Author Topic: [Proposals] Wat would be Next Mate ?  (Read 4632 times)
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
Re: [Proposals] Wat would be Next Mate ?
« Reply #15 on: 12. October 2015, 21:24:53 »
If you ask me ?  need to documentation of  mate-tweak, in this form it break user usability... if you got a setup you can loose it easily
and noway to return
Dutch go the dutch site :)
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #16 on: 12. October 2015, 21:41:05 »
played a bit... seems to need some polkit  right ?
only broke my build setup again with it... does not save it properly if you run it from menu...atleast... find it also not stable as it is...
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #17 on: 13. October 2015, 21:21:30 »
first concept iso : with vertex :p
Offline k357k9
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: Xfce 16.06 pre2
  • Skill: Intermediate
« Reply #18 on: 13. October 2015, 21:57:51 »
Very nice.  Is there any way to make those icons blue to match the other blue?
Is there any chance that the mate/mint menu will be part of this?
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #19 on: 13. October 2015, 22:03:56 »
for mate menu i guess, its a low chance... mayby i have just find a new theme or try something else..
i hate the idea, each update can brake your menu* is with cinnamon also but this is more fundamental i gues..
didnt get mate-menu worked ootb, dont want to figure out why even i changed the install file about the glibc schemas..
but did not work somehow...
Mayby it need a good tutorial and to maintain it...
Offline k357k9
  • Sr. Mitglied
  • Branch: Stable
« Reply #20 on: 13. October 2015, 22:11:43 »
Does the problem with mate/mint menu have something to do with python 2 vs 3?
Is there another menu that will work with mate and has favorites and a search bar?
The blue is beautiful, but the green icons just do not match the theme.
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #21 on: 13. October 2015, 22:19:26 »
elementary theme is blue ? :)
Gnome-main menu, is the base off those but has not the features :p
i gona pick Vertex-icons probably :) is a matching icon theme on paper of that dev..
i dont know but problem is also on python alson ubuntu is systemic bit behind.. i dont know those stuf to make it more stable.... even i looked for cardapio ..  just want to put something in and after a regular update menu is broken...if i know to maintain those then can see but, i have no clear sight of it..
Offline sb56637
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon
  • GPU Card: Intel
« Reply #22 on: 13. October 2015, 22:30:14 »
It's a pity they can't integrate the Whisker menu from XFCE into Mate.
Offline k357k9
  • Sr. Mitglied
  • Branch: Stable
« Reply #23 on: 13. October 2015, 22:58:18 »
Whisker is a great menu.  Xfce needed something like it.
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #24 on: 14. October 2015, 16:07:52 »
dont know how to make mate-menu stable.... thats the big question :p
Also is there a tutorial about mate-tweak. personal i find it also unstable.. :)
if i can make a manjaro-profile then is ok :)
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #25 on: 14. October 2015, 19:02:32 »
mate-tweak would be less trouble some if i can set  manjaro.ui besides the fedora and gnome2 , so if some got some explaination how i can save the ui  would be great... mayby inplent it in the package then is less troublesome
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #26 on: 14. October 2015, 21:05:36 »
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #27 on: 17. October 2015, 09:15:05 »
ok , the  mate-tweak layout worked as i wanted... add manjaro somewhere in the source and made te package
so :) cool
Maybe add Manjaro Plank layout ? intoo mate-tweak ?
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #28 on: 18. October 2015, 01:17:54 »
Ok end result, put Manjaro intoo the code, forked te git and made a package.
But still this package does not need user password to change /usr/share/mate-panel-layouts.. find it weird...
Somehow caja logo dont comes on the starter :lol
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #29 on: 18. October 2015, 14:07:50 »
