Author Topic: Fluxbox menu with icons & tint2 instead of the taskbar  (Read 6483 times)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
« on: 19. December 2015, 22:12:53 »
Hello,
I want to costomize my Fluxbox install.
1) I would like to have icons in the menu, but I oly get a few of them if I launch fbmenugen -i. Should I simply change the icon theme?
2) I would like to have the tint2 panel instead of the native taskbar. How can I make the taskbar disappear?
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline wordler
  • Vollwertiges Mitglied
  • I can wire a plug
  • Branch: Stable
  • Desktop: Fluxbox & Xfce
  • GPU Card: Nvidia GT720 1gb ddr5
  • GPU driver: non-free
  • Kernel: linux4.4-x64
  • Skill: Novice
Re: Fluxbox menu with icons & tint2 instead of the taskbar
« Reply #1 on: 19. December 2015, 23:06:46 »
There is a wiki for tint2. I think the info you need is on the "install" page:
https://gitlab.com/o9000/tint2/wikis/home
have fun!  :)
Fear is the mind killer.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #2 on: 19. December 2015, 23:11:12 »
have fun!  :)
Thanks, wordler! But I have more of an issue with getting rid of the Fluxbox taskbar which I won't need if I have tint2.
Offline wordler
  • I can wire a plug
  • Branch: Stable
  • Skill: Novice
« Reply #3 on: 19. December 2015, 23:17:27 »
There is a section on the "install" page which gives instructions for removing the Fluxbox taskbar.
I haven't tried it myself but I may give it a go when I get some free time.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #4 on: 19. December 2015, 23:19:38 »
Ok, didn't find it at once:
https://gitlab.com/o9000/tint2/wikis/Install
Quote
Autorun tint2 in Fluxbox
    Remove the fluxbox panel and systray from the file ~/.fluxbox/init.
    Remove systemtray from the list of items on the line session.screen0.toolbar.tools.
    On the line session.screen0.toolbar.visible: true change true to false.
    Add in ~/.fluxbox/startup: (sleep 2s && tint2) & Restart Fluxbox.
Then thank you even more!
« Last Edit: 19. December 2015, 23:21:51 by eugen-b »
Offline wordler
  • I can wire a plug
  • Branch: Stable
  • Skill: Novice
« Reply #5 on: 19. December 2015, 23:21:30 »
You're welcome!
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #6 on: 20. December 2015, 14:03:25 »
Update: Issue 2) is [SOLVED], I have tint2 now and Fluxbox panel is invisible.
However I cannot create a Fluxbox menu with icons.
From config.pl
Code: [Select]
our $CONFIG = {
  "editor"              => "mousepad",
  "Linux::DesktopFiles" => {
                             desktop_files_paths     => ["/usr/share/applications"],
                             gtk_rc_filename         => "/home/eugen/.gtkrc-2.0",
                             icon_dirs_first         => "/usr/share/icons/Dalisha",
                             icon_dirs_last          => "/usr/share/icons/hicolor",
                             icon_dirs_second        => "/usr/share/icons/gnome",
                             keep_unknown_categories => 1,
                             skip_entry              => [
                                                            key => "Name",
                                                            re  => qr/(?:Install|Oblogout|Wallpaper Changer|Manage Printing|Notifications|Bluetooth Adapters|File Manager|Customize Look and Feel|Preferred Applications)/i,
                                                          { key => "Exec", re => qr/^clipit|lightdm-gtk-greeter-settings/ },
                             skip_filename_re        => qr/^(?:xfce4-about|compton|manjaro-settings-manager-gtk|pcmanfm|oblogout|plank|gnome-terminal|fb-restore-menu)\b/,
                             skip_svg_icons          => 1,
                             strict_icon_dirs        => true,
                             substitutions           => [
                                                          { key => "Name", re => qr/Time Settings/, value => "Time & Date" },
                             terminalization_format  => "%s -e '%s'",
                             terminalize             => 1,
                             unknown_category_key    => "other",
  "menu_title"          => "Fluxbox Menu",
  "missing_icon"        => "gtk-missing-image",
  "name_keys"           => ["Name"],
  "terminal"            => "lxterminal",
  "VERSION"             => 0.76,
I issued following commands
Code: [Select]
/usr/bin/fbmenugen -u
/usr/bin/fbmenugen -d
/usr/bin/fbmenugen -i
I still don't have icons in my menu.
I checked fluxbox -i and it shows that it supports PNG icons.
I tried with gnome and hicolor, no difference. The ~/.fluxbox/menu file simply has <> everywhere instead of the paths to icons.
I installed fbmenu-manjaro, was this a mistake?
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #7 on: 20. December 2015, 15:30:28 »
This is as good as it gets so far, edited the ~/.fluxbox/menu file manually.
I'm also going to customize the window theme to look like Numix.
Offline wordler
  • I can wire a plug
  • Branch: Stable
  • Skill: Novice
« Reply #8 on: 20. December 2015, 16:09:09 »
@eugen-b:
I found this old article with a link to a menu editor in sourceforge and some old instructions. Might be worth investigating further... ;)
http://www.freesoftwaremagazine.com/articles/powering_fluxbox_menus_fluxbox_editor
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #9 on: 20. December 2015, 16:12:40 »
Yeah, there are many tools for genarating a Fluxbox menu, but I wanted to get the one which is preinstalled to work... Or to prove that it has a bug. However the issue isn't very urgent anymore. Will take time to analyse fbmenugen later and hope that s.o. can help with it.
« Last Edit: 20. December 2015, 16:15:26 by eugen-b »
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #10 on: 23. December 2015, 11:36:10 »
Does anybody know an icon theme which has many 32x32 sized PNG icons? No Faenza, Gnome, Elementary, Tango and similar 10 year old themes.
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #11 on: 23. December 2015, 12:56:16 »
How about just using any theme - even .svg and simply converting a higher resolution to what you need? You can use imagemagick for that very well.
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #12 on: 23. December 2015, 13:20:53 »
A good idea! Do you happen to know the command for converting icons with imagemagick? I would try to run it in a loop then.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #13 on: 25. December 2015, 00:45:08 »
I found an icon theme which works with Fluxbox - nouveGnomeGray.
I needed to change /usr/share/fluxbox/styles/manjaro-flux/theme.cfg
menu.titleHeight:            33
menu.itemHeight:            33
to get enough space for 32x32 icons.
Then ran
Code: [Select]
fbmenugen -d
fbmenugen -i
and reloaded Fluxbox config.
Then I opended the ~/.fluxbox/menu file and replaced all 24x24 with 32x32.
Finally I have non-corrupted icons in the Fluxbox menu:
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #14 on: 25. December 2015, 06:51:10 »
That looka great!  :D
