Author Topic: [SOLVED] Oh My GawD,What The Flux!!  (Read 1036 times)
Offline SunkenShips
  • Neuling
  • Desktop: i3-Gaps,JWM,FluXBoX On top I7
  • GPU Card: Pc1 i3-Gaps,JWM Ati 6850 Ati 6850,pc2 ATI 6750 FluXBoX
  • GPU driver: pc1 FreE.pc2 Non Free.
  • Skill: Novice
« on: 17. October 2015, 01:52:55 »
After Running The FluxBox spin for some hours at the 6 hour mark this happened..  :o Could It Be The Kernel? I'm running the default one. 3.18 LTS
« Last Edit: 18. October 2015, 10:30:46 by SunkenShips »
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
Re: Oh My GawD,What The Flux!!
« Reply #1 on: 17. October 2015, 02:09:59 »
is that xdg-open chewing up your ram?  happened to me too before with open box.  someone forgot to install a file.,
yaourt -S perl-file-mimeinfo should fix the problem
see here for more
https://wiki.archlinux.org/index.php/Xdg-open
« Last Edit: 17. October 2015, 02:19:07 by Lizbeth1 »
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
« Reply #2 on: 17. October 2015, 02:36:56 »
The perl-file-mimeinfo is in the main repositories, there is no need to use yaourt for this.
Code: [Select]
sudo pacman -S perl-file-mimeinfo
Offline SunkenShips
  • Neuling
  • Skill: Novice
« Reply #3 on: 17. October 2015, 04:02:58 »
Alright Buddies,thanx! Ya I guess It was really hungRy.  ;D Will give that a go,then report back after the 6-8 mark see how it behaves.
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
« Reply #4 on: 17. October 2015, 08:17:51 »
Looks like I should install perl-file-mimeinfo by default, then... ::)
Thank you for the information, Lisbeth1!
I hope that fixes it, SunkenShips! Let us know! :)
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #5 on: 17. October 2015, 08:31:11 »
Quote
lol!
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #6 on: 17. October 2015, 16:44:53 »
Yay that is funny.  You know what though i have found it missing in openbox as well as openrc openbox/xfce as well.  It might me prudent to check all the wm distros to ensure its installed on all them.  just a suggestion.
Offline SunkenShips
  • Neuling
  • Skill: Novice
Re: [SOLVED] Oh My GawD,What The Flux!!
« Reply #7 on: 18. October 2015, 10:30:14 »
Ran it for 12 hours,Seems to be behaving thanx for the fix buddies. Will report any more mishaps.
Offline dr-kart
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: Openbox LXQt
  • Kernel: 4.4
  • Skill: Novice
« Reply #8 on: 19. October 2015, 15:18:17 »
confirmed
Have not found "perl-file-mimeinfo" in my openbox (originally 0.8.13 ver)
Thus should I install it?
Desktop Lxqt systemD x64 nvidia 650 xonar DS
Desktop Lxqt systemD x64 nvidia 520
Laptop openbox openrc x32 radeon x700
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #9 on: 19. October 2015, 16:45:00 »
def yes install it!
