make sure you remove /etc/oblogout.conf first!
Offline dr-kart
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #25 on: 12. January 2016, 16:41:53 »
oh, yeah... got it. Actually that is what I have done right after I discovered oblogout-manjaro app. But (legacy) oblogout was not functioning that time. Maybe due to not having /etc/oblogout.conf removed first. So probably I'll try another time. Now I feel confused about old (since openbox 0.13) not yet solved memory loop issue, and xarchiver rar issue
https://forum.manjaro.org/index.php?topic=29127.msg249086#msg249086
https://forum.manjaro.org/index.php?topic=26748.msg248758#msg248758
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #26 on: 12. January 2016, 17:10:08 »
If you want to use oblogout from the dock you will have to create a new .desktop file like /usr/share/applications/oblogout_blur.desktop but without the trailing "_blur". You can use the existing one but you'll have rename it and edit it with a texteditor and remove all the "_blur"s there ;)
The menu is (for whatever reason ::) set to call oblogout already instead of oblogout_blur. So that should work right away.
Offline simgin
  • Held Mitglied
  • Branch: All.
« Reply #27 on: 12. January 2016, 17:19:47 »
Please respect Oberons work, don't like it, don't use it!
It is not like you have paid for it, but he has by using his spare time.
cheerio
Simgin
PS. Sorry for the rant, but it needs to be said.  C:-)
Offline dr-kart
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #28 on: 12. January 2016, 17:25:17 »
For you especially, I wrote InMyHumbleOpinion. And that's it. C:-)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #29 on: 12. January 2016, 18:06:55 »
@simgin: Well, I don't see any disrespect from dr-kart, IMHO.
@dr-kart, adding IMHO doesn't make much sense, you are writing that you don't need s.th., you are not writing that Oberon should remove it.
@manjone, I think you should have better described your issue instead of asking a rhetorical question.
Sorry, for interfering. At least we are all obviously interested enough in Oberon's Fluxbox release to write s.th. here.
« Last Edit: 12. January 2016, 18:08:56 by eugen-b »
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
