Author Topic: [menda] theme rebase, need help ...  (Read 7099 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« on: 16. December 2015, 13:25:42 »
Hi community,
seems it is time to rebase our Menda theme once more. Gtk 3.18 introduced some defects into the current one. I already started to fork the new Arc-Theme. Now we have to recolour it ...
Any experts here with inkscape and gtk theming? Source can been found here: https://github.com/manjaro/artwork-menda/tree/devel
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
Re: [menda] theme rebase, need help ...
« Reply #1 on: 16. December 2015, 13:52:10 »
Most of the work would be to replace the cyan-based colours with some more in the direction of magenta. Arc-Theme is using assets, so a simply SVG file needs to been ediited and after that you execute a bash-script to render your new assets. Some CSS files need new colour IDs plus some PNGs some love. The theme supports Normal, Dark and Darker as variants. Still didn't figured out how to change the colour scheme with inkscape. Maybe I'm missing some plugin or libriary as the options simply don't work ...
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #2 on: 16. December 2015, 14:06:48 »
You can either fork the git repository of Menda or ask me to get added to our Artwork-Team to work directly on the source.
Offline MadmanRB
  • Sr. Mitglied
  • Always thinking, always crazy
  • Branch: Stable
  • Desktop: Cinnamon 2.8.5
  • GPU Card: Intel HD Graphics 4600
  • GPU driver: Free and proprietary, depending on need
  • Kernel: 4.1.13
  • Skill: Intermediate
« Reply #3 on: 16. December 2015, 14:13:15 »
Typical of GTK3, if its fixed break it again
Insanity is only a state of mind
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #4 on: 16. December 2015, 15:17:32 »
Yep, but what to do ...
Offline MadmanRB
  • Sr. Mitglied
  • Branch: Stable
  • Kernel: 4.1.13
« Reply #5 on: 16. December 2015, 17:40:21 »
Well you could try to get GTK 3.18.2-1 which apparently fixes most issues
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #6 on: 16. December 2015, 20:46:57 »
Well, it is more about the theme. It was designed for gtk 3.14 and updated to work with gtk 3.16. Newer themes are working fine with 3.18. It is simply that gtk changes over time and you have to adopt these. Either you find a theme which fits your vision or you find one but it doesn't fit your colours. Simply like that ...
Offline MrOats
  • Neuling
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU driver: free
  • Kernel: 4.4.6-1-x64
« Reply #7 on: 16. December 2015, 21:06:19 »
How about Maia, is that an option?
Nvm, I see you use that already.
Offline rabideau
  • Sr. Mitglied
  • just another day older...
    • ManyRoads
  • Branch: stable... and usually up to date
  • Desktop: xfce 4.12
  • GPU Card: nVidia
  • Kernel: 4.4-MANJARO x86_64
« Reply #8 on: 16. December 2015, 22:05:19 »
Not that you are looking for options but I find Numix-OS works nice with XFCE... Moka icons.... and Menda-Dark Window borders
Pax vobiscum,
...mark
“Letting go gives us freedom, and freedom is the only condition for happiness. If, in our heart, we still cling to anything - anger, anxiety, or possessions - we cannot be free.”  ― Thích Nhất Hạnh
Offline lastrodamo
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #9 on: 16. December 2015, 22:59:01 »
Hello
I'm a GNU/Linux user and use manjaro since 3 month. it is a really nice distribution.
I'm a CG artist since 7 years and I work a lot on 3d with blender. Look at my artwork on http://www.3dminfographie.com
If you need some help I really want to help you.
cu
lastrodamo
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #10 on: 16. December 2015, 23:31:06 »
@lastrodamo: yes why not. Artwork doesn't please everybody the same way. Everybody has his own taste. There are lot themes out there in blue but not so much in green.With time I might even learn it ... So if you want to do artwork for Manjaro, you're more than welcome.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #11 on: 17. December 2015, 01:59:54 »
Seems I found a fix for the current issue. However, if somebody wants to adopt the new Arc-Theme into green, feel free ...
Offline Charles LaHaine
  • Neuling
  • Branch: stable
  • Desktop: Gnome
  • GPU Card: Intel 965GM
  • GPU driver: xf86-video-intel
  • Kernel: linux41-x64
« Reply #12 on: 18. December 2015, 10:08:11 »
Arc adapted to greenish style would be a great choice to base Menda on, I already use gtk-theme-arc-git from AUR on Gnome.
« Last Edit: 18. December 2015, 19:37:14 by Charles LaHaine »
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #13 on: 18. December 2015, 10:47:25 »
mayby check up :
from : https://aur.archlinux.org/packages/green-arc-gtk-theme-git/
issues are it did not renaming so arch theme already installed conflicts..
Also cinnamon theme is not fixed on that part... :)
« Last Edit: 18. December 2015, 10:49:23 by ringo »
Dutch go the dutch site :)
Offline MadmanRB
  • Sr. Mitglied
  • Branch: Stable
  • Kernel: 4.1.13
« Reply #14 on: 18. December 2015, 12:40:58 »
well if menda is fixed maybe ringos theme should be its own theme with its own name.
Something like Mountain or Millenium or something, keep it m themed though :D
