Author Topic: manjaro available at www.citycloud.eu  (Read 1241 times)
Offline gustav3d
  • Neuling
« on: 20. March 2013, 17:04:56 »
manjaro 0.8.4 net is upon my request now available  at  https://www.citycloud.eu/   , located in sweden.
their storage is raid5+1, according to their support staff.
its not a pre installed image.
When adding a new VM you have to choose "install my own" and then select manjaro.
connect with VNC to install.
you can enable VIRTIO, VIRTBLK at the VM advanced config tab for better performance.
then ssh as usual :)
Offline ultima
  • Held Mitglied
Re: manjaro available at www.citycloud.eu
« Reply #1 on: 27. March 2013, 23:10:45 »
Keep up the great work there gustav3d .
