Author Topic: Small issue with systemd-jounrald during shutdown  (Read 1456 times)
Offline hammy_283
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Openbox
  • GPU Card: Integrated Intel® HD Graphics
  • GPU driver: Non-free
  • Kernel: 4.3.3-2-MANJARO x86_64
  • Skill: Intermediate
« on: 28. December 2015, 11:36:16 »
So, during shutdown on my netbook which is running kernel 4.3.3, x86_64, and fluxbox, during shutdown the verbose shows a small issue. "Systemd-Journald [154]: Failed to send stream file descriptor to service manager: connection refused", other lines at the end show up as "Transport end point not connected". It doesn't effect the shutdown, I just want to know why it is appearing and how to fix it. The image below show what comes up during shutdown.
Any help or info would be great, thank you.
“They’ve done studies, you know. 60 percent of the time, it works every time.”
— Brian Fantana (Anchorman)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
Re: Small issue with systemd-jounrald during shutdown
« Reply #1 on: 28. December 2015, 11:59:30 »
Did it happen several times? Did it happen with different kernels?
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline hammy_283
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Openbox
« Reply #2 on: 28. December 2015, 23:25:00 »
Hi eugen-b,
It happens everytime I shutdown. I haven't used any other kernels.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #3 on: 28. December 2015, 23:30:15 »
I would try other kernels.
Offline hammy_283
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Openbox
« Reply #4 on: 28. December 2015, 23:37:33 »
Ok, i will.
Offline hammy_283
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Openbox
« Reply #5 on: 28. December 2015, 23:47:03 »
Installed 4.2.8.1 kernel and I don't have the same issue. Who should I report this issue to?
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #6 on: 28. December 2015, 23:54:41 »
Good! :D But I mean to remember that the 4.2.8 kernel is the last of the series and will soon reach end of life. How about 4.1 kernel?
Report? I would report if it was an RC kernel or an LTS. Then to Philm or if you want on kernel.org
« Last Edit: 28. December 2015, 23:58:20 by eugen-b »
Offline hammy_283
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Openbox
« Reply #7 on: 29. December 2015, 02:59:48 »
So, I shutdown my netbook a few minutes ago and the same issue came up. So, I will try a fresh install and go from there.
