Author Topic: New Iso for maintenance of Manjaro Pantheon Shell 2015.10 Bellatrix  (Read 7682 times)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
Hi Community ,
i have just upload now new iso for pantheon shell .
This isos contain all update at yesterday on our unstable branch ( Iso is based on unstable branch ) :
Kernel 4.1.9
hexchat preconfigurated to connect on our IRC channel
removed audience and replaced with smplayer
geary stable and rebuild to notify bullet in a dock
renamed most pkg and rebuilded to allign it on alucryd repo
three installer ( Thus , Calamares (dev version) and cli installer: note that if you want use cli installer before install xterm pkg ( notice of this issue after build the iso .. sorry  :P )
Download
https://sourceforge.net/projects/manjarodev/files/users/Ste74/Pantheon/Dev/
Greetings
Ste
EDIT : After update of gtk 3.18 the system not work fine .. launch this script in the user home directory , i tested only in my system and work .. open terminal and type
Code: [Select]
git clone https://github.com/Ste74/pantupdate.git
If git not installed run
Code: [Select]
sudo pacman -S git
after download the script
Code: [Select]
cd pantupdate
sudo sh pantupdate.sh
answer yes at the request of the script and at the end reboot .
This script revert some pkg to alucryd repo and install patch for wingpanel .
« Last Edit: 21. October 2015, 07:49:38 by Ste74 »
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
Re: New Iso for maintenance of Manjaro Pantheon Shell 2015.10 Bellatrix
« Reply #1 on: 04. October 2015, 21:49:54 »
Wow, exciting!!!  8) Looking GREAT!
Congrats Stefano! I will check it out asap :)
« Last Edit: 04. October 2015, 21:54:41 by oberon »
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #2 on: 04. October 2015, 21:54:11 »
removed audience
That sounds a bit sad to me ???
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #3 on: 04. October 2015, 21:56:17 »
 ;D ;D ;D ;D lol oberon   ::) ::) ::)
https://launchpad.net/audience this is my audience  >:D
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #4 on: 14. October 2015, 13:53:50 »
Gtk 3.18 .. pfff pantheon broken ...  >:(
 will waiting update in upstream   :(
Canale IRC italiano
#manjaro-it
Offline sugarshock
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #5 on: 17. October 2015, 11:30:30 »
After loging-in into Pantheon, I can only see the wallpaper. Nothing shows up, no dock, no panel.
I can use the terminal with Ctrl+Alt+FF, but I don't know how to connect my wifi in command line.
What shall I do?
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #6 on: 17. October 2015, 14:06:58 »
Hi,at login you have to choice the Pantheon session,default Is gnome. Is a bug of pantheon session manager.  If you install after first time the session is saved and work fine.
Just remember at the moment ignore message of update. If you update system pantheon is broken.  In upstream not implemented gtk 3.18
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #7 on: 18. October 2015, 22:56:00 »
Upload a new profile on github .. tomorrow build a iso .. patched work fine ...  :)
Canale IRC italiano
#manjaro-it
Offline sb56637
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon
  • GPU Card: Intel
« Reply #8 on: 19. October 2015, 05:38:41 »
Wow, so it's already fixed to work with Gnome 3.18?
Would it be better to make this based on Manjaro's Stable branch, so that it doesn't update so quickly to the upstream Arch releases? The delay before new Gnome releases hit Stable should be enough to patch Pantheon.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #9 on: 20. October 2015, 12:44:19 »
Hi community , to solve after update with this iso you can remove all .bzr.manjaro pkg and replace with the .bzr pkg from alucryd repo . I will prepare a little script to perform that but now want start a test :
Build an iso with manjaro stable repo , delete the repo alucryd and in my repo merge the pkg of alucryd but not immediatly in according with stable repo manjaro .. do you think ?
Canale IRC italiano
#manjaro-it
Offline Fatboy
  • Sr. Mitglied
  • "Spiral out. Keep going..."
  • Branch: stable
  • Desktop: Xfce, KDE plasma 5
  • GPU Card: nVidia GeForce 210
  • GPU driver: 340.xx
  • Kernel: Manjaro Kernel 4.4 LTS
« Reply #10 on: 20. October 2015, 15:08:55 »
Good job ste74! This looks amazing! I am quite a fan of the pantheon DE, although it felt a bit sluggish on top of ubuntu 14.04. I'm assuming it's way faster on manjaro? :)
It seems that gnome and KDE 5 are the most active DEs with regards to development? Or am I mistaken?
"I'm reaching for the random or whatever will bewilder me. Whatever will bewilder me."
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #11 on: 20. October 2015, 22:41:33 »
Hi , thank you .. do you mean ? Development into manjaro or in general ? The most problem on pantheon is your developer : elementary team .. more bug not solved and biblic time to release .. big problem is the base ubuntu   :P ..
Canale IRC italiano
#manjaro-it
Offline sb56637
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon
  • GPU Card: Intel
« Reply #12 on: 21. October 2015, 04:21:05 »
I finally got a chance to test out this ISO. Very nice work! It's actually one of the first times I've used Pantheon, either in Arch or in Elementary, and the overall impression is good. Just a few things:
- No aero-snap by dragging windows to the corner or side for quarter or half tiling.
- Power management (screen off after 5 minutes) doesn't seem to work.
- Multiple control centers is a bit confusing.
Again, nice work, and I'd love to see a stable release of this!
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #13 on: 21. October 2015, 07:51:53 »
Modified the first message for solve the problem on gtk 3.18 ..
@sb56637 : thank you for your observation  ;)
Canale IRC italiano
#manjaro-it
Offline Fatboy
  • Sr. Mitglied
  • Branch: stable
« Reply #14 on: 21. October 2015, 08:51:51 »
Hi Ste74, I mean the developers of the DE itself, e.g. with Pantheon, plasma 5 and gnome, some of the bugs seems related to the GNU and not the linux it is based on? Maybe ubuntu used the old version without the bug fixes being applied. I think I should give this manjaro one a spin :D
I love XFCE and it seems not a lot of people are developing the DE, if I remember the gap between the 4.10 and 4,12 release? Excuse my ignorance, I am under correction here.
