Author Topic: Basic questions.  (Read 1536 times)
0 Members and 2 Guests are viewing this topic.
Offline kohane
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon // Mate
  • GPU Card: Intel
  • GPU driver: Free I guess...
  • Kernel: Linux 3.16 x64 // Linux 3.18 x64 // Linux 4.2 x64 (in use) - Manjaro 0.8.13
  • Skill: Intermediate
Basic questions.
« on: 22. October 2015, 16:22:48 »
How do I install Pantheon in Manjaro?
How do I tweak it?
Thanks in advance! :)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
Re: Basic questions.
« Reply #1 on: 22. October 2015, 16:41:01 »
I would think, not as straightforward as with other DEs. Ste74 wouldn't complain so much if it were easy. ;)
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline kohane
  • Sr. Mitglied
  • Branch: stable
  • GPU Card: Intel
« Reply #2 on: 22. October 2015, 17:36:34 »
Okay, but... How?
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #3 on: 22. October 2015, 22:29:05 »
Hi kohane , install pantheon on manjaro is not hard  :)  ... but you have to switch into unstable branch to use because pantheon is in development release and yes is subject at possible broken  .
If ok for you i explain more .. ( but you can view my profile into github https://github.com/manjaro/manjaro-tools-iso-profiles/tree/master/pantheon )
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline kohane
  • Sr. Mitglied
  • Branch: stable
  • GPU Card: Intel
« Reply #4 on: 22. October 2015, 23:39:19 »
Ah, unstable...
Well.... I don't know...
My problem is that Cinnamon is failing too much and Mate isn't exactly what I want. I thought of trying a new desktop. But I'm not sure if it's a good idea for me to switch to unstable right now.
BTW, thank you for your quick reply!!  :D
Offline Chrysostomus
  • Maintainer
  • Neckbeards are cool
    • Git
  • Branch: unstable
  • Desktop: Gnome, bspwm
  • GPU Card: Intel HD4000
  • GPU driver: free
  • Kernel: linux44-x64
« Reply #5 on: 17. November 2015, 07:03:10 »
If stability is what you are after, I would go with the official xfce edition. Xfce is known for stability and customizability, and as official edition it receives more developement resources and more user feedback than other editions.
Offline michaldybczak
  • Vollwertiges Mitglied
  • I'm new. Be nice!
  • Branch: Manjaro 64bit
  • Desktop: Plasma 5, Gnome 3
  • GPU Card: nVidia
  • Kernel: 4.4
  • Skill: Novice
« Reply #6 on: 28. December 2015, 18:58:26 »
Ah, unstable...
You can easily tweak gnome to look like pantheon (or even better!). There is even slingshot launcher on pantheon so you actually can create pantheon out of gnome.
I tried that myself and tweaked gnome behaves in exactly the same way as pantheon, even with transparent bar.
Perk of using gnome instead pantheon is that gnome is more configurable then pantheon (with help of addons). Con is that gnome is more resources hungry and a bit slower then pantheon (which is lighter then gnome). On the other hand gnome is stable and reliable, pantheon is not...
