I was wondering about the buttons being rather big. I think it is the same size with all oblogout-themes, though.
You could of course either remove entries in oblogout.conf (are you using all of them? switch-user? hibernate?)
Or you could shrink the icons in
/usr/share/themes/OutMokThis is btw the folder you could just copy if you want to keep the theme only
and then specify OutMok in oblogout.
Well, but then you can anyway use oblogout-manjaro right away, no?
