Author Topic: Bumblebee does not start after update.  (Read 4991 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: Bumblebee does not start after update.
« Reply #30 on: 17. September 2012, 22:28:44 »
Sometimes sensors shows you outputs wrongly. My onboard nvidia-card should have 180 °C which might be the death of it. It's simple displayed wrongly. Mostly it get shown 20°C+ as it really is. 180 °C it can't be right. So maybe you check the net if your mainboard has that issue.
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #31 on: 17. September 2012, 22:44:18 »
I dont think so. because the fan is allways running and I can feel the temperature on laptop. I changed the driver again with  sudo mhwd -i pci video-hybrid-intel-nvidia-bumblebee and now it is about 58-65 Celsius. But optrun glxspheres is still not working and I dont mind it. Low temperature is enough for me at the moment. Optimus Linux support must be go forward may be. :)
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
