Author Topic: octopi and password input  (Read 1043 times)
Offline holgerw
  • Neuling
  • Branch: stable
  • Desktop: KDE
  • GPU Card: Thinkpad R500 with Intel, Desktop PC with Intel
  • GPU driver: free driver
  • Kernel: newest
  • Skill: Advanced
« on: 16. June 2015, 10:55:40 »
Hi,
one question: How can I modify octopi settings, that this piece of software memorise password input? After installing software and closing octopi it is okay, that a new start and action of octopi needs new password input. But it is an exorbitant behavior of security, that every step of installation or removing software must be confirmed with password input, while I don't close octopi between installation steps.
Kind regards,
  Holger
« Last Edit: 16. June 2015, 10:59:11 by holgerw »
I'm using Debian, siduction, Antergos, Manjaro and openSUSE tumbleweed
Offline Cubanpit
  • Sr. Mitglied
  • Skill: Novice
Re: octopi and passord input
« Reply #1 on: 16. June 2015, 11:01:43 »
You can install more then one package with one "confirmation", anyway I think that it's not possible to memorize the password.
Octopi utilize "pacman" and he wants a password every time.
Laptop: Lenovo Ideapad Flex 14 (2013) // Graphics: Intel HD Haswell - Free Driver // DE: KDE Plasma 5 // Kernel: Linux 4.6 // Branch: Testing
PC: Graphics: ATI Radeon X1600 PRO - Free Driver // WM: i3 // Kernel: Linux 4.4 // Branch: Stable
Offline holgerw
  • Neuling
  • Branch: stable
  • Desktop: KDE
  • Kernel: newest
  • Skill: Advanced
Re: octopi and password input
« Reply #2 on: 16. June 2015, 11:46:51 »
Hi,
thanks for your answer. I know that I can install and remove a lot of packages in one step. But sometimes I notice "Ah, I need also package xyz" and then I start a further installation.
The YaST module for softwaremanagement is a frontend to zypper, it also requieres password input. But when closing YaST and restarting it during 10 minutes after closing, no further password input is required.
Kind regards,
  Holger
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
« Reply #3 on: 16. June 2015, 11:55:41 »
you can also do
Code: [Select]
sudo suand install from the terminal but it also requires that you leave the window open... ;) :)
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
