Author Topic: [test] Manjaro Budgie Desktop RC1 minimal ISO  (Read 7922 times)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
Re: [test] Manjaro Budgie Desktop RC1 minimal ISO
« Reply #15 on: 25. August 2015, 01:55:20 »
eugen-b
Well the only way I was able to download an official PKGBUILD for Maxthon was cheating by using the WayBack Machine in Internet Archive.org.
It was kinda a pain doing makepkg/building and install all manually. My brain doesn't work the way it used to (Dam brain surgery has turned my world upside down).
Yaourt didn't find maxthon. Google only had a cache of maxthon in AUR.
Who maintains Arch AUR Packages?  &  is there a way to make request to have maxthon-browser-stable reinstated in AUR Package Repositories.
Help me Obi One Kenobi
Sounds too complicated for me to understand. Simply go to their site, click on Linux tab and download .tgz (must be source code) then do with it s.th., compiling or whatever. You could need to install development packages from Manjaro if you don't have them from the ISO. Here are direct links if you don't find. There are also .deb and .rpm packages but
http://dl.maxthon.com/linux/tars/maxthon-browser-stable-1.0.5.3-x86_64.tgz
http://dl.maxthon.com/linux/tars/maxthon-browser-stable-1.0.5.3-i386.tgz
« Last Edit: 25. August 2015, 02:02:49 by eugen-b »
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #16 on: 25. August 2015, 11:25:52 »
project aur3 broken
backup aur3 for maxthon
http://pkgbuild.com/git/aur-mirror.git/tree/maxthon-browser
You can use it for build ..
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #17 on: 25. August 2015, 22:06:50 »
Hi guys , modified the first post  ;)
uploading now RC2 both 32bit and 64bit . Not changes only the pkg updated at the last stable release and added the gui for manage your internet connection  :)
i think ready tomorrow  ;)
Canale IRC italiano
#manjaro-it
Offline allen832008
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #18 on: 26. August 2015, 00:42:50 »
Great job on this distro! Unfortunately, I am only seeing the i686 version of the RC2 on the download link?
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #19 on: 26. August 2015, 08:01:00 »
I have a bad speed internet Connection .. at this moment 3 hours to finish.    :)
Canale IRC italiano
#manjaro-it
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #20 on: 26. August 2015, 22:50:21 »
downloading Budgie
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #21 on: 27. August 2015, 00:07:15 »
After a very short test I would say that Budgie desktop is great!!
I'm not ironical, but I think its greatness is that it absolutely recomandable for linux beginners. It looks pretty out of the box, but you cannot customize much beyond predefined 2-3 options. That means you cannot break much which is very good for beginners! ;) :-X
But if you come to it from Xfce you will be a bit disappointed. You cannot make the panel and window decoration transparent, you cannot move the panel to the left side for example. At least not from the GUI, maybe there are config files for that. Is it possible to add panel applets from Gnome or Cinnamon or Mate? Can you create custom applications launchers? With .desktop files I think yes, but they will only appear in the menu, because there seems to be no way to put launchers on the panel. Edit: There is the option "Pin to panel" when an application is active and shown on the panel. But the icon is pinned at taskbar and cannot be moved on the panel. If you close the application and open it anew from the pinned icon a new icon appears which is against intuition. But wait, when you close the window for a second time an open it anew, a second icon doesn't appear, it works as known from DockbarX panel plugin for example.
I found another small glitch with panel appletts: If you add a new applet and try to move it, it go to the left more than one step and it takes to move it vack and forth until its place place on the panel corresponds with its place in the list.
It is lightweight and responsive even on a usb stick.
Overall, a good thing, but seems to be more for the beginners target group. Or I'm wrong about this point you can customize much with config files. Then it is still good for beginners, or those who like a nice desktop out of the box, but not only for them.
Some updates: The config files in home are as minimal as the options in the GUI. (What else to expect? ;) ) It wasn't obvious how to get to the /root/ folders because the file manager doesn't have an "up" button. (It is a bit cartoon like, reminds me of all those cloud app and appears not like a solid desktop programm.) It doesn't provide an editable adress bar. I found a "Computer" button on the left side of the file manager and came to the root folder. I looked at /usr/share/applications and found a very interesting app - Widget Factory. Now I can start creating widgets which I miss, yahoo!!  ^-^
« Last Edit: 27. August 2015, 00:42:57 by eugen-b »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #22 on: 02. September 2015, 21:32:18 »
https://www.youtube.com/watch?v=TMvcxXKKn_Y :)  8)
Congratulations Stefano! Great work!!  ^-^
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #23 on: 02. September 2015, 22:00:23 »
Hi oberon .. thank you .. but also your light Iso is really nice . Fluxbox in a italian forum where i am moderator is great   8) ;)
now try to build an complete iso's ..
Canale IRC italiano
#manjaro-it
Offline BorisBalkan
  • Neuling
  • Branch: Stable
  • Desktop: Mate - Budgie
  • GPU Card: Ati Mobility Radeon HD 5650
  • GPU driver: Free driver
  • Kernel: 4.2.3-1-x64
« Reply #24 on: 06. September 2015, 19:13:09 »
I would to say thanks to this beautiful ISO because it's FANTASTIC!!
I use budgie version every day and i can say it is stable and responsive, on my notebook it's all ok..I have two hd and i was usually use mate, now im am use this iso from the RC 2 and everything is ok...
I have temperature problem on my notebook and i resolve it with removing tracker, before my laptop was at about 45/50 °C and now it is less than 40°C.
I suggest to remove tracker and add the Arc Theme Gtk because i think it's beautiful on Budgie...
Here is my desktop
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #25 on: 06. September 2015, 19:27:06 »
Thank you BorisBalkan .. my pleasure  :D
Canale IRC italiano
#manjaro-it
Offline BorisBalkan
  • Neuling
  • Branch: Stable
« Reply #26 on: 06. September 2015, 21:15:48 »
I have a question, if is it possible to change windows font because i try with Gnome Tweak but nothing change...it's a little problem but i did't know how to change size and type of font in Budgie Windows....
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #27 on: 06. September 2015, 22:42:06 »
I think is a bug .. budgie is in development not in stable release .. yes is stable but not function is complete i think , see this report
https://solus-project.com/forums/viewtopic.php?t=216
and this
https://bugs.solus-project.com/buglist.cgi?quicksearch=font&list_id=989
Canale IRC italiano
#manjaro-it
Offline BorisBalkan
  • Neuling
  • Branch: Stable
« Reply #28 on: 06. September 2015, 23:17:37 »
I resolve this, i watch your links and i found a solution with my curiosity and Dconf-editor...
For use personal font in Budgie Windows use dconf o gsettings and go to "org gnome desktop wm preferences"
Here you can choose your font in "titlebar-font" and uncheck "titlebar-uses-system-font" et VOILA!!!  ;D
I think is only necessary to uncheck "titlebar-uses-system-font" and after you can change font normally with gnome tweak but i'm not sure....
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #29 on: 07. September 2015, 07:43:31 »
Thank you for share solution... unceck this Key in Next iso..
Grazie  ;)
Canale IRC italiano
#manjaro-it
