Author Topic: Budgie desktop error reporting  (Read 1271 times)
Offline AJReissig
  • Neuling
  • Skill: Novice
« on: 30. August 2015, 03:05:45 »
I've been playing around with the Budgie community edition for the past few days...great distro!  One thing I've encountered is on boot I get the following error message:
Configured directory for incoming files does not exist  Please make sure that directory /home/manjaro/Downloads exists or configure it with blueman-services
The error message is easily dismissed, and only appears at boot.  I'm not sure how to solve the issue, though.  Also, I'd like to report the bug, but I'm unsure how to report it since this is a community edition.  Any help would be welcome.
Thanks!
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: Budgie desktop error reporting
« Reply #1 on: 30. August 2015, 09:58:03 »
What language did you boot with?
@Ste74: did you hardcode some? This folder is not always called Download.
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #2 on: 30. August 2015, 17:09:32 »
hi; its mayby in the dconf ?
Code: [Select]
sudo pacman -S dconf-editor
if you dont have the editor installed.
then go to  : org -> blueman -> transfers >
there must be a shared path, which path is it ?
Dutch go the dutch site :)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #3 on: 30. August 2015, 18:44:03 »
Yep , thank you Ringo , dconf-editor is default program in budgie profile and ... yep in the key is marked Download folder ..
I not know why because not configurated then during the test to build the iso .. delete the value and upload the corrected dconf ...
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
