Author Topic: New Iso for maintenance of Manjaro Pantheon Shell 2015.10 Bellatrix  (Read 7789 times)
Offline tuxnotes
  • Neuling
  • I'm new. Be nice!
    • tuxnotes
  • Skill: Novice
Re: New Iso for maintenance of Manjaro Pantheon Shell 2015.10 Bellatrix
« Reply #30 on: 21. February 2016, 21:47:41 »
Hello!
He still supported? Or better not to install or select another DE?
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #31 on: 21. February 2016, 21:56:11 »
Hi , yes but remember this pantheon is in hard development in arch so this iso is a development release and based on our unstable branch . I continue the support for this . Please remember that read the first post how run after install and before update my little script for this iso.  :)
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline tuxnotes
  • Neuling
  • I'm new. Be nice!
    • tuxnotes
  • Skill: Novice
« Reply #32 on: 21. February 2016, 22:02:05 »
Ste74 , thank you! I'll try.
Offline tuxnotes
  • Neuling
  • I'm new. Be nice!
    • tuxnotes
  • Skill: Novice
« Reply #33 on: 21. February 2016, 22:51:54 »
What is the password? Do not fit the manjaro.
Quote
n you have to select the pantheon session ( default is gnome but is broken )
Thanks
« Last Edit: 21. February 2016, 23:25:38 by tuxnotes »
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #34 on: 21. February 2016, 23:18:39 »
User manjaro pass manjaro but at the login screen you have to select the pantheon session ( default is gnome but is broken )
Canale IRC italiano
#manjaro-it
Offline mitcoes
  • Jr. Mitglied
  • Branch: STABLE
  • Desktop: XFCE
  • GPU Card: NVIDIA GTX 750 Ti
  • GPU driver: NON FREE - not other available -
  • Skill: Guru
I used i3 spin to install gnome and kde and xfce as gnome spin did not let me install (add to the DM) other WM or DEs.
I love Manjaro is getting so many WMs and DEs, almost every one out there
But
Why not one ISO with several profiles where you can select your SPIN and then, installing make the download.
Yes we have the net SPIN, but it is not for newbes.
It would be great even to have an ALL IN ONE spin, not only for educational purposes, also for kiosk mode where you can be asked to select your DE or WM, and be sure there is no conflict between all those WMs and DEs, being able to have all of them properly configured together at the same time - Deepin was a disaster for my gnome language config and I still haven't recovered it al -
Also I think it would be great to have META PACKAGES with the spins in order to be able to install the DEs or WMs with their Manajro goodies and not plain and simple as they sue to come from the repos without enjoying all the spin fine tuning and artwork.
I know it is not your work but being in charge of 2 spins I think you will understand what is what I am asking for, and why and be able to forward it to whoever can do something about it.
It would be nice for Manjaro "all in one" to be the first distro able to have all the WMs DEs GNU/Linux enjoys at the same computer with their own work art, and with all the configuration files clearly owned by each one
And also have a GRUB2 .iso boot profile in order to put manjaroaio.iso at a separate GPT /boot partition as default for using it as repairing tool or to make other installation or to copy to a USB with grub installed to install Manjaroaio.iso from it. (Now Multisystem has to unpack the iso to make it boot and do not allow different manjaro spins)
