Author Topic: Can't get lightdm to start in Manjaro Net... :/  (Read 1683 times)
Offline AtheistSpacePirate
  • Neuling
  • I'm new. Be nice!
  • Desktop: Xfce
  • Skill: Novice
« on: 30. December 2015, 16:51:39 »
Every time I try to start lightdm, I get this error msg:
Job for lightdm.service failed because the control process exited with error code. See "systemctl status lightdm.service" and "journalctl -xe" for details.
When I do what it says... I get this...
Code: [Select]
[fuckuimabird@laptop ~]$ systemctl status lightdm
● lightdm.service - Light Display Manager
   Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
   Active: failed (Result: start-limit) since Wed 2015-12-30 10:42:33 EST; 1min 36s ago
     Docs: man:lightdm(1)
  Process: 1436 ExecStart=/usr/bin/lightdm (code=exited, status=1/FAILURE)
 Main PID: 1436 (code=exited, status=1/FAILURE)
Is there something I can do to fix this?
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
Re: Can't get lightdm to start in Manjaro Net... :/
« Reply #1 on: 30. December 2015, 17:24:14 »
There's a couple things. Since you don't give any details...
1. Did you enable lightdm in systemd?
2. Did you try reinstalling lightdm?
More details = more detailed help.
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
  • Neuling
  • I'm new. Be nice!
  • Desktop: Xfce
  • Skill: Novice
« Reply #2 on: 30. December 2015, 17:29:47 »
Yes, I enabled lightdm via
Code: [Select]
sudo systemctl enable lightdm
  • Neuling
  • I'm new. Be nice!
  • Desktop: Xfce
  • Skill: Novice
« Reply #3 on: 30. December 2015, 17:32:21 »
And I just reinstalled lightdm... still didn't work.
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
« Reply #4 on: 30. December 2015, 17:41:32 »
Didn't try NET edition yet, what is the session LightDM is supposed to start?
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
  • Neuling
  • I'm new. Be nice!
  • Desktop: Xfce
  • Skill: Novice
« Reply #5 on: 30. December 2015, 18:27:37 »
I figured it out...
https://wiki.archlinux.org/index.php/LightDM#Enabling_LightDM
I ran
Code: [Select]
lightdm --test-mode --debug
and was told that lightdm-gtk-greeter wasn't found. I ran
Code: [Select]
sudo pacman -S lightdm-gtk-greeter
and now lightdm has started... :)
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #6 on: 30. December 2015, 20:46:58 »
I figured it out...
I ran
Code: [Select]
Code: [Select]
I should have known--sorry 'bout that, I always install the set--lightdm, lightdm-gtk-greeter, and lightdm-gtk-greeter-settings. Never thought about a missing piece. ;)
