Author Topic: KDE plank just in one virtual desktop  (Read 3645 times)
Offline chrismanjaro
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Kde
  • GPU Card: nVidia FeForce GT 635M
  • GPU driver: free
  • Kernel: linux 4.1.10.1
  • Skill: Novice
« on: 16. October 2015, 20:02:25 »
hi to all...i have installed plank..but i can see it just in the first virtual desktop....nothing in all others 3 virtual desktop...
how can i fix it? thanks to all
Offline krg1966
  • Neuling
  • Desktop: KDE
  • Skill: Intermediate
Re: KDE plank just in one virtual desktop
« Reply #1 on: 20. February 2016, 08:31:57 »
I'm experiencing he same issue, I will pass on a fix if I find one.
Offline BbigTree
  • Neuling
« Reply #2 on: 20. February 2016, 12:29:56 »
Did you look into ~/.config/plank/dock1/settings?
No options in there?
Offline montagdude
  • Jr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: KDE
« Reply #3 on: 20. February 2016, 16:46:43 »
There is a setting to make it show up on all virtual desktops, but it doesn't work with KDE. It seems that it doesn't know how to work with Plasma virtual desktops correctly. When I wanted a dock on KDE, I struggled with this problem for awhile and eventually just decided to make a fake dock using another panel with an icons-only task manager. You can make it centered and only spanning part of the screen if you want, so it basically performs the same function as a dock, albeit not as fancy. That being said, if there is a fix or workaround for this problem, I'd like to know.
FYI, I also tried docky and it had the same problem.
« Last Edit: 20. February 2016, 16:49:30 by montagdude »
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
« Reply #4 on: 20. February 2016, 18:31:14 »
I wish daisy was still maintained: http://cdlszm.org/pages/about.php
« Last Edit: 20. February 2016, 18:32:52 by AJSlye »
Offline hakayova
  • Neuling
  • Skill: Novice
« Reply #5 on: 20. February 2016, 19:40:56 »
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU Card: Intel 4th gen
  • GPU driver: free
  • Kernel: Always the newest!
  • Skill: Advanced
« Reply #6 on: 20. February 2016, 20:47:04 »
cairo-dock works in Plasma, appears on all desktops.
Offline krg1966
  • Neuling
  • Desktop: KDE
« Reply #7 on: 23. February 2016, 03:35:02 »
Thanks everyone for your responses, I asked a question on the plank support site which hasn't been answered yet.  I'll respond if that leads to anything, but it sounds like it will not.
montagdude
Thanks for the information, I saw the 'Restrict to Workspace' option in plank and have it turned off.  I thought it made the most sense to be the setting you are referring to.  It definitely isn't working.
I tried using a fake dock first using another panel, but it irritated me.  Although I had it set to auto-hide it would pop-up when I changed workspaces and stayed there until hovering the mouse over it.  I think it would also pop-up when I changed applications and stay visible.
xircon
I'll try cairo-dock next.
Offline krg1966
  • Neuling
  • Desktop: KDE
« Reply #8 on: 13. March 2016, 20:12:23 »
This was the response from Plank support:
It does normally span all workspaces and is using gtk_window_stick to accomplish it.
https://developer.gnome.org/gtk3/stable/GtkWindow.html#gtk-window-stick
I moved on to Cairo-Dock, it is working well.  Did have to restart after installing for it to show up on in all workspaces.
Offline trixon
  • Neuling
  • Skill: Novice
« Reply #9 on: 03. May 2016, 19:37:27 »
Stumbled upon this topic since I had this problem too.
I found a solution that works for me in this bug report: https://bugs.launchpad.net/plank/+bug/1523089
The problem is solved by starting plank from a script instead.
Perhaps another solution could be to add a delay to the .desktop file.
