Author Topic: tweaking i3  (Read 11904 times)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
Re: tweaking i3
« Reply #15 on: 29. September 2015, 07:49:51 »
Fixed it and the ISOs are currently uploading  8)
Btw, there was a little typo in shadow-exclude = [ "class_g" = 'i3-frame'" ]
One extra quote after class_g that needs to be left out! ;)
btw @Airblader, when is i3 4.11 to be expected and can we test it already? Is there a secret PKGBUILD somewhere?  >:D
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline Airblader
  • Jr. Mitglied
  • I'm new. Be nice!
  • Desktop: i3-gaps
  • Skill: Advanced
Re: tweaking i3
« Reply #16 on: 29. September 2015, 07:58:19 »
4.11 will ship very soon ;) You can always just use the next branch of i3. Releasing i3 just means merging that into master. So for example just install i3-git.
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
Re: tweaking i3
« Reply #17 on: 29. September 2015, 11:45:10 »
Offline Airblader
  • Jr. Mitglied
  • I'm new. Be nice!
  • Desktop: i3-gaps
  • Skill: Advanced
Re: tweaking i3
« Reply #18 on: 30. September 2015, 09:15:47 »
It has just been released. :)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
Re: tweaking i3
« Reply #19 on: 30. September 2015, 12:13:22 »
Supercool! 8)
I am already toggling sticky ;D
Code: [Select]
bindsym $mod+Shift+s sticky togglefun!
Congratulations and thanks, Airblader and everybody at i3!
Offline audiosl4ve
  • Neuling
  • Linux scrub
  • Desktop: i3-gaps
  • GPU Card: Intel HD
  • Kernel: 64bit 4.1.11
  • Skill: Novice
Re: tweaking i3
« Reply #20 on: 13. October 2015, 18:58:56 »
hello folks first of all. I know i mught have couple of questions that are silly and can be found googleing but i tried and just well i can't somehow find them. So i need your help. I looked in all configs and didn't find what i was looking for or somehow missed that. So here we go :)
1. Can i somehow move my i3-bar on top?
2. Where can i configure i3-bar. What i want is to remove lan part from it and somehow fix battery status since it's not working (it says no battery all the time).
3. Where can i edit/remove conky's from desktop (the bottom left and top right ones)? .conkyrec is empty soo :S
That would be all for now. I know it might be silly but i'm still newbie to WMs. I edited configs a little to suite my tastes and added icons to workspaces but i want to do more! :D
here's a pic for you :)
Thanks a bunch!  ;D
Offline twodogsdave
  • Jr. Mitglied
  • Desktop: i3
  • GPU Card: Radeon HD Graphics
  • GPU driver: free
Re: tweaking i3
« Reply #21 on: 13. October 2015, 19:54:37 »
1) put i3 bar on top
put 'position top' in i3 config file under the 'bar' section.
2) look at your i3status.conf file
put a hash mark (#) in front of 'order' to not display a section.
ex:
order += "cpu_usage"
# order += "load"
order += "disk /"
# order += "disk /home"
order += "wireless _first_"
order += "ethernet _first_"
order += "battery 0"
order += "tztime local"
# order += "ipv6"
# order += "run_watch DHCP"
3) uncomment the conky part in the i3 config file
# exec --no-startup-id ~/.conky/start_conky_grey
Hope this helps!
Offline audiosl4ve
  • Neuling
  • Linux scrub
  • Desktop: i3-gaps
  • Skill: Novice
Re: tweaking i3
« Reply #22 on: 13. October 2015, 20:02:58 »
i would gladly say it helped but it didn't, even one bit xD
1. i searched my config too and i still haven't found something with bar and position. Here's my config: http://pastebin.com/Fcc1FD3V
2. searched im pcmanfm for i3status.conf and still couldn't find one. Am i that dumb or what? :O
3. it is uncommented like that and it still boots up. Well it's getting weird now xD
Thanks for your help tho
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
Re: tweaking i3
« Reply #23 on: 13. October 2015, 20:39:28 »
The entry about i3bar starts in line 247 of your config
Remember that you have to reload the config to apply the settings (mod+Shift+c)
Quote
The default config is stored in /etc/i3status.conf. Best practice if you want to customize it is to copy and rename it to ~/.i3status.conf and edit that one. i3status will automatically use your custom file then.
Quote
When I look at your config: only the grey conky is commented out! Comment out line 274 and conky will not start next time. With
Code: [Select]
pkill conkyyou can stop it right away in the current session :)
Offline audiosl4ve
  • Neuling
  • Linux scrub
  • Desktop: i3-gaps
  • Skill: Novice
Re: tweaking i3
« Reply #24 on: 13. October 2015, 20:52:14 »
Thanks! I did what i needed with 1 and 2! Now for the 3rd one. I killed it manually but i want to kill only bottom one? Are they together as one conky? :D
Offline twodogsdave
  • Jr. Mitglied
  • Desktop: i3
  • GPU driver: free
Re: tweaking i3
« Reply #25 on: 13. October 2015, 22:02:31 »
Hey, audiosl4ve.  Sorry, not too familiar with fonts, but I saw your config in pastebin and was wondering what font do I install to get my bar to look like yours (the workspace names)?  Thanks.
Offline audiosl4ve
  • Neuling
  • Linux scrub
  • Desktop: i3-gaps
  • Skill: Novice
Re: tweaking i3
« Reply #26 on: 13. October 2015, 22:03:31 »
just copy paste icon from here to text editor and voila :)
http://fortawesome.github.io/Font-Awesome/cheatsheet/
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
Re: tweaking i3
« Reply #27 on: 15. October 2015, 02:17:25 »
No, they are actually two separate conkies.
The scripts start_conky_grey and ..._green are located in /usr/bin/ There you can comment out the shortcut one :)
As you will see there, the conky config files live in /usr/share/conky/
have fun! :)
Offline Belemrys
  • Jr. Mitglied
  • I love Manjaro i3!
  • Branch: Unstable
  • Desktop: i3
  • GPU Card: ATI Radeon r9 270
  • GPU driver: MESA
  • Kernel: 4.1
  • Skill: Novice
Re: tweaking i3
« Reply #28 on: 16. October 2015, 19:56:37 »
have fun! :)
Worked perfectly for me! Why don't we get a conky manager? I feel like you include it in your Fluxbox ISO...
Offline paolo
  • Neuling
  • Branch: stable
  • Desktop: i3
  • GPU Card: ATI Mobility Radeon 7500 32MB
  • GPU driver: Mesa
  • Skill: Novice
Re: tweaking i3
« Reply #29 on: 25. October 2015, 18:30:36 »
hello !
thanks to the suggestion of Oberon and Twodogsdave I make some small modification to my laptop... but my laptop can use 2 battery   ::)
I make a modification in etc/i3status.conf but the first battery is showed, and for the second battery I can only see ¨No battery¨
Code: [Select]
# i3status configuration file.
# see "man i3status" for documentation.
# It is important that this file is edited as UTF-8.
# The following line should contain a sharp s:
# ß
# If the above line is not correctly displayed, fix your editor first!
general {
        colors = yes
        interval = 5
color_good = "#2ECC71"
        color_bad = "#E74C3C"
# color_degraded = " "
# order += "load"
order += "disk /"
order += "battery 1"
order += "battery 2"
# order += "ipv6"
# order += "run_watch VPN"
cpu_usage {
format = " cpu  %usage "
load {
format = " load %1min "
# max_threshold = 0.3
disk "/" {
# format = " hdd %avail "
format = " ⛁ %avail "
disk "/home" {
format = " /home %avail "
wireless _first_ {
# format_up = "W: (%quality at %essid) %ip"
format_up = "  %essid %quality "
format_down = " no wlan "
ethernet _first_ {
# if you use %speed, i3status requires root privileges
format_up = " lan: %ip %speed "
format_down = " no lan "
battery 1 {
# format = "%status %percentage %remaining %emptytime"
format = " %status %percentage"
format_down = "No battery"
last_full_capacity = true
integer_battery_capacity = true
# status_chr = ""
status_chr = "⚡"
status_bat = ""
# status_bat = "bat"
# status_bat = "☉"
# status_full = ""
status_full = "☻"
        low_threshold = 15
threshold_type = time
battery 2 {
# status_chr = ""
status_chr = "⚡"
status_bat = ""
# status_bat = "☉"
# status_full = ""
status_full = "☻"
        low_threshold = 15
tztime local {
#        format = "%Y-%m-%d %H:%M:%S"
format = " %d.%m. %H:%M "
# run_watch DHCP {
#         pidfile = "/var/run/dhclient*.pid"
# run_watch VPN {
#         pidfile = "/var/run/vpnc/pid"
As you can see in the file the batterys are called ¨ battery 1¨ e ¨battery 2¨, in the screeshot in xfce-battery-settings the batterys are called ¨Battery_BAT1¨ e ¨ Battery_BAT0¨  :o
If in the file I write ¨battery 0¨ i3bar show only 1 battery
Can someone help me please ?
« Last Edit: 27. October 2015, 14:19:38 by paolo »
Dell Latitude C640 – CPU P4 2Ghz – RAM 2 GB
HP Compaq nx6310 - CPU M410 1,46Ghz - RAM 2 GB
Asus EeePC 1001PX - CPU Atom N450 1,66Ghz - RAM 2 GB
HP Pavillion dv2000 - CPU T7300 2Ghz - RAM 3 GB
all for Manjaro i3 by oberon
