Author Topic: [Capella] Manjaro 15.12-rc2 released  (Read 2211 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« on: 18. December 2015, 14:27:25 »
After another good week of development we are happy to present to you Manjaro 15.12-rc2. This release comes with XFCE 4.12, KDE Plasma 5.5.1, 4.1.0 LTS kernel and all the usual Manjaro and upstream updates. We worked mostly on our tools and the graphical installers.
Noteable changes in our tools:
  • kcm module of Manjaro-Settings got reworked
  • several enhancements to Pamac and Octopi
  • optimizations and fixes to Manjaro-Tools
  • a lvm issue was fixed within Thus
Stable branch was used to create these install medias. Please give us feedback and report any issues with this release.
kind regards
Philip Müller, Manjaro Development Team
Download: Manjaro 15.12-rc2
« Last Edit: 18. December 2015, 14:31:25 by philm »
Offline jordan
  • Vollwertiges Mitglied
  • Skill: Advanced
Re: [Capella] Manjaro 15.12-rc2 released
« Reply #1 on: 19. December 2015, 10:32:22 »
Hi!
Xfce:
Live USB tests on 2 notebooks.
1. My notebook: no problem
2. Friends notebook:
Ubuntu 15.10
Bios emulated, Intel Core i5
Card-1: Intel 4th Gen Core Processor Integrated Graphics Controller
Card-2: NVIDIA GM107M [GeForce GTX 860M]
Display Server: X.Org 1.17.2 driver: nvidia Resolution: 1920x1080 at 60.01hz
GLX Renderer: GeForce GTX 860M/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 352.63
2.1 default settings: error messages
Code: [Select]
...nouveau...
...drm_kms_helper: panic occurred... not syncing...Attempting to kill init...
2.2 non-free drivers + NO KMS + nomodeset -> okay.
Jordan @ Linux multi boot
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #2 on: 19. December 2015, 15:09:55 »
Doesn't work on my new PC (UEFI), nor with thus or calamares.
1) the 1st choice of the 1st menu doesn't work, it stops before the desktop
2) the grub is not installed. With thus, i can't select /dev/sda2 as /boot/efi, and with calamares,at the end, grub is bad installed.
It can be due to the last windows 10 update ?
I stay under W10 for the moment.  :(
« Last Edit: 19. December 2015, 15:12:38 by Esclapion »
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #3 on: 19. December 2015, 16:30:00 »
@Esclapion: yes, UEFI is still a problem ...
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Branch: stable, unstable
  • Desktop: Xfce
  • GPU Card: GTX780/HD3000/AMD8400
  • GPU driver: Nvidia/Intel/Catalyst
  • Kernel: latest stable+lts (64)
  • Skill: Advanced
« Reply #4 on: 19. December 2015, 20:26:18 »
Toshiba Satellite M50D-A-10Z (AMD A6 CPU, integrated GPU) - live environment works with default, not with non-free drivers (may be an older issue, can't remember). Installed system is fine (except for the occasionally buggy trackpad general Linux issue)
Please note that the Xfce Whisker Menu icon isn't working. The typo has been fixed in Git for the final release, however.
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #5 on: 19. December 2015, 21:00:10 »
Can you please check fstab on the installed system, the /boot/efi mount comes after /boot mount if installed with calameres?
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • Kernel: linux46 - x64
  • Skill: Intermediate
« Reply #6 on: 20. December 2015, 19:39:03 »
@artoo, this means you assume escapion have both /boot and /boot/efi partitions and mount points?
And if /boot is also in vfat (fat32) format, won't bootctl (systemd boot) take precedence over grub?
This is intriguing, and hope you can confirm your findings. Thanks.
ps: I've done /boot (no /boot/efi) in fat32 and bootctl implements (without loader.conf or <os>.conf .... so won't boot straitaway without manually adding conf files)
Have not done both /boot (in any format) and /boot/efi (at installation).
And after installation, I can install grub2 (by mounting an esp partition as /boot/efi) and have both bootctl and grub2 for the same OS.
« Last Edit: 20. December 2015, 19:44:44 by gohlip »
Life is a sexually transmitted disease with a 100% mortality rate.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #7 on: 21. December 2015, 12:51:44 »
As with the given Calamares installer you need to do a special partitioning to get it working.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #8 on: 21. December 2015, 13:05:14 »
Also in net installs. But always best to have partitioning ready before installation, whatever installer is used.
Offline Chazy Chaz
  • Jr. Mitglied
  • I'm new. Be nice! :P
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: AMD R9 290
  • GPU driver: Free
  • Kernel: Linux44-x64
« Reply #9 on: 23. December 2015, 17:40:52 »
Will Calamares support proper automatic setup of SSD? Or is it still necessary to manually partition it?
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #10 on: 23. December 2015, 20:46:47 »
Some day it will support it. Until now, not. But we are working on it ...
Offline Dgekins
  • Neuling
  • I'm new. Be nice!
  • Desktop: Manjaro Cinnamon 15.09-1-x86_64
  • GPU driver:
  • Skill: Novice
« Reply #11 on: 29. December 2015, 15:48:34 »
Help from Synaptic not put an application writes can not be inserted due to an unexpected error that package.
