Author Topic: How to make dmenu-manjaro forget bad entries and options?  (Read 1941 times)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
Re: How to make dmenu-manjaro forget bad entries and options?
« Reply #15 on: 23. October 2015, 22:28:12 »
Do this:
1. Delete the file ~/.dmenurc
2. Run dmenu once (this will create a new config file)
3. Open the new ~/.dmenurc and where it says: TERMINAL="urxvt -e" exchange urxvc with lxterminal (or whichever terminal you want dmenu to use...)
« Last Edit: 23. October 2015, 22:29:46 by oberon »
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline Chrysostomus
  • Maintainer
  • Neckbeards are cool
    • Git
  • Branch: unstable
  • Desktop: Gnome, bspwm
  • GPU Card: Intel HD4000
  • GPU driver: free
  • Kernel: linux44-x64
« Reply #16 on: 24. October 2015, 05:03:24 »
Update your system with
Code: [Select]
sudo pacman -SyuThat's how you always get all fixes.
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #17 on: 24. October 2015, 13:49:34 »
Code: [Select]
well yes ;) It's just possible sometimes that you'll have to adjust to modified config cooked up by Chry&Obi ::)
