Author Topic: calamares not install grub  (Read 2617 times)
Offline franke
  • Neuling
  • Branch: stable/testing
  • Desktop: kde/cinnamon
  • GPU Card: nVidia gt610
  • GPU driver: non-free
  • Kernel: linux4.1
  • Skill: Novice
« on: 10. December 2015, 11:10:23 »
Calamares not install grub on the / partition on the second hard disk (hdb), bios.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: calamares not install grub
« Reply #1 on: 10. December 2015, 11:56:37 »
Well, did you point Calamares where to install grub or does it install grub not at all? Also which version did you use?
Offline franke
  • Neuling
  • Kernel: linux4.1
  • Skill: Novice
« Reply #2 on: 11. December 2015, 09:31:27 »
I plug in options "install the system partition /",  "installation of grub failed". i used  http://sourceforge.net/projects/manjarotest/files/15.12/kde-minimal/15.12-rc1/manjaro-kde-minimal-15.12-rc1-x86_64.iso. i have 2 hard disks ,and installation of grub is on the second (hdb). Sorry for english
Offline franke
  • Neuling
  • Kernel: linux4.1
  • Skill: Novice
« Reply #3 on: 11. December 2015, 09:34:31 »
.. the boot manager is on the first disk (hda), in the windows disk (paragon).
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #4 on: 11. December 2015, 10:07:49 »
hmm. Do you have the install log for me?
Offline franke
  • Neuling
  • Kernel: linux4.1
  • Skill: Novice
« Reply #5 on: 11. December 2015, 10:43:01 »
I try and let you know
Offline franke
  • Neuling
  • Kernel: linux4.1
  • Skill: Novice
« Reply #6 on: 11. December 2015, 11:45:24 »
Error by Boost.Python in operatio "bootloader"
<Class 'subprocess.CalledProcessError>
Command 'grub-install --target=i386-pc --recheck --force /dev/sdb1 return non-zero exit status 1
trace back:
File " /usr/lib/calamares/modules/bootloader/main.py", line 244, in run prepare_bootloader (fw-type)
File  " /usr/lib/calamares/modules/bootloader/main.py", line 232, in prepare_bootloader install_grub (efi_directory, fw_type)
File  " /usr/lib/calamares/modules/bootloader/main.py", line 191,in install_grub "--recheck", "--force",boot_loader ["installPath"]])
File "<string>", line 2, in <modules>.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #7 on: 11. December 2015, 13:25:48 »
Why didn't you install it to MBR as the first option suggests? Selecting system partition mostly fails ... Works just fine on my end.
Offline jordan
  • Vollwertiges Mitglied
  • Skill: Advanced
« Reply #8 on: 11. December 2015, 16:40:23 »
Jordan @ Linux multi boot
Offline franke
  • Neuling
  • Kernel: linux4.1
  • Skill: Novice
« Reply #9 on: 12. December 2015, 07:42:49 »
thank you very much , but the suggestion is too much for my skills . The option to install grub in a specific partition is critical , in my opinion , for every installer , because it avoids overwriting it every time you try a new distribution ( and maybe do damage ) . Thanks again anyway :D
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #10 on: 13. December 2015, 10:54:42 »
@franke: please open an issue for this and add as much information as possible. Exact version of calamares (pacman -Q | grep calamares), Installation log in debug mode (install with calamares from terminal with 'sudo calamares -d'), list of your partition scheme and full error message.
Offline franke
  • Neuling
  • Kernel: linux4.1
  • Skill: Novice
« Reply #11 on: 14. December 2015, 19:41:28 »
I can not register there to place the issue , so I put here all the information :
Calamares - dev - 1.80r1654
sDA windows
sdb1 installation in question ( failed )
sdb6 Manjaro
sdb3 PcLinux .
The installation log can send attached , so the full error message .
Bottom Line : This happens with xfs , with btrfs grub is installed , but is not seen by the primary boot manager ( paragon of hda )
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #12 on: 14. December 2015, 20:45:37 »
Hi franke, I created an issue (CAL-347) for you. Please keep track on it. What was the issue in registering?
Offline franke
  • Neuling
  • Kernel: linux4.1
  • Skill: Novice
« Reply #13 on: 15. December 2015, 06:45:42 »
if I try to register I get this page:
Your JIRA administrator has not yet configured this contact form.
Perhaps the only way is to register on GitHub and enter with that account.
I follow the issue and hope to help in some way. :)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #14 on: 15. December 2015, 14:29:30 »
Ah, right. Works currently only with github account as we use Jira just for the advanced bugtracker options and management.
