Author Topic: Terminal misbehavin  (Read 3181 times)
Offline hammy_283
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Openbox
  • GPU Card: Integrated Intel® HD Graphics
  • GPU driver: Non-free
  • Kernel: 4.3.3-2-MANJARO x86_64
  • Skill: Intermediate
Re: Terminal misbehavin
« Reply #30 on: 14. November 2015, 01:17:01 »
So, I also had the same problems with lxterminal and terminator would launch and mininize to a tiny box automatically. I then switched to qterminal and it seems to be working with no issues, so far.
“They’ve done studies, you know. 60 percent of the time, it works every time.”
— Brian Fantana (Anchorman)
Offline gychang
  • Vollwertiges Mitglied
  • Skill: Novice
« Reply #31 on: 14. November 2015, 02:36:07 »
may not be a same problem, but will try qterminal tomorrow....
Offline gychang
  • Skill: Novice
« Reply #32 on: 15. November 2015, 20:11:59 »
qterminal can only be used in maximally enlarged window, I get no adjustable arrow that will make the app smaller.  will remove qterminal...
