Author Topic: How do I fix Manjaro error hibernation device not found on boot?  (Read 10025 times)
0 Members and 2 Guests are viewing this topic.
Offline noah
  • Neuling
  • I used ubuntu for a while but new to manjaro
  • Branch: testing
  • Desktop: gnome,kde,and more
  • GPU Card: gtx 970
  • GPU driver: non-free
  • Skill: Novice
After installing updates and restarting I got these errors.
ERROR: resume: hibernation device 'UUID=long number here' not found
ERROR: device '/dev/mapper/ManjaroVG-ManjaroRoot' not found. Skipping fsck.
ERROR: Unable to find root device '/dev/mapper/ManjaroVG-ManjaroRoot'.
Then I am dropped to recovery shell with the message SH: can't access tty: job control turned off.
This is a less than a week old install I checked lvm and luks encryption on the graphical installer.
Offline noah
  • Neuling
  • Branch: testing
  • GPU Card: gtx 970
  • Skill: Novice
Re: How do I fix Manjaro error hibernation device not found on boot?
« Reply #1 on: 17. December 2015, 08:03:53 »
there has been a glitch it created 3 of the same post please delete the extras
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #2 on: 17. December 2015, 14:54:10 »
Boot from the live-media and issue followed cmd in a terminal:
Code: [Select]
sudo blkid
You should get, for example for your hibernation drive, this:
Code: [Select]
/dev/sda2: LABEL="swap" UUID="6dd17673-7ddb-4fd5-9c83-e3ef0116a872" TYPE="swap" PARTUUID="48afb528-02"
Check if you find that same UUID (for resume) in your /boot/grub/grub.cfg:
Code: [Select]
sudo cat /boot/grub/grub.cfg | grep -i resume
linux /boot/vmlinuz-4.1-x86_64 root=UUID=fcd883f2-5d60-4b71-9d17-1a24e210d2b6 rw  resume=UUID=6dd17673-7ddb-4fd5-9c83-e3ef0116a872 quiet splash
If not, change it to the correct one. You can use nano or any other editor to do that. It would be better to do this from the live-cd, though.
Offline noah
  • Neuling
  • Branch: testing
  • GPU Card: gtx 970
  • Skill: Novice
« Reply #3 on: 17. December 2015, 18:49:59 »
I ran sudo blkid I have two on sda. I have sda1 labeled ManjaroBoot and sda2 type crypto_LUKS.
sudo cat /boot/grub/grub.cfg | grep -i resume returns the cryptdevice=the correct uuid of sda2 and resume=a uuid I can't find and then quiet splash. The uuid of resume does not match any returned by sudo blkid. I am using the live usb that I installed manjaro from.
What should I do?
Offline noah
  • Neuling
  • Branch: testing
  • GPU Card: gtx 970
  • Skill: Novice
« Reply #4 on: 18. December 2015, 03:52:22 »
If someone could please help me out that would be great I have been using my Chromebook for 2 days now.
Offline anika200
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Gnome 3.20-x on PC, Antergos on laptop and another PC.
  • GPU Card: NVIDIA 750Ti, Intel Iris 5200, AMD
  • GPU driver: NV, AMD uses proprietary and the intel is free
  • Kernel: 4.4.8-1-MANJARO
  • Skill: Intermediate
« Reply #5 on: 20. December 2015, 04:07:57 »
Do you have a swap partition or file? Philm has already given the keys to the problem so I will not re-type all the commands.
1) Find out if you have a swap and its uuid
2) the uuid as reported from the "cat" command must match your swap partition.
if it does not then
3) Change the file /etc/default/grub to match your resume uuid (should be line 5 or so)
4) update grub with the command "sudo update-grub"
5) reboot
Hope this gets you going.
« Last Edit: 20. December 2015, 04:10:18 by anika200 »
Offline xinity
  • Neuling
  • I'm new. Be nice!
  • Desktop: i3wm
  • GPU Card: nvidia
« Reply #6 on: 18. January 2016, 14:22:05 »
hi here,
i just had the same behavior on my Dell XPS 15 (2016), right after upgrading my kernel to 4.4
i've checked UUID everything is fine.
i now can't boot from either kernel 4.1 or 4.4 :(
any clues ?
Offline anika200
  • Sr. Mitglied
  • Branch: stable
« Reply #7 on: 18. January 2016, 14:34:26 »
hi here,
any clues ?
This does not sound like it is related to the original thread subject. You are likely to get more help if you start a new topic with more detail about your exact problem.
