Author Topic: introducing oblogout-manjaro  (Read 13385 times)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
Re: introducing oblogout-manjaro
« Reply #30 on: 26. September 2015, 15:00:25 »
All my hard work to make it look perfect... Just *poof* gone after the update  :'(
I just see that my install script in the last version was crap ::) :P
Will fix it for the next update.
I hope you can still reproduce those changes... ???
Stay tuned! ...  :-[
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline Photon
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Xfce+Compiz
  • GPU Card: Intel 4500MHD
« Reply #31 on: 26. September 2015, 15:06:18 »
Maybe not exactly with the panel, sorry for the misleading information. The darkened area is not filling the screen, on the bottom there is a non-darkened strip: https://dl.dropboxusercontent.com/1/view/at7w0z5pzxfjjfr/Apps/Shutter/Workspace%201_005.png I thought that the strip height is exactly that of the panel on the top of the screen, but now I tried changing the panel height and running oblogout afterwards with no change to the strip height.
Offline lightbeam
  • Sr. Mitglied
  • Branch: Stable as in: "Whoa, Nelly!"
  • Desktop: Wide Openbox
  • GPU Card: AMD Radeon Xpress 200 Series - Methuselah Edition
  • GPU driver: Free as in Lunch
  • Kernel: Linux44, i686
« Reply #32 on: 26. September 2015, 15:17:08 »
Oberon, is the blurlock feature available with this?  I'm not sure how to activate it.
Also, I have Compton handling transparency for inactive windows.  Er, windows become transparent when inactive, but then the lockscreen - with HTML color or PNG/JPEG - also becomes transparent, which of course means I see both the desktop and the lockscreen.  This is why I'd prefer to just use the blurlock feature if I could.
Thanks!
I make you look good. 8)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #33 on: 26. September 2015, 16:19:31 »
@Photon: It does indeed look like there is somehow a reserved space. Are you sure you don't have any of the panel settings interfering?
What happens if you move the panel to the bottom. Or check if you have any leftover extra panels maybe??
@lightbeam: This is the problem with blurlock: What it does is, it takes a screenshot at the moment you launch the script, then blurs it and uses that for i3lock. That will result in a blurred oblogout-screen - not exactly what we want, is it? ;)
I wonder if the script could be altered in a way to first close the oblogout window and then take the screenshot ???
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #34 on: 26. September 2015, 16:56:58 »
@lightbeam: I think I found a way ;D
I'm hatching it now ... ::)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #35 on: 26. September 2015, 17:14:42 »
Not quite there ... maybe someone can help with this:
From oblogout.conf I am calling
Code: [Select]
[commands]
lock = blurlock
which looks like this
Code: [Select]
#!/bin/bash
# /usr/bin/blurlock
pkill oblogout &&
scrot /tmp/screenshot.png
convert /tmp/screenshot.png -blur 0x5 /tmp/screenshotblur.png
i3lock -i /tmp/screenshotblur.png
(requires scrot and imagemagick)
Now what happens is this: The Oblogout window closes BUT then the screen is locked with the blurred screenshot of the desktop with Oblogout still in the picture...  :o How is this possible?
« Last Edit: 26. September 2015, 17:34:25 by oberon »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #36 on: 26. September 2015, 17:26:59 »
I guess the problem is that blurlock in this scenario is a child process of oblogout?
Is there a better / proper way to close that window?
The source for oblogout is here... ::) https://github.com/Cloudef/oblogout-fork/blob/master/oblogout/__init__.py
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #37 on: 26. September 2015, 17:28:17 »
@lightbeam: If you can live with oblogout still visible in the blurlock the solution is quite simple:
create the above blurlock script (executable of course) whithout that 'pkill oblogout' line and edit oblogout.conf as mentioned.
« Last Edit: 27. September 2015, 02:17:00 by oberon »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #38 on: 26. September 2015, 17:30:53 »
I got it!
You have to take the screenshot BEFORE Oblogout launches!
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #39 on: 26. September 2015, 17:39:24 »
So let say you launch oblogout by keybinding. Let that keybinding call a script instead:
Code: [Select]
#!/bin/bash
#/usr/bin/oblogout_blur
scrot /tmp/screenshot.png &&
oblogout
now in /etc/oblogout.conf you still need
Code: [Select]
[commands]
lock = blurlock
and that one will look like this now
Code: [Select]
#!/bin/bash
# /usr/bin/blurlock
Leaving the 'convert...' line in blurlock will save the conversion time in case you are going to use an oblogout function that does not involve screenlocking, like restart or shutdown...
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #40 on: 26. September 2015, 18:14:44 »
I will package a new version of oblogout-manjaro with a proper upgrade-script and include the blurlock later tonight.
Actually I wanted to do that from the beginning but now I finally know the how!...  8) ;D
« Last Edit: 26. September 2015, 18:40:17 by oberon »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #41 on: 26. September 2015, 23:51:32 »
Ok. oblogout-manjaro 20150927-1 is available in unstable and testing now  :D
If you call it with
Code: [Select]
oblogout it will just lock with a black screen or whatever colour or picture (only .png is allowed!) you set in /usr/bin/ob_blurlock
If you want to use it with blurlock you have to invoke it with
Code: [Select]
oblogout_blur
And this is also fixed:
Quote
==> existing oblogout.conf will be saved as /etc/oblogout.conf.bak
Sorry again for that, oleerik!  :-[
8) Enjoy your locking!! ;D
« Last Edit: 27. September 2015, 02:47:45 by oberon »
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
« Reply #42 on: 27. September 2015, 00:06:01 »
 :-[ I'm gonna be a killjoy here, having the options in the menu is way more efficient. I recall using oblogout but on old hardware it takes time to start whereas menu options were instantanoius. Yeah I get that people like big shiny buttons, maybe I'm just weird  ;D
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #43 on: 27. September 2015, 00:18:30 »
Sure! I completely understand! In i3 I lock/suspend/... or whatever simply with <mod>+0 plus the respective letter ^-^
We just all have our shiny days sometimes ...  8)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #44 on: 27. September 2015, 02:15:48 »
Oh, or did you change the icons?? Sounds like... That would not be a good idea without backing up your customizations...  :o :P
