Author Topic: [Bumblebee] Issues on Nvidia bumblebeed machines  (Read 9084 times)
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« on: 05. July 2015, 21:22:11 »
hi,
There seems here and there some nvidia bumblebeed machines. i will try to help to solve this issues but it comes back here and there, i find it very comeback to much. Help to bann this issue...
it goes like this threat : https://bbs.archlinux.org/viewtopic.php?id=185865
in other manjaro threats seems so different. find it weird. had someoine tried with this solution
https://wiki.archlinux.org/index.php/Bumblebee#systemd-logind:_failed_to_get_session:_PID_XXX_does_not_belong_to_any_known_session
but doesnt seems to work.
if you got this issue.
please give some info. like example :
cat /var/log/Xorg.0.log | grep -i acpi
systemctl status -l bumblebeed
dmesg logs
kernel use etc etc
output of optirun glxgears , as example
personal i think its something to acpi to bbswitch .. but i dont know :(
« Last Edit: 12. July 2015, 14:30:33 by Kirek »
Dutch go the dutch site :)
Offline huynguyen27
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
Re: [Bumblebee] systemd-logind issues on Nvidia bumblebeed machines
« Reply #1 on: 08. July 2015, 17:23:53 »
cat /var/log/Xorg.0.log | grep -i acpi :
Code: [Select]
[    29.814] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Code: [Select]
● bumblebeed.service - Bumblebee C Daemon
   Loaded: loaded (/usr/lib/systemd/system/bumblebeed.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2015-07-08 22:13:56 UTC; 6h left
 Main PID: 931 (bumblebeed)
   CGroup: /system.slice/bumblebeed.service
           └─931 /usr/bin/bumblebeed
dmesg logs
Code: [Select]
http://www.pastebin.ca/3051249
uname -r
Code: [Select]
3.18.14-1-MANJARO
mhwd -li
Code: [Select]
> Installed PCI configs:
                  NAME               VERSION          FREEDRIVER           TYPE
video-hybrid-intel-nouveau-bumblebee            2015.04.10                true            PCI
p/s : i'm using manjaro on live usb.
« Last Edit: 08. July 2015, 17:31:39 by huynguyen27 »
Offline flipper
  • Sr. Mitglied
  • spic-and-span
  • Branch: testing
  • Desktop: Netrunner KDE 4 -> 5
  • GPU Card: nVidia GT555M/ HD3000
  • GPU driver: non-free bumblebee
  • Kernel: x64 4.5 Manjaro
  • Skill: Novice
« Reply #2 on: 08. July 2015, 17:36:07 »
Maybe not a bad idea to include:
Code: [Select]
inxi -G
Offline huynguyen27
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #3 on: 08. July 2015, 17:39:29 »
Code: [Select]
inxi -G
Sure:
Code: [Select]
Graphics:  Card-1: Intel Broadwell-U Integrated Graphics
           Card-2: NVIDIA GM107M [N16S-GT1-KB-B]
           Display Server: X.Org 1.17.1 driver: intel
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
           GLX Version: 3.0 Mesa 10.5.7
Offline bsima
  • Neuling
  • I'm new. Be nice!
  • Desktop: stumpwm
  • GPU Card: NVIDIA Corporation GK107M [GeForce GT 750M] (rev a1)
  • Kernel: Linux bsima 3.16.7.14-1-MANJARO #1 SMP PREEMPT Tue Jun 30 18:03:14 UTC 2015 x86_64 GNU/Linux
  • Skill: Novice
« Reply #4 on: 11. July 2015, 05:22:44 »
I've been struggling with this one for a while now. Can anyone give me some help? All of the informating asked for above and a bit more is in this gist: https://gist.github.com/bsima/159bd8b260bb3adb4fa1
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • GPU Card: Intel HD4000 + Nvidia 620M / Geforxe GTX 970
  • GPU driver: nonfree
  • Kernel: Latest
  • Skill: Intermediate
« Reply #5 on: 12. July 2015, 14:30:18 »
its not logind, is the xorg server failing to start the secondary gpu.
https://github.com/Bumblebee-Project/Bumblebee/commit/b506a03abab85bc202109f8eeda5c337ee956935
https://github.com/Bumblebee-Project/Bumblebee/issues/600
Every time I had this problem I just fixed it by using a different kernel version, sometimes some kernels are just broken with bumblebee and certain nvidia cards.
Following the post starting the acpid service MAY resolve this (in my laptop I don't need this), but there is a rejected pull request that says that bumblebee has nothing to do with acpid...
Noted: Edited the topic title to remove system-logind, as it is misleading where the issue is.
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #6 on: 12. July 2015, 15:58:46 »
Is also i discussed the topic, its not a fine solution this way hopefull people wil note here more also hoping also for more back data :)
Offline huynguyen27
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #7 on: 12. July 2015, 17:04:39 »
So i'll only have to use another kernel to solve the problem? i've tried switching to 4.11 kernel but it still got the same error.
edit: mhwd isn't able to install the non-free nvidia module automatically by using mhwd -f -a pci 0300 , i have to manually install it then nvidia driver. and now it turns to "Can not load GPU driver" :(.
I'm using nvidia 940M on asus K501LB...
« Last Edit: 12. July 2015, 17:10:48 by huynguyen27 »
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • Kernel: Latest
Re: [Bumblebee] Issues on Nvidia bumblebeed machines
« Reply #8 on: 12. July 2015, 17:30:02 »
Try to enabling acpid "sudo systemctl enable acpid.service && sudo systemctl start acpid.service"
Offline bsima
  • Neuling
  • I'm new. Be nice!
  • Desktop: stumpwm
  • Skill: Novice
« Reply #9 on: 16. July 2015, 15:09:03 »
Code: [Select]
bsima $ systemctl status acpid
● acpid.service - ACPI event daemon
   Loaded: loaded (/usr/lib/systemd/system/acpid.service; enabled; vendor preset: disabled)
   Active: active (running) since Thu 2015-07-16 08:59:13 EDT; 6min ago
     Docs: man:acpid(8)
 Main PID: 677 (acpid)
   CGroup: /system.slice/acpid.service
           └─677 /usr/bin/acpid --foreground --netlink
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
acpid is active for me, but I still can't get it to work. As a last-ditch effort, I'll try rolling back my kernel to 3.10 (currently I'm on 3.16). I'll report back if it works or not.
Offline bsima
  • Neuling
  • I'm new. Be nice!
  • Desktop: stumpwm
  • Skill: Novice
« Reply #10 on: 24. July 2015, 15:25:17 »
Rolling back my kernel *kind of* worked. I'm now able to launch firefox, but `optirun` still isn't working.
Code: [Select]
bsima $ optirun -vv glxgears
[ 2454.757810] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 2454.758044] [INFO]Configured driver: nvidia
[ 2454.758143] [DEBUG]optirun version 3.2.1 starting...
[ 2454.758151] [DEBUG]Active configuration:
[ 2454.758155] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 2454.758159] [DEBUG] X display: :8
[ 2454.758163] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia:/usr/lib32/nvidia
[ 2454.758167] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 2454.758171] [DEBUG] Accel/display bridge: auto
[ 2454.758175] [DEBUG] VGL Compression: proxy
[ 2454.758178] [DEBUG] VGLrun extra options:
[ 2454.758182] [DEBUG] Primus LD Path: /usr/lib/primus:/usr/lib32/primus
[ 2454.758364] [DEBUG]Using auto-detected bridge virtualgl
[ 2459.436034] [INFO]Response: No - error: [XORG] (EE) systemd-logind: failed to get session: PID 3568 does not belong to any known session
[ 2459.436051] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) systemd-logind: failed to get session: PID 3568 does not belong to any known session
[ 2459.436057] [DEBUG]Socket closed.
[ 2459.436072] [ERROR]Aborting because fallback start is disabled.
[ 2459.436077] [DEBUG]Killing all remaining processes.
Additionally, my laptop screen is not being configured properly, but my external HDMI monitor is. So at least I can use my laptop with an external monitor.
Code: [Select]
bsima $ xrandr --output eDP1 --auto
xrandr: Configure crtc 1 failed
I think it's related to this: https://bbs.archlinux.org/viewtopic.php?id=137753
Offline xtinkrr
  • Neuling
  • I'm new. Be nice!
  • GPU Card: nvidia gtx 860m
  • Kernel: linux318-x64
  • Skill: Novice
« Reply #11 on: 13. August 2015, 14:49:08 »
Hello guys,
I'm new to Manjaro and am having a similar issue right now. My Nvidia bumblebeed setup was working fine til last week but when I've logged in yesterday, I had a blank screen. I tried troubleshooting by following this https://wiki.manjaro.org/index.php?title=Configure_NVIDIA_(non-free)_settings_and_load_them_on_Startups but was not successful. I cannot even access the tty* terminals when I install a driver (both free or non-free) using
Code: [Select]
sudo mhwd -a pci nonfree 0300. I have to append "single" in the kernel boot option to have an access to the terminal again as root. Also, after following https://forum.manjaro.org/index.php?topic=3385.0 to enable bumblebeed service at startup. It doesn't seem to work as after rebooting and checking its status using
Code: [Select]
systemctl status bumblebeed, the service is still inactive.
I hope someone could shed some light with these problem.
Offline gatotkoco
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #12 on: 30. September 2015, 09:40:30 »
I'm still have problem about nvidia driver on mylaptop.. I can't running it from setting manajer gui on mymenu.. I'm using xfce desktop manjaro with kernel 4.1.8-1-MANJARO.
Offline davelowp
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #13 on: 19. October 2015, 02:02:05 »
I have more of a question than a solution, with these new nvidia proprietary drivers(version 346 to 355), can the nvidia control center even work for card switching just like Mint or Ubuntu and stop using bumblebee altogether? It works very well on those distros I can even use my HDMI port on my XPS. I'm just looking for an excuse to go back to Manjaro :)
Offline 0xicl33n
  • Neuling
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: intel
  • GPU driver: free
  • Kernel: 4.9.0-1
« Reply #14 on: 02. November 2015, 08:03:38 »
I just updated my manjaro after not using it for quite a while and now i cannot launch steam because it says there is no GLX:
Code: [Select]
[bon@manjaro[~]$inxi -G
Graphics:  Card-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
           Card-2: NVIDIA GM204 [GeForce GTX 970]
           Display Server: X.Org 1.17.4 driver: intel Resolution: 1920x1080@60.00hz
           GLX Renderer: N/A GLX Version: N/A
Oddly enough, optirun works when primus does not. I do not understand why:
Optirun also showed the spheres and ran perfectly.
primus:
Code: [Select]
[bon@manjaro[~]$primusrun glxspheres64
Polygons in scene: 62464 (61 spheres * 1024 polys/spheres)
Xlib:  extension "GLX" missing on display ":0.0".
ERROR in line 630:
Could not obtain RGB visual with requested properties
optirun:
Code: [Select]
[bon@manjaro[~]$optirun glxspheres64
Visual ID of window: 0x20
Context is Direct
OpenGL Renderer: GeForce GTX 970/PCIe/SSE2
203.153734 frames/sec - 226.719567 Mpixels/sec
182.982964 frames/sec - 204.208988 Mpixels/sec
180.911082 frames/sec - 201.896768 Mpixels/sec
181.720356 frames/sec - 202.799917 Mpixels/sec
180.823652 frames/sec - 201.799195 Mpixels/sec
^C[ 1061.441825] [WARN]Received Interrupt signal.
Code: [Select]
[    16.790] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Code: [Select]
   Active: active (running) since Sun 2015-11-01 22:41:45 PST; 13min ago
 Main PID: 510 (bumblebeed)
           └─510 /usr/bin/bumblebeed
Nov 01 22:53:09 manjaro bumblebeed[510]: [  697.712759] [ERROR][XORG] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554811] [WARN][XORG] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554820] [WARN][XORG] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554835] [ERROR][XORG] (EE) systemd-logind: failed to get session: PID 3938 does not belong to any known session
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554837] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554839] [ERROR][XORG] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554842] [WARN][XORG] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554856] [ERROR][XORG] (EE) kbd: <default keyboard>: failed to set us as foreground pgrp (Inappropriate ioctl for device)
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554859] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
Nov 01 22:53:36 manjaro bumblebeed[510]: [  724.554861] [ERROR][XORG] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
dmesg:
http://hastebin.com/vadomidali.vhdl
Code: [Select]
[bon@manjaro[~]$mhwd -li
video-hybrid-intel-nvidia-bumblebee            2015.08.18               false            PCI
Code: [Select]
[bon@manjaro[~]$uname -r
4.1.12-1-MANJARO
Any help would be greatly greatly appreciated...
« Last Edit: 02. November 2015, 08:06:51 by 0xicl33n »
