Author Topic: [dev] New Pantheon Iso 2015.08 now for x86_64 and i686 system  (Read 15717 times)
Offline AndrewTim
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
Re: [dev] New Pantheon Iso 2015.08 now for x86_64 and i686 system
« Reply #75 on: 06. September 2015, 21:22:46 »
Hey Ste74. Is it only mine problem with "Aplications" button? First click it works, second click doesnt work, third it does, fourth it doesnt and so on
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #76 on: 06. September 2015, 22:13:04 »
Yep , .. is equal .. if anyone have idea because ... gala is build with mutter 3.14 for full control window .. no idea if is the problem ..  :(
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #77 on: 07. September 2015, 22:31:32 »
Guys , if you want use geary-plank ( integration in plank for notification ) you can install the pkg geary-plank-bzr .. unfortunally not remember if i have release a new version  :P in any case you can reinstall geary-plank-bzr ..  ::) ::) ::) ::)
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #78 on: 08. September 2015, 22:02:46 »
Add new pkg to repo .. geary-plank-manjaro .. this pkg is based on geary stable version and provide integration on plank for bullet notification .. if you want test it  ^-^
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #79 on: 20. September 2015, 20:54:16 »
Hi guys , i have finished to rebuild a pkg and upload them in my pantheonrepo  :)
well now the wingpanel-rewrite-x11-bzr-manjaro is instead of wingpanel-bzr-manjaro (according with Alucryd repo ; thank you at alucryd and your hard work) and rewrite all pkg related to new pkg .. now wingpanel-indicator-ayatana is provide on repo alucryd so to perform this upgrade you need to remove wingpanel-inadicator-ayatana and reinstall it after upgrade ( remember now you can choice it from repo alucryd )
Greetings
Ste
Canale IRC italiano
#manjaro-it
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
  • Skill: Intermediate
« Reply #80 on: 05. January 2016, 13:31:35 »
Hi everyone, just sayng gala now works well and I was thinking create a new iso
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #81 on: 05. January 2016, 14:49:20 »
Hi lucasnota  :) :)
Alucryd's unofficial repo arch seem freeze not update after the 10/10/2015 ... only theme pkg update .. you have new notice ?
Canale IRC italiano
#manjaro-it
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
« Reply #82 on: 05. January 2016, 16:12:04 »
I'm updating and fixing pkg-builds  just wingpanel don't turn black, the rest are working great
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #83 on: 05. January 2016, 17:22:55 »
Ok .. try now to build a new pkg's to update my repo ..    ;)  :)
Canale IRC italiano
#manjaro-it
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
« Reply #84 on: 05. January 2016, 19:50:20 »
Ste something are strange like alucryd wingpanel are working but I use the same pkgbuild and source dosen't work well
I will list what are working and what not
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #85 on: 06. January 2016, 10:07:00 »
I think problem in upstream, after wingpanel r(?) of alucryd , wingpanel not work properly.
Canale IRC italiano
#manjaro-it
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
« Reply #86 on: 06. January 2016, 11:27:29 »
The wingpanel from alucyd repo are working in rev93 but i compile with the same pkgbuilds and rev but not work the same way, sorry for bad english
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #87 on: 06. January 2016, 22:36:25 »
i try to build an iso up to date .. only the wingpanel r93 work .. try this my workaround .. copy this in
https://github.com/Ste74/pantupdate/blob/master/org.pantheon.desktop.gala.gschema.xml
 /usr/share/glib-2.0/schemas/
glib-compile-schemas /usr/share/glib-2.0/schemas/
Canale IRC italiano
#manjaro-it
