Author Topic: [QT5] Release 2.0 of redshiftconf  (Read 2707 times)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« on: 02. June 2015, 15:08:10 »
CARE : The icon doesn't appear in Xfce, so it's unuseable in this DE for the moment.
Works with Lxqt and Kde
Hi all  :)
I restructured this program around an icon that can remain permanently in the notification area.
  • simple click on this icon turns redshift on/off
  • rigt click on this icon allows to configure/quit the program
Configure opens the configuration windows :
to see the results of the configuration, click again on the icon. When ready, close the configuration windows. The Latitude/Longitude is preset automatically by geolocation when possible.
redshifconf can be run at start or thru Menu -> Utilities.
To install it : yaourt -S redshiftconf
(0.07 Mb installed)
Any request for improvement is welcome.  ;)
« Last Edit: 17. June 2015, 14:12:07 by Esclapion »
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline notargets
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: Plasma 5
  • GPU Card: AMD Radeon HD 6670
  • GPU driver: free
  • Kernel: linux4.4-x64
  • Skill: Novice
Re: [QT5] Release 2.0 of redshiftconf
« Reply #1 on: 02. June 2015, 21:09:11 »
Very nice, thank you! :)
I've tested it with KDE4 and noticed the following:
  • Always except the first time after it is launched, I have to click twice on the icon with either the left or right mouse button to toggle Redshift or bring up the context menu. After the first click, what happens is the focus is taken away from other windows, nothing else.
  • When I toggle Redshift by left clicking, the icon disappears temporarily and appears again on the left side of all other icons, as if the application was killed and run again. (This doesn't happen with redshift-gtk.)
Otherwise, I like it a lot. Especially because it can be configured from the GUI (unlike redshift-gtk) and it's Qt-based.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #2 on: 02. June 2015, 21:28:11 »
1) can't reproduce here...
2) also not with lxqt. Whe I toggle, i hide the icons, change it, and shows again set the icon invisible, change the icon, and set icon visible. Normally, it must not change the position ? To see, thanks for the info.
(edit)
It's not necessary to set the icon invisible and after visible, i can suppress that. It will probably solve this problem.
« Last Edit: 02. June 2015, 21:33:49 by Esclapion »
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #3 on: 02. June 2015, 21:40:48 »
great esclapion now with icon  ;D
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #4 on: 02. June 2015, 21:43:41 »
New release 2.1. I hope the problem 2) disappeared...  ::)
Please, do an update and say me the result.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #5 on: 02. June 2015, 21:46:57 »
Sure ok  ;)
Canale IRC italiano
#manjaro-it
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #6 on: 02. June 2015, 21:47:56 »
Else, I did a little github HERE.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #7 on: 02. June 2015, 22:02:31 »
Error checksum during build ...
Canale IRC italiano
#manjaro-it
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #8 on: 02. June 2015, 22:08:46 »
Works here ????
(edit)
You do : yaourt -S redshiftconf , like me ?
« Last Edit: 02. June 2015, 22:10:37 by Esclapion »
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #9 on: 02. June 2015, 22:13:55 »
i have modified pkgbuild : md5 skipped
Edit your github repo  ;)
Canale IRC italiano
#manjaro-it
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #10 on: 02. June 2015, 22:15:55 »
Oh, you took from sources ?  :D Yep, my PKGBUILD was not updated...
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #11 on: 02. June 2015, 22:18:16 »
 ;D sorry i did not understand
Canale IRC italiano
#manjaro-it
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #12 on: 02. June 2015, 22:23:04 »
github updated  ;D
Offline notargets
  • Branch: stable
  • Desktop: Plasma 5
  • GPU driver: free
  • Skill: Novice
« Reply #13 on: 02. June 2015, 22:27:06 »
Yes, now it stays in one place for me.
As for the other issue, most of the time one click is enough now, but not always. I'm not sure why.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #14 on: 02. June 2015, 22:28:56 »
Nice, so half solved. Maybe else a problem of logic, will have a look.  ;) The icon moving was bad...  :)
