Author Topic: Missing functionality in Manjaro Fluxbox 0.8.13.1-x86_64  (Read 3027 times)
Offline paulus
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
Re: Missing functionality in Manjaro Fluxbox 0.8.13.1-x86_64
« Reply #15 on: 16. September 2015, 21:52:12 »
The CUPS-server (a site in the browser) is not needed any longer: in this Manjaro there is an item Printer Settings under Configuration, so from there the printer must be recognized, but it isn't, unfortunately.
I tried also to uninstall the universal driver, I tried all other ML-xxxx drivers that are in AUR, but no success.
In the LXDE-version I already tried the original drivers of the Samsung site, but also no luck.
paulus
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #16 on: 17. September 2015, 00:07:33 »
paulus
NO that's not what I said  Printer Settings under Configuration,  that is hit and miss.
you only need what i said  remove printer driver and all the Manjaro stuff for printing HP foomatic
install cups, install system-config-printer,  1.5.7-1 reboot, connect your printer switch it on in  system-config-printer click connect  to server once connected to server your printer should show up as connected without the drivers  instantly it will not work but connected, if it does not then cups may not be started. post the results.
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
Offline paulus
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #17 on: 17. September 2015, 13:51:01 »
I did as you told: I removed all the Manjaro-printer drivers. Then I rebooted, went to system-config-printer: that is exactly what I meant, for this IS the Printer Settings under Configuration! ;) It is just another way to reach and access it!
But again: no recognition, I mean by this: the printer does not show up in the list, only the Generic-CUPS-PDF. So NOT my Samsung printer.
This is my output.
So I think, but I might be wrong, that CUPS IS detected, otherwise the Generic-CUPS-PDF would not show up, am I right?
Again: thanks for helping!
paulus
Offline mandog
  • Held Mitglied
  • Branch: All
  • GPU Card: nvidia
  • Kernel: latest
  • Skill: Advanced
« Reply #18 on: 17. September 2015, 17:59:21 »
do this in terminal sudo  lpinfo -v  with the printer on this should tell you if the printer is recognised if not try another port incase its blocked on that port :
this is mine
network ipps
network https
network http
network ipp
network lpd
file cups-pdf:/
network socket
network smb
direct usb://EPSON/L210%20Series?serial=545A5A4D3034323964&interface=1
Taking it that its a usb printer are you running 64 bit check your lead also if it does not show cups is not relevant for this
Offline paulus
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #19 on: 17. September 2015, 19:52:48 »
This is the output, so the printer is not seen:
Code: [Select]
[manjaro@manjaro-FX ~]$ sudo  lpinfo -v
network https
network socket
file cups-pdf:/
network lpd
network http
network ipp
network ipps
direct hp
network smb
direct hpfax
It is indeed Manjaro Fluxbox x64-bit, and it is an UBS-printer.
What is the next step?
Offline paulus
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #20 on: 17. September 2015, 20:11:49 »
Some progress has been made!
I just copied the output of my Peppermint OS 6 into the Printer Manager:
Code: [Select]
usb://Samsung/ML-1640%20Series?serial=144QBAHS312058Y.
Then I let is search for ML-1640 driver, and it was accepted. Also the Test Print went well.
But I am not too optimistic, because this is only once; it is done in a life situation via USB, so it is not permanent and it could work out wrong again in the installed Manjaro Fluxbox; also I have experienced sooo much trouble, that it seems too good to be true, I must say! ???
So I will have some testing around, and reboot the life USB serveral times, and then, if everything remains alright, then I will probably have enough courage to make a real installation!
But: so far, so good.
I will be back after a thorough test periode.
Anyway: thank you for your help: by that it brought me to the idea to copy the same command in Peppermint OS, and then copy the output into the Printer Manager! ;D
Till soon!
paulus
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
« Reply #21 on: 17. September 2015, 23:08:37 »
Hi paulus!
Sounds great what you have achieved! :)
Be aware that when you reboot a live environment you will always start from zero. So in order to see if your settings are permanent you'd at least have to install to a virual harddrive in virtualbox...
Good luck anyway! :)
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline paulus
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #22 on: 17. September 2015, 23:21:36 »
As I presumed: not solved yet.
In "task attibutes", which I cannot copy and show here, there is an item "job-printer-state-message", that has the output: "Waiting for printer to become available."
Thats the problem right now. I haven't restarted yet, as already in the same life session this problem occured!
I pressed "Help", that started a diagnostical tool. The output, called "Printing troubleshooter" shows following as output:
Code: [Select]
Page 1 (<troubleshoot.SchedulerNotRunning.SchedulerNotRunning object at 0x7fc1a61a4358>):
{'cups_connection_failure': False}
Page 2 (<troubleshoot.CheckLocalServerPublishing.CheckLocalServerPublishing object at 0x7fc1a61b23c8>):
{'local_server_exporting_printers': False}
Page 3 (<troubleshoot.ChoosePrinter.ChoosePrinter object at 0x7fc1a61b2198>):
{'cups_dest': <cups.Dest Samsung-ML-1640 (default)>,
 'cups_instance': None,
 'cups_queue': 'Samsung-ML-1640',
 'cups_queue_listed': True}
Page 4 (<troubleshoot.CheckPrinterSanity.CheckPrinterSanity object at 0x7fc1a61b2630>):
{'cups_device_uri_scheme': 'usb',
 'cups_printer_dict': {'device-uri': 'usb://Samsung/ML-1640%20Series?serial=144QBAHS312058Y.',
                       'printer-info': 'Samsung ML-1640',
                       'printer-is-shared': True,
                       'printer-location': '',
                       'printer-make-and-model': 'Samsung ML-1640, 2.0.0',
                       'printer-state': 3,
                       'printer-state-message': 'Waiting for printer to '
                                                'become available.',
                       'printer-state-reasons': ['none'],
                       'printer-type': 143444,
                       'printer-uri-supported': 'ipp://localhost/printers/Samsung-ML-1640'},
 'cups_printer_remote': False,
 'is_cups_class': False,
 'local_cups_queue_attributes': {'charset-configured': 'utf-8',
                                 'charset-supported': ['us-ascii', 'utf-8'],
                                 'color-supported': False,
                                 'compression-supported': ['none', 'gzip'],
                                 'copies-default': 1,
                                 'copies-supported': (1, 9999),
                                 'cups-version': '2.0.4',
                                 'document-format-default': 'application/octet-stream',
                                 'document-format-supported': ['application/octet-stream',
                                                               'application/pdf',
                                                               'application/postscript',
                                                               'application/vnd.adobe-reader-postscript',
                                                               'application/vnd.cups-pdf',
                                                               'application/vnd.cups-pdf-banner',
                                                               'application/vnd.cups-postscript',
                                                               'application/vnd.cups-raster',
                                                               'application/vnd.cups-raw',
                                                               'application/x-cshell',
                                                               'application/x-csource',
                                                               'application/x-perl',
                                                               'application/x-shell',
                                                               'image/gif',
                                                               'image/jpeg',
                                                               'image/png',
                                                               'image/pwg-raster',
                                                               'image/tiff',
                                                               'image/urf',
                                                               'image/x-bitmap',
                                                               'image/x-photocd',
                                                               'image/x-portable-anymap',
                                                               'image/x-portable-bitmap',
                                                               'image/x-portable-graymap',
                                                               'image/x-portable-pixmap',
                                                               'image/x-sgi-rgb',
                                                               'image/x-sun-raster',
                                                               'image/x-xbitmap',
                                                               'image/x-xpixmap',
                                                               'image/x-xwindowdump',
                                                               'text/css',
                                                               'text/html',
                                                               'text/plain'],
                                 'finishings-default': 3,
                                 'finishings-supported': [3],
                                 'generated-natural-language-supported': ['en-us'],
                                 'ipp-versions-supported': ['1.0',
                                                            '1.1',
                                                            '2.0',
                                                            '2.1'],
                                 'ippget-event-life': 15,
                                 'job-cancel-after-default': 10800,
                                 'job-cancel-after-supported': (0,
        2147483647),
                                 'job-creation-attributes-supported': ['copies',
        'finishings',
        'ipp-attribute-fidelity',
        'job-hold-until',
        'job-name',
        'job-priority',
        'job-sheets',
        'media',
        'media-col',
        'multiple-document-handling',
        'number-up',
        'output-bin',
        'orientation-requested',
        'page-ranges',
        'print-color-mode',
        'print-quality',
        'printer-resolution',
        'sides'],
                                 'job-hold-until-default': 'no-hold',
                                 'job-hold-until-supported': ['no-hold',
                                                              'indefinite',
                                                              'day-time',
                                                              'evening',
                                                              'night',
                                                              'second-shift',
                                                              'third-shift',
                                                              'weekend'],
                                 'job-ids-supported': True,
                                 'job-k-limit': 0,
                                 'job-k-octets-supported': (0, 2736876),
                                 'job-page-limit': 0,
                                 'job-priority-default': 50,
                                 'job-priority-supported': [100],
                                 'job-quota-period': 0,
                                 'job-settable-attributes-supported': ['copies',
        'finishings',
        'job-hold-until',
        'job-name',
        'job-priority',
        'media',
        'media-col',
        'number-up',
        'output-bin',
        'page-ranges',
        'print-color-mode',
        'print-quality',
        'sides'],
                                 'job-sheets-default': ('none', 'none'),
                                 'job-sheets-supported': ['none',
                                                          'classified',
                                                          'confidential',
                                                          'form',
                                                          'secret',
                                                          'standard',
                                                          'topsecret',
                                                          'unclassified'],
                                 'jpeg-k-octets-supported': (0, 2736876),
                                 'jpeg-x-dimension-supported': (0, 65535),
                                 'jpeg-y-dimension-supported': (1, 65535),
                                 'marker-change-time': 0,
                                 'media-bottom-margin-supported': [529],
                                 'media-col-default': '(unknown IPP value '
                                                      'tag 0x34)',
                                 'media-col-supported': ['media-bottom-margin',
                                                         'media-left-margin',
                                                         'media-right-margin',
                                                         'media-size',
                                                         'media-source',
                                                         'media-top-margin',
                                                         'media-type'],
                                 'media-default': 'iso_a4_210x297mm',
                                 'media-left-margin-supported': [379],
                                 'media-right-margin-supported': [379],
                                 'media-size-supported': ['(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)',
                                                          '(unknown IPP '
                                                          'value tag 0x34)'],
                                 'media-source-supported': ['auto', 'manual'],
                                 'media-supported': ['na_letter_8.5x11in',
                                                     'na_legal_8.5x14in',
                                                     'iso_a4_210x297mm',
                                                     'na_executive_7.25x10.5in',
                                                     'oe_ledger_17x11in',
                                                     'iso_a3_297x420mm',
                                                     'na_number-10_4.125x9.5in',
                                                     'om_monarch_98.43x190.5mm',
                                                     'om_c-5_161.93x228.95mm',
                                                     'om_dl_110.07x220.13mm',
                                                     'jis_b4_257x364mm',
                                                     'jis_b5_182x257mm',
                                                     'om_env-isob-5_176.04x250.12mm',
                                                     'jpn_hagaki_100x148mm',
                                                     'jpn_oufuku_148x200mm',
                                                     'iso_a5_148x210mm',
                                                     'iso_a6_105x148mm',
                                                     'jis_b6_128x182mm',
                                                     'om_c-6_113.95x161.93mm',
                                                     'om_folio_210x330mm',
                                                     'na_personal_3.625x6.5in',
                                                     'na_number-9_3.875x8.875in',
                                                     'na_oficio_8.5x13.4in'],
                                 'media-top-margin-supported': [529],
                                 'media-type-supported': ['off',
                                                          'normal',
                                                          'thick',
                                                          'thin',
                                                          'bond',
                                                          'ohp',
                                                          'cardstock',
                                                          'label',
                                                          'used',
                                                          'color',
                                                          'envelope',
                                                          'cotton',
                                                          'stationery-recycled',
                                                          'archive'],
                                 'multiple-document-handling-supported': ['separate-documents-uncollated-copies',
        'separate-documents-collated-copies'],
                                 'multiple-document-jobs-supported': True,
                                 'multiple-operation-time-out': 300,
                                 'natural-language-configured': 'en-us',
                                 'notify-attributes-supported': ['printer-state-change-time',
        'notify-lease-expiration-time',
        'notify-subscriber-user-name'],
                                 'notify-events-default': ['job-completed'],
                                 'notify-events-supported': ['job-completed',
                                                             'job-config-changed',
                                                             'job-created',
                                                             'job-progress',
                                                             'job-state-changed',
                                                             'job-stopped',
                                                             'printer-added',
                                                             'printer-changed',
                                                             'printer-config-changed',
                                                             'printer-deleted',
                                                             'printer-finishings-changed',
                                                             'printer-media-changed',
                                                             'printer-modified',
                                                             'printer-restarted',
                                                             'printer-shutdown',
                                                             'printer-state-changed',
                                                             'printer-stopped',
                                                             'server-audit',
                                                             'server-restarted',
                                                             'server-started',
                                                             'server-stopped'],
                                 'notify-lease-duration-default': 86400,
                                 'notify-lease-duration-supported': (0,
        2147483647),
                                 'notify-max-events-supported': [100],
                                 'notify-pull-method-supported': ['ippget'],
                                 'notify-schemes-supported': ['dbus',
                                                              'mailto',
                                                              'rss'],
                                 'number-up-default': 1,
                                 'number-up-supported': [1, 2, 4, 6, 9, 16],
                                 'operations-supported': [2,
                                                          4,
                                                          5,
                                                          6,
                                                          8,
                                                          9,
                                                          10,
                                                          11,
                                                          12,
                                                          13,
                                                          16,
                                                          17,
                                                          18,
                                                          19,
                                                          20,
                                                          21,
                                                          22,
                                                          23,
                                                          24,
                                                          25,
                                                          26,
« Last Edit: 17. September 2015, 23:31:14 by paulus »
Offline paulus
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #23 on: 17. September 2015, 23:28:03 »
Hi paulus!
Sounds great what you have achieved! :)Be aware that when you reboot a live environment you will always start from zero. So in order to see if your settings are permanent you'd at least have to install to a virual harddrive in virtualbox...
Isn't that an insecure situation to judge, as everything in VB is sustained by the VB guest additions? So also the printer driver will be provided by VB, so that doesn't render a trustworthy picture of this situation, am I right with that?
paulus
