Author Topic: Budgie 2015.10 Bellatrix ;)  (Read 7083 times)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
Re: Budgie 2015.10 Bellatrix ;)
« Reply #45 on: 26. October 2015, 12:27:49 »
Hey, Ste74: Manjaro base, unstable repos, Budgie DE (only), GNOME packages, Mjro tools, network-manager, lightdm, lts-kernel, etc. Ps_mem = 291MB, Free -m = 250MB.
This is my new Budgie DE, thanks to Ikey Doherty (SolusOS), you & Manjaro. Thanks! :D
Well now budgie is in stable repo .. now can build a stable iso for this environment  ;)
Unused mate in my experience in linux  ::) but budgie environment is plus lighter than mate or equal ? Only curiosity  :P
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #46 on: 26. October 2015, 15:52:01 »
It *feels* a bit lighter than MATE to me but I do not normally run MATE. I normally run GNOME and Budgie is way lighter. It is like MATE, but with GTK3, which is still *experimental* in MATE. Budgie replaces the shell in GNOME. Budgie may be a lightweight DE but I use it to run GNOME applications, and that is where it shines best so far.
It is still a bit rough at the moment--I wouldn't want it on a production machine yet--but it is a brand new DE so that is to be expected. I will probably return to GNOME shortly until Ikey adds a bit more polish to it. :)
« Last Edit: 26. October 2015, 15:54:44 by c00ter »
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #47 on: 27. October 2015, 02:17:10 »
Ste74, I re-installed your Budgie since you upped it to Stable, and I'm glad. You had a couple of packages I did not that makes the interface feel much "smoother." I also found a couple of tricks...
Post-install & update, if the user also installs package group "gnome-shell" (total about 1.5 MB) you can then boot into GNOME and using Tweak Tool can: A) add minimize/maximize window buttons, B) tweak Nautilus settings--for instance, I like "open with 1-click" and C) other GNOME features like this in Lollypop and probably a few other GNOME applications that put a conf or pref settings in the GNOME top panel. When done, you can logout of GNOME, log back into Budgie and remove "gnome-shell." The settings changes you make will remain.
I also like adding "gnome-session properties" from AUR so I can adjust a few startup services/apps, but that's an individual preference.
« Last Edit: 27. October 2015, 02:20:15 by c00ter »
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #48 on: 27. October 2015, 21:57:12 »
Thank you for tip  ;)
This new concept for budgie
https://plus.google.com/+Solus-Project/posts/gKYwbfZRCd6
Canale IRC italiano
#manjaro-it
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #49 on: 27. October 2015, 22:07:59 »
Thank you for tip  ;) This new concept for budgie
Exciting stuff! IMHO, Budgie DE is gonna take Linux by storm in 2016.  With competition from oberon's Deepin DE. ;)
« Last Edit: 27. October 2015, 22:26:44 by c00ter »
Offline kohane
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon // Mate
  • GPU Card: Intel
  • GPU driver: Free I guess...
  • Kernel: Linux 3.16 x64 // Linux 3.18 x64 // Linux 4.2 x64 (in use) - Manjaro 0.8.13
  • Skill: Intermediate
« Reply #50 on: 27. October 2015, 22:51:23 »
Now Budgie is working!! I could play around and configure it. Very nice effects, handy desktop. The menu is a bit peculiar.
It hanged at some point, but that happens to me too with Cinnamon. I guess is a GTK 3 related thing. Or maybe Python that is failing after the last two updates.
Anyway, I'm loving Budgie and looking forward to see the improvements to come.
Thanks!!!!  :D
