Here is conky config as asked:
use_xft yes
xftfont 123:size=8
xftalpha 0.1
update_interval 1
total_run_times 0
own_window yes
own_window_type conky
own_window_transparent yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
own_window_colour 000000
own_window_argb_visual yes
own_window_argb_value 0
double_buffer yes
#minimum_size 250 5
#maximum_width 500
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
default_color white
default_shade_color red
default_outline_color green
alignment top_left
gap_x 0
gap_y 20
no_buffers yes
uppercase no
cpu_avg_samples 2
net_avg_samples 1
override_utf8_locale yes
use_spacer yes
minimum_size 0 0
TEXT
${voffset 10}${color EAEAEA}${font GE Inspira:pixelsize=120}${time %I:%M}${font}${voffset -84}${offset 10}${color FFA300}${font GE Inspira:pixelsize=42}${time %d} ${voffset -15}${color EAEAEA}${font GE Inspira:pixelsize=22}${time %B} ${time %Y}${font}${voffset 24}${font GE Inspira:pixelsize=58}${offset -148}${time %A}${font}
${voffset 1}${offset 12}${font Ubuntu:pixelsize=12}${color FFA300}HD ${offset 9}$color${fs_free /} / ${fs_size /}${offset 30}${color FFA300}RAM ${offset 9}$color$mem / $memmax${offset 30}${color FFA300}CPU ${offset 9}$color${cpu cpu0}%
and compton.conf
# Shadow
shadow = true; # Enabled client-side shadows on windows.
no-dock-shadow = true; # Avoid drawing shadows on dock/panel windows.
no-dnd-shadow = true; # Don't draw shadows on DND windows.
clear-shadow = true; # Zero the part of the shadow's mask behind the window (experimental).
detect-rounded-corners = true;
# shadow-radius = 7; # The blur radius for shadows. (default 12)
# shadow-offset-x = -7; # The left offset for shadows. (default -15)
# shadow-offset-y = -7; # The top offset for shadows. (default -15)
shadow-ignore-shaped = false;
shadow-exclude = [
"class_g = 'wbar'",
"class_g = 'Conky'"
# Fading
# fading = true; # Fade windows during opacity changes.
# fade-delta = 4; # The time between steps in a fade in milliseconds. (default 10).
# fade-in-step = 0.03; # Opacity change between steps while fading in. (default 0.028).
# fade-out-step = 0.03; # Opacity change between steps while fading out. (default 0.03).
# no-fading-openclose = true; # Fade windows in/out when opening/closing.
