Author Topic: Octopi - a simple qt frontend for pacman  (Read 57959 times)
0 Members and 2 Guests are viewing this topic.
Offline viking60
  • Sr. Mitglied
    • bjoernvold.com
  • Branch: stable
  • Desktop: openbox
  • GPU Card: NVIDIA GT200b [GeForce GTX 275]
  • GPU driver: nonfree
  • Kernel: linux4.1-x86_64
  • Skill: Intermediate
Re: Octopi - a simple qt frontend for pacman
« Reply #225 on: 14. July 2014, 14:56:59 »
Octopi is my favorite pacman GUI - good job arnt.
Offline arnt
  • Core Team
« Reply #226 on: 07. November 2014, 14:12:35 »
Friends,
A new version of Octopi got released last tuesday: 0.5.0. Highlights are the new dialog for choosing terminals and the less intrusive notifier.
More info at:
http://octopiproject.wordpress.com/2014/11/04/maturing-and-getting-even-better-octopi-0-5/
Thank you for your tireless help!
Offline emogg
  • Jr. Mitglied
  • Branch: stable
  • Desktop: KDE
  • GPU Card: nvidia
  • GPU driver: non-free
  • Kernel: linux314-x64
« Reply #227 on: 14. November 2014, 23:17:04 »
Is there a way for octopi to retain the root password for an entire session? It seems to ask for it too often otherwise.
'Twas brillig, and the slithy toves / Did gyre and gimble in the wabe — Lewis Carroll
Offline arnt
  • Core Team
« Reply #228 on: 15. November 2014, 19:31:04 »
While in KDE you can run it as root.
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
« Reply #229 on: 15. November 2014, 20:05:44 »
No, not really, but this does sound like a good suggestion for arnt, I'm sure he could find a way.
Not really a good Idea and an even worse suggestion, my friend. :)
« Last Edit: 15. November 2014, 20:08:17 by AJSlye »
Offline arnt
  • Core Team
« Reply #230 on: 15. November 2014, 20:42:08 »
1) Believe me, I've tried. But kdesu and gksu were the only tools that worked as they retrieve all pacman command's output so Octopi can parse them;
2)It was just an idea. Let's not forget that Octopi is just a frontend to pacman, so it should not harm your system. Of course there could be security issues in Qt4/5 library that could be exposed while doing so.
But I don't see those authentication dialogs (kdesu/gksu) as bad things. I think the interaction with package managers is not very constant for the average user and if we are talking about a power one, changes are he is using "pacman" directly.
Offline emogg
  • Jr. Mitglied
  • Branch: stable
  • Desktop: KDE
  • GPU Card: nvidia
« Reply #231 on: 16. November 2014, 00:21:24 »
I haven't used pamac for quite some time, but I thought that it did retain the root password throughout a session. Anyway I'll try running Octopi via kdesu and see how that works.
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
« Reply #232 on: 16. November 2014, 03:50:35 »
I believe that pamac is using policykit for authentication, and that's how it keeps the administrator rights open for the entire session.
« Last Edit: 16. November 2014, 04:54:02 by AJSlye »
Offline arnt
  • Core Team
« Reply #233 on: 16. November 2014, 13:36:38 »
Indeed. Octopi Notifier also uses policykit.
But when I tried to use it for Octopi itself, it didn't retrieve the output for pacman commands. So I was left alone with my kdesu/gksu options.
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
« Reply #234 on: 16. November 2014, 15:43:52 »
Huh, well it's all good. I don't mind the extra steps anyway.
Offline miku
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Plasma 5
  • GPU Card: ATi 5750
  • GPU driver: free
  • Kernel: latest
« Reply #235 on: 10. February 2015, 12:28:42 »
I really like Octopi!
I need just one small thing to make me happy :)
If I click to one app, then its details are shown in the below box. If I do this with keyboard (like pushing up or down at keyboard choosing another app), then the result is empty screen it does not refresh the data. The bottom screen should be refreshed with the details if I push up or down at the keyboard.
Offline miku
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Plasma 5
  • GPU driver: free
  • Kernel: latest
« Reply #236 on: 04. March 2015, 11:02:04 »
As I can see it is working with v0.6 :)
Offline miku
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Plasma 5
  • GPU driver: free
  • Kernel: latest
« Reply #237 on: 10. March 2015, 13:37:21 »
Would it be beneficial if the user could always see the "Info" page? I am always using it and if it could be pinned it would be great always to see the date, dependencies etc.
I think there is enough space for the other 5 tabs in the middle/ right side, so there would be space for the "Pinned info" page.
If thef user selects more apps then this page would be empty(, or a list of the selected apps).
Offline maravic
  • Neuling
« Reply #238 on: 25. March 2015, 13:48:59 »
Hi, I have installed the last Manjaro-KDE pre5 with octopi 6.0. I'm not able to find yaourt group in octopi panel. Something was changed in this version? How can I enable AUR packages in octopi?
Offline conky57
  • Held Mitglied
  • Branch: testing
  • Desktop: KDE Plasma 5.8.4 (16.10 Fringilla) w/OpenRC
  • GPU Card: M92 Ati Mobility Radeon HD 4500 Series
  • GPU driver: free
  • Kernel: 3.18.32-1-MANJARO - x86_64
  • Skill: Novice
« Reply #239 on: 25. March 2015, 13:57:17 »
Yes, there has been a change in accessing yaourt. You now just click on the green alien face icon next to the search box, and that enables yaourt tool. You then can search yaourt as before.
Best regards.
Be kind to everyone, because everyone is fighting some sort of battle.
LinuxCounter registered user  #278931
