Author Topic: 'budgie-desktop' package is missing 'gnome-session' as dep  (Read 1432 times)
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« on: 30. December 2015, 17:24:42 »
I installed (on unstable):
Code: [Select]
community/budgie-desktop 10.1-1 [installed]
    Simple GTK3 desktop experience
This brought in a selection of dependencies, but on trying to select the session from LightDM login aborts with the following in .xsession-errors:
Quote
/usr/bin/budgie-desktop: line 2: exec: gnome-session: not found
Installing 'gnome-session' now, will edit in a mo.
Edit:
gnome-desktop'gnome-session' does get it working, though that's added a non-working GNOME session to LightDM. :D
Reference deps from AUR package:
Code: [Select]
depends=('libwnck3' 'gnome-menus' 'gnome-settings-daemon' 'libpeas'
         'mutter>=3.18' 'desktop-file-utils' 'libgee' 'gnome-themes-standard'
         'gtk3>=3.18' 'libpulse' 'upower' 'intltool' 'gnome-session>=3.18'
         'gnome-terminal' 'gnome-control-center' 'nautilus')
[later edit: correct gnome-desktop to gnome-session]
« Last Edit: 31. December 2015, 02:38:34 by jonathon »
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
Re: 'budgie-desktop' package is missing 'gnome-session' as dep
« Reply #1 on: 30. December 2015, 17:41:08 »
Hi jonathon .. yes , i switched on gdm .. in aur the pkg is updated yesterday ..
https://aur.archlinux.org/packages/budgie-desktop/
https://github.com/manjaro/manjaro-tools/issues/169
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #2 on: 30. December 2015, 17:42:58 »
maybe .. i posted when you have re posted  :P
Canale IRC italiano
#manjaro-it
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #3 on: 30. December 2015, 17:43:47 »
Yes. :D
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #4 on: 30. December 2015, 17:47:23 »
Add notice .. startx not work have to put in .xinitrc
Code: [Select]
exec budgie-desktop
 :P
Canale IRC italiano
#manjaro-it
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #5 on: 30. December 2015, 20:51:49 »
You're going to also find that some permissions aren't handled correctly. For instance, gnome-disk-utility can only be changed as root if started as root. I also notice nautilus-admin from AUR has no effect, and lxsession-gtk3 (which was necessary in 8.3.1) seems to have no impact.
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #6 on: 30. December 2015, 21:26:22 »
@c00ter
see issue on github
https://github.com/solus-project/budgie-desktop/issues
i think more feature is lost  :P
Canale IRC italiano
#manjaro-it
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #7 on: 30. December 2015, 22:51:15 »
@c00ter
see issue on github
Yep. This is what "in development" means. :P
Meanwhile @oberon etal are kicking butt on Deepin. (I'm using it as sole DE in Arch at the moment.). Budgie will get there soon, I'm sure.
Keep up the good work, Stefano. :D
Ken
