Author Topic: Budgie 2015.10 Bellatrix ;)  (Read 7082 times)
Offline Lt__Gruber
  • Neuling
  • Desktop: Gnome
  • Skill: Novice
Re: Budgie 2015.10 Bellatrix ;)
« Reply #15 on: 08. October 2015, 17:24:54 »
I don't like to see plank in the desktop, i think you should removed it.
Waiting to test the iso, keep up the good work. :)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
« Reply #16 on: 08. October 2015, 18:11:57 »
Do you think a panel on the bottom and a dock on the left (where it could easily be removed by the user)  would be better?
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #17 on: 08. October 2015, 21:48:51 »
My personal preference--based on the Solus Project's design principle is no dock at all. Why? Two reasons, both from the Budgie website:
Quote
Designed with the modern user in mind, it focuses on simplicity and elegance.
I like the simplicity part. And:
Quote
Also note that Budgie can now emulate the look and feel of the GNOME 2 desktop, optionally, via a setting in the panel preferences.
So the user already has some options built-in. The user can always add a dock of their own choosing post-installation. Maybe even a Budgie dock? ;)
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline Lt__Gruber
  • Neuling
  • Desktop: Gnome
  • Skill: Novice
« Reply #18 on: 09. October 2015, 15:57:27 »
No dock at all, i prefer simple also. Budgie last time i checked have a panel. And the menu for launching apps, is prety and simple.
Thats just my opinion. :)
Offline ToxicDragon
  • Neuling
  • I'm new. Be nice!
« Reply #19 on: 09. October 2015, 16:13:12 »
No dock PLZ! :)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #20 on: 10. October 2015, 21:56:08 »
Hybrid solution with dock hidden at the left of screen ?
i see immage on solus forum .. most users use plank ..
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Lt__Gruber
  • Neuling
  • Desktop: Gnome
  • Skill: Novice
« Reply #21 on: 10. October 2015, 22:06:12 »
If you really want, maybe its good option. I still prefer no dock.  ;D
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #22 on: 10. October 2015, 22:07:45 »
Why would you want to use plank you can dock your favourite applications on the panel simple,
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
Offline Lt__Gruber
  • Neuling
  • Desktop: Gnome
  • Skill: Novice
« Reply #23 on: 10. October 2015, 22:15:45 »
Thats why i dont use any dock, i like simplicity.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #24 on: 10. October 2015, 22:25:15 »
That was my idea, too. The dock would be easy to remove there.
@Lt__Gruber, mandog: I don't use a dock either, but I'm aware of its aestetic qualities and popularity. I wouldn't waste the chance to win some user with it.
« Last Edit: 10. October 2015, 22:30:11 by eugen-b »
Offline kohane
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon // Mate
  • GPU Card: Intel
  • GPU driver: Free I guess...
  • Kernel: Linux 3.16 x64 // Linux 3.18 x64 // Linux 4.2 x64 (in use) - Manjaro 0.8.13
« Reply #25 on: 22. October 2015, 20:51:45 »
I installed Budgie desktop but when I login nothing happens. What else should I do or install?
Thanks in advance :)
Offline BorisBalkan
  • Neuling
  • Branch: Stable
  • Desktop: Mate - Budgie
  • GPU Card: Ati Mobility Radeon HD 5650
  • GPU driver: Free driver
  • Kernel: 4.2.3-1-x64
« Reply #26 on: 22. October 2015, 22:08:13 »
Yesterday after the Manaro Update it happened the same, login in automatic and i see only the mouse pointer but nothing else...
I switching to tty2 and text login, after i resolve this problem with AUR with budgie-desktop-git, it will replace the budgie-desktop from repo Community and after restart everything is ok...i thing this is a little bug with budgie-desktop and Gnome 3.18...
Ps i use budgie desktop every day on my laptop from the Budgie-Manjaro Rc2 and i have only this little problem, nothing else...everything is always smooth...
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #27 on: 22. October 2015, 22:13:45 »
I remember that Pantheon had the issue that on first boot you needed to select the correct session in the login greeter.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #28 on: 22. October 2015, 22:22:10 »
Guys  >:( gtk 3.18 arrived .. i think is the problem .. budgie wm have problem .. i have to investigate if problem is our or if budgie/solus upstream not implemented gtk 3.18 .. philm is autor of pkgbuild for create budgie-desktop pkg into manjaro . i ask him to help me to investigate. :P
Canale IRC italiano
#manjaro-it
Offline kohane
  • Sr. Mitglied
  • Branch: stable
  • GPU Card: Intel
« Reply #29 on: 22. October 2015, 23:44:44 »
Oh, well... Then it's a matter of waiting for the next update?
I'd really love to try it, looks very good.  :D
