Author Topic: Manual intervent on Pantheon  (Read 1490 times)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« on: 04. August 2015, 22:32:54 »
For the next dev release of Pantheon De on Manjaro i have modified some pkg from alucryd repo and upload on server ..
the pkg repo are here :
https://github.com/Ste74/Pkg-Dev
the binary pkg are here :
http://download.tuxfamily.org/repoarch/pantheonrepo/
To uniform the installation needed add this in our pacman.conf ; to perform it open pacman.conf and at the end of file add this line:
Code: [Select]
[pantheonrepo]
SigLevel = Optional TrustAll
Server = http://download.tuxfamily.org/repoarch/pantheonrepo/$arch
if you want to use wingpanel please install this pkg
Code: [Select]
mutter-pantheon-manjaro
gala-bzr-manjaro
pantheon-session-bzr-manjaro
slingshot-launcher-bzr-manjaro
wingpanel-rewrite-x11-bzr-manjaro
wingpanel-indicator-notifications-bzr-manjaro
wingpanel-indicator-ayatana-bzr
wingpanel-indicator-datetime-bzr-manjaro
wingpanel-indicator-network-bzr-manjaro
wingpanel-indicator-power-bzr-manjaro
wingpanel-indicator-session-bzr-manjaro
wingpanel-indicator-sound-bzr-manjaro
wingpanel-indicator-launcher-bzr-manjaro
pantheon-default-settings-bzr
optionally remove this pkgs
Code: [Select]
indicator-session-systemd #from Aur for patch indicator session pantheon
indicator-datetime
indicator-power #from Aur
indicator-sound
mutter-pantheon-manjaro replace mutter-manjaro-pantheon
gala-bzr-manjaro replace manjaro-gala-bzr
pantheon-session-bzr-manjaro replace pantheon-session-manjaro-bzr
wingpanel-rewrite-x11-bzr-manjaro modified to work to pkg patched
greetings
Ste
« Last Edit: 04. August 2015, 22:43:19 by Ste74 »
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
