Author Topic: Dual monitor, primary display always the left monitor  (Read 9568 times)
Offline doaN
  • Neuling
« on: 27. February 2013, 04:26:15 »
Hi guys!
I've got a dual monitor setup with 2 DVI. I'm running the Manjaro 0.8.4 XFCE and I use the proprietary nvidia driver.
My problem is that I can't set my right monitor as primary. It will be always the left one as primary.
I tried everything in the nvidia panel but nothing seems to affect anything and I tried the xrandr way with the help of ArchWiki but it doesn't work either...
It seems to come from XFCE because I found a similar issue there: https://forum.xfce.org/viewtopic.php?id=6440
Otherwise, congrats for the Manjaro Team for this userfriendly distro based on Arch.
« Last Edit: 27. February 2013, 04:50:12 by doaN »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: Dual monitor, primary display always the left monitor
« Reply #1 on: 27. February 2013, 06:08:46 »
Did you tried this workaround?
Offline doaN
  • Neuling
« Reply #2 on: 28. February 2013, 10:17:04 »
Hello,
I tried this command:
xfconf-query -c xfce4-panel -p /panels/panel-1/output-name
But it returns me:
Property "/panels/panel-1/output-name" does not exist on channel "xfce4-panel".
I saw that my panel's name is Panel 0 so I tried to replace panel-1 by panel-0 but it gave me the same thing above.
EDIT:
After reading the XFCE doc. I found this:
xfconf-query -c xfce4-panel -p /panels -l -v
/panels                           1
/panels/panel-0/autohide          false
/panels/panel-0/background-style  0
/panels/panel-0/length            100
/panels/panel-0/length-adjust     true
/panels/panel-0/mode              0
/panels/panel-0/plugin-ids        <<UNSUPPORTED>>
/panels/panel-0/position          p=6;x=800;y=15
/panels/panel-0/position-locked   true
/panels/panel-0/role              xfce4-panel-12965750720
/panels/panel-0/size              27
But this solution is only about moving the panel. And by the GUI I can do it. But I want all the notifications, new windows open, etc... on my right monitor.
Because I can cheat and move the panel & plank to the right but it will be still "broken".
« Last Edit: 28. February 2013, 10:25:29 by doaN »
Offline frustratedtech
  • Jr. Mitglied
« Reply #3 on: 02. March 2013, 20:26:34 »
I've always noticed that the notifications always show up on the monitor your currently active in.
I like this setup and haven't tried to find another solution.
Offline amboyguy
  • Jr. Mitglied
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: AMD/ATI
  • GPU driver: free
  • Kernel: linux310-x64
  • Skill: Novice
« Reply #4 on: 04. March 2013, 01:35:56 »
Have you tried the settings editor ?
Click on menu->settings->settings editor->displays  Scroll to the monitor you're using and click on the primary variable and edit it. (both monitors)
HP-ENVY-TS-15 Notebook
HP-dv7 Notebook
Offline doaN
  • Neuling
« Reply #5 on: 05. March 2013, 17:48:17 »
Thanks guys for your replies.
amboyguy, I hadn't tried but it didn't work.
After what frustratedtech wrote. I noticed this and I'm ok with it.
For my panel and plank. I just set up the output "manually" in the preferences.
Looking forward about XFCE 4.12 who seems to bring multi monitors support enhancement.
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #6 on: 05. March 2013, 20:07:23 »
this is on ubuntu Askings :D
:o
http://askubuntu.com/questions/62681/how-do-i-setup-dual-monitors-in-xfce
it allmost like what above but witt Xrandr , you can switch i gues ...
:) if it works then you put it to autostart... other wise it lost settings then
Dutch go the dutch site :)
