Author Topic: manjaro-fluxbox 0.8.13.1  (Read 14617 times)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
Re: manjaro-fluxbox 0.8.13.1
« Reply #60 on: 11. September 2015, 01:10:53 »
Ah, good thinking, gohlip, yes!
That makes sense.
But anyway the menu und theme are determined by files in ~/.fluxbox - so it is still strange...
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
« Reply #61 on: 11. September 2015, 01:13:27 »
He had firefox installed in previous xfce. That remains in new fluxxbox install because he reused /home.
Also if I had to install a Manjaro over a previous Manjaro partition (/), I had to reformat that partition otherwise even previous kernels are maintained even if they are not in new installation. Yes, its wierd. So his firefox app previously installed is there. This results even if I ask installer to format the partition. I needed to format that partition before starting new installation.
We really need to look into Manjaro installers. Had mentioned this before and I do not like to repeat as it may appear more of a criticism than a report. Some people take 'complaints' badly. (I take compliments badly...   ::)  not used to it  ;D )
« Last Edit: 11. September 2015, 01:17:49 by gohlip »
Life is a sexually transmitted disease with a 100% mortality rate.
Offline yellowbosch
  • Neuling
« Reply #62 on: 11. September 2015, 01:19:18 »
That makes sense.
exactly, since I had firefox before I think it could show up, but conserning fluxbox...not even the background was showing...
so I have to back up my home partition and do a new install in the whole hdd...maybe later!
thanks for the feedback!
Offline Belemrys
  • Jr. Mitglied
  • I love Manjaro i3!
  • Branch: Unstable
  • Desktop: i3
  • GPU Card: ATI Radeon r9 270
  • GPU driver: MESA
  • Kernel: 4.1
  • Skill: Novice
« Reply #63 on: 11. September 2015, 01:36:54 »
Yeah, I had issues with the fluxbox menu not showing programs I installed like LibreOffice. I installed i3 manjaro by Oberon and am loving it...although dmenu isnt showing my new installs either...I have to use the dmenu-desktop to find libreoffice and gimp :/
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #64 on: 11. September 2015, 01:44:04 »
What happens if in dmenu you just type libreoffice and hit enter (just ignore if it's not showing up). Is it listed the next time?
Here I don't have that problem. libreoffice is right there immediately.
Do you have the latest dmenu-manjaro installed?
In Fluxbox that's normal. The menu is not dynamic. You will have to either update it manually in ~/.fluxbox/menu or use a utility like menumaker.
« Last Edit: 11. September 2015, 01:46:16 by oberon »
Offline dbVU
  • Jr. Mitglied
  • Branch: stable
  • Desktop: XFCE openrc
  • GPU Card: Nvidia 7800GS
  • GPU driver: free
  • Kernel: 4.4.6-1-MANJARO i686
  • Skill: Novice
« Reply #65 on: 11. September 2015, 13:39:09 »
Oberon,
Great job with this release! I normally run Xfce/Openbox openrc release your, openrc Fluxbox is very attaractive
and runs great. Thank you for the effort.
db
Offline yellowbosch
  • Neuling
« Reply #66 on: 11. September 2015, 13:52:56 »
hi all,
finally last night installed systemd fluxbox!
just had to make another partition to create a scratch home partition, and voilá!
everything looks awesome!
just a question, how/where do I invert the scrooling of my mouse?
thanks,
Offline oleerik
  • Vollwertiges Mitglied
  • Just a little duck
  • Branch: stable
  • Desktop: Fluxbox
  • GPU Card: Nvidia GTX780ti
  • GPU driver: non-free
  • Kernel: linux41-x64
« Reply #67 on: 11. September 2015, 13:58:06 »
According to a random google search:
The wheeling direction parameter is located in ./fluxbox/init. So open it with your favourite text editor and modify the following value:
session.screen0.reversewheeling:    true
I try to help, please don't shoot me if I'm wrong!
Oberon rocks | github
Please remember to mark your topic as solved if it is  C:-)
Offline lightbeam
  • Sr. Mitglied
  • Branch: Stable as in: "Whoa, Nelly!"
  • Desktop: Wide Openbox
  • GPU Card: AMD Radeon Xpress 200 Series - Methuselah Edition
  • GPU driver: Free as in Lunch
  • Kernel: Linux44, i686
« Reply #68 on: 11. September 2015, 15:56:36 »
Really?!  Fluxbox doesn't benefit from menu system similar to Openbox/Obmenu?   :o
I make you look good. 8)
Offline yellowbosch
  • Neuling
« Reply #69 on: 11. September 2015, 16:05:07 »
thanks for the help, but I tried and nothing...looked for the man page of fluxbox and didn't see that option...
thanks,
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #70 on: 11. September 2015, 16:26:40 »
thanks,
Have you restarted the session? The init file is only processed on login or when you click on "restart" in the fluxbox menu.
Have you tried both values, true and false?
I'm not at my flux-computer right now... will try it out later :)
Stay tuned! ;)
Offline oleerik
  • Branch: stable
  • Desktop: Fluxbox
« Reply #71 on: 11. September 2015, 16:30:24 »
Another possibility:
Code: [Select]
xmodmap -e “pointer = 1 2 3 5 4 6 7 8 9 10 11 12”
As you can see 5 and 4 has switched spots - which should make scrolling reversed.
Offline yellowbosch
  • Neuling
« Reply #72 on: 11. September 2015, 16:36:29 »
Code: [Select]
sorry, but should I write this on terminal?
it gave me a number of errors...
Offline oleerik
  • Branch: stable
  • Desktop: Fluxbox
« Reply #73 on: 11. September 2015, 16:48:22 »
Code: [Select]
xmodmap -e "pointer = 1 2 3 5 4 6 7 8 9 10 11 12"
Yes, execute that in your terminal.
 Try it again, I think the preview one had some problems.
Works fine for me! :)
Offline yellowbosch
  • Neuling
« Reply #74 on: 11. September 2015, 16:51:33 »
AWESOME!
thanks!
