Author Topic: manjaro-fluxbox 0.8.13.1  (Read 14526 times)
Offline kike1965
  • Jr. Mitglied
  • K|Ke
    • Manjaro Linux Hispano
  • Branch: Stable
  • Desktop: Fluxbox
  • GPU Card: nVidia GT640M
  • GPU driver: free
  • Kernel: linux41-x64
  • Skill: Intermediate
Re: manjaro-fluxbox 0.8.13.1
« Reply #15 on: 01. September 2015, 02:42:05 »
Un gran trabajo oberon, me parece fantástico todo el diseño y cuidado en las diferentes configuraciones de Fluxbox. Realmente me gustó mucho ver nuevamente renacer una edición de Manjaro Fluxbox.
Un abrazo y reitero mis felicitaciones por esta excelente edición.  :)
K|Ke
Manjaro Linux Comunidad Hispana
"Las personas nacen libres e iguales en dignidad y derechos"
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #16 on: 01. September 2015, 02:50:09 »
Thank you very much for your kind words, Kike! :)
Fluxbox is really a great WM and it's fun to play around with the configuration...  8)
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline kike1965
  • Jr. Mitglied
  • K|Ke
  • Branch: Stable
  • Desktop: Fluxbox
  • GPU driver: free
« Reply #17 on: 01. September 2015, 02:55:38 »
You're absolutely right oberon, Fluxbox is simple to set up, light and do what you have to do, I use it in Manjaro, Arch and FreeBSD and everything is perfect, I only need to install it on Windows  ;D ;D ;D ;D ;D ;D
best regards  ;)
K|Ke
Offline oleerik
  • Vollwertiges Mitglied
  • Just a little duck
  • Branch: stable
  • Desktop: Fluxbox
  • GPU Card: Nvidia GTX780ti
  • GPU driver: non-free
« Reply #18 on: 01. September 2015, 13:02:25 »
The thread regarding EFI bootloader issues has been moved to https://forum.manjaro.org/index.php?topic=25744.0.
Just posting this back here in case more people stumble upon this issue with manjaro-fluxbox.
I try to help, please don't shoot me if I'm wrong!
Oberon rocks | github
Please remember to mark your topic as solved if it is  C:-)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #19 on: 01. September 2015, 14:12:49 »
Great! Good luck with that one! ;D ;D ;D
Offline lightbeam
  • Sr. Mitglied
  • Branch: Stable as in: "Whoa, Nelly!"
  • Desktop: Wide Openbox
  • GPU Card: AMD Radeon Xpress 200 Series - Methuselah Edition
  • GPU driver: Free as in Lunch
  • Kernel: Linux44, i686
« Reply #20 on: 02. September 2015, 05:28:25 »
So, what about the "oblogout-manjaro" package?  When will it be available in the stable repos?  Today, I almost installed i3lock to replace xlockmore, so I'm very interested in this!
I make you look good. 8)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #21 on: 02. September 2015, 08:56:22 »
It will arrive with the next stable update on Monday. But you can of course install it already from the unstable repo with a temporary
Code: [Select]
sudo pacman-mirrors -g -b unstable && sudo pacman -Sy
sudo pacman -S oblogout-manjaro
Just remember to
Code: [Select]
sudo pacman-mirrors -g && sudo pacman -Syagain afterwards to keep the rest of your system in stable... :) 8)
Offline oleerik
  • Branch: stable
  • Desktop: Fluxbox
« Reply #22 on: 02. September 2015, 14:15:30 »
Hey, oberon!
I don't know how to contribute to the project (other than poking you on the forums..)
Because nitrogen is used by default the default theme should (in my opinion) be slightly changed:
Code: [Select]
/usr/share/fluxbox/styles/manjaro-flux/theme.cfg
Comment out:
background:
background.color:
background.colorTo:
This is based on https://wiki.archlinux.org/index.php/Fluxbox#Nitrogen
Quote
You may find that if you restart Fluxbox, the wallpaper set by the currently selected theme overwrites the wallpaper set by Nitrogen. To fix this, edit the theme.cfg file of the theme you are using and comment out or delete the following options:
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #23 on: 02. September 2015, 14:23:13 »
Thank you oleerik!
That's perfectly fine. Please keep poking! ;D
Good point with the packground!
Package update is on the way :)
Offline oleerik
  • Branch: stable
  • Desktop: Fluxbox
« Reply #24 on: 02. September 2015, 14:37:06 »
Thank you oleerik!
For the future: Could I, theoretically, push this change to github myself?
I'm guessing I could... I've just never used github for anything but personal project so far. Sorry if it's a dumb question :)
« Last Edit: 02. September 2015, 14:43:44 by oleerik »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #25 on: 02. September 2015, 15:34:31 »
You can always simply fork a repo and open a pull request with your suggested change, sure! :)
Offline lightbeam
  • Sr. Mitglied
« Reply #26 on: 02. September 2015, 18:39:23 »
Code: [Select]
Just remember to
Code: [Select]
Thanks!  :)  But do I need to edit any dotfiles to get it to work?  Or will it automagically work by itself?  Does it come with a preference pane for the menu?
Sorry about all the hand holding!   :P
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #27 on: 02. September 2015, 19:34:58 »
Editing not necessarily needed, just you might want to comment out one or the other entry like maybe switch user or hibernate in /etc/oblogout.conf :)
Offline lightbeam
  • Sr. Mitglied
« Reply #28 on: 02. September 2015, 20:24:52 »
Thanks, Oberon! :)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #29 on: 02. September 2015, 20:46:59 »
Looks like we have a happy new manjaro fluxbox user here ;D
https://www.youtube.com/watch?v=wGLtOtP1PU0
