Author Topic: [ Build 2 Iso Manjaro ( b2im ) ] manjaro-tools in GUI  (Read 8339 times)
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
  • GPU Card: nVidia GeForce GTS 450
  • Kernel: linux318-x64
  • Skill: Intermediate
Re: [ Build 2 Iso Manjaro ( b2im ) ] manjaro-tools in GUI
« Reply #30 on: 23. May 2015, 16:55:57 »
Hi @darso,
I just found the bug in the translation file
Code: [Select]
en.po:164:msgstr "<b>Version ISO image:</b"
I added code to avoid
Code: [Select]
"Segmentation fault"
Thank you for the feedback  ;)
Offline darso
  • Held Mitglied
  • Keep 'er between the hedges!
  • Branch: OpenRC-Stable
  • Desktop: OpenBox+XFCE
  • GPU Card: nVidia GT610
  • GPU driver: non-free
  • Kernel: linux43-x64
  • Skill: Novice
« Reply #31 on: 23. May 2015, 17:05:45 »
Hi @darso,
Code: [Select]
Code: [Select]
Nice! and really quick too  ;)
Thanks xcfaudio, does this mean we need to download and install again?
Cheers,
darso.
It must be difficult... for those who have taken authority as the truth, rather than truth as the authority.
-G. Massey, Egyptologist.
Linux Counter Reg Number #578558
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #32 on: 23. May 2015, 17:15:14 »
Yes, but I prepare a PKGBUILD file for the next b2im version
ps:
But if you do programming, it is not difficult to correct  ;)
« Last Edit: 23. May 2015, 17:17:01 by xcfaudio »
Offline darso
  • Held Mitglied
  • Skill: Novice
« Reply #33 on: 23. May 2015, 17:17:32 »
Excellent, I look forward to trying this out  ;) ;D 8)
Brilliant work buddy, thanks so much  ;D (it really helps us dopey people that can't fathom manjaroiso or manjarotools lol)
Cheers,
darso.
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #34 on: 23. May 2015, 23:04:15 »
The following destination options have changed name:
Code: [Select]
chroots_pkg=
chroots_iso=
to:
Code: [Select]
chroots_dir=
If your root folder HAS more space, make household from:
Code: [Select]
/var/lib/manjaro-tools
If @Artoo can confirm this?
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #35 on: 24. May 2015, 00:03:52 »
Yes, version 0.9.8 will have this.  :)
Release is next days.
I personally have an entire build partition I mount on boot.
« Last Edit: 24. May 2015, 00:06:09 by artoo »
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #36 on: 24. May 2015, 00:13:20 »
Thank's.
I change my code for imminent release.
More apparent default for now for b2im.
PS:
The new version of b2im-0.9.17.tar.gz is available ... Have fun   ;)
Code: [Select]
$ yaourt -S b2im
« Last Edit: 24. May 2015, 19:35:57 by xcfaudio »
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #37 on: 24. May 2015, 22:49:47 »
Hi xcfaudio ,
Italian language is here .. https://mega.co.nz/#!FdUUwbjC!dbGbrJFpKvpGtJfYiJfdiW02gNnsIrzAefnOinyUv08
Great Work  ;)
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #38 on: 24. May 2015, 23:11:25 »
Thank you for translating Italian @Ste74   ;)
The file will be included in the next version of b2im.
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #39 on: 26. May 2015, 15:47:27 »
Update of b2im-0.9.18.tar.gz is available  8)
Offline lemust83
  • Neuling
  • You speak french ? http://manjaro.fr/forum/
    • Manjaro.fr
  • Branch: Testing
  • Desktop: Xfce
  • GPU Card: Nvidia GF119 (GT 610)
  • GPU driver: Nonfree
  • Kernel: Linux The last one ;)
« Reply #40 on: 26. May 2015, 23:51:57 »
It's on Aur repo:
Code: [Select]
$ yaourt b2im
1 aur/b2im 0.9.18-1 [installed] (2)
    a graphic tool for manjaro-tools
==> Numéro(s) des paquets à installer (ex: 1 2 3 ou 1-3)
MANJARO Xfce: CPU: Single core AMD Athlon TF-20
Machine: Mobo:Gigabyte Model GA-A55M-S2HP .
CG:: NVidia Gf 119
http://manjaro.fr/forum/index.php
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #41 on: 05. June 2015, 14:07:49 »
you might want to adjust your script's dependencies in the near future:
"manjaro-tools" just got split into 3 packages. the changes are already affecting the unstable branch. read more about it here: https://wiki.manjaro.org/index.php?title=Manjaro-tools#Introduction
if you are using the "mkset" tool, it got renamed to "buildset".
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
« Reply #42 on: 05. June 2015, 14:11:39 »
Is there a way to get a gui for manjaro-tools that does not  pull in tons of KDE stuff?
J.
Hitten by the door in the back when I left Manjaro.
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #43 on: 05. June 2015, 22:46:32 »
Hi,
@excalibur1234,
Thank you for the information  ;)
@Jeannie,
gfxboot absolutely needs kdegraphics-kolourpaint  >:D
Offline ewolnux
  • Held Mitglied
  • Branch: Stable
  • Desktop: KDE (the best)
  • GPU Card: Intel HD4000
  • GPU driver: Free
  • Kernel: 4.1.x
« Reply #44 on: 08. June 2015, 10:29:38 »
Bonjour
Today, testing update replaces manjaro-tools by manjaro-tools-base.
b2im must uninstall to continue, then change the dependencies of PKGBUILD and rebuild the package, or wait xcfaudio releases its latest version.
Below the new PKGBUILD :
Code: [Select]
# Maintainer: lemust83 <lemust83420@gmail.com>
# Contributor: Claude Bulin <xcfaudio@gmail.com>
pkgname=b2im
pkgver=0.9.19
pkgrel=1
pkgdesc="a graphic tool for manjaro-tools"
arch=('i686' 'x86_64')
url="http://www.xcfa.tuxfamily.org/article25/build-2-iso-manjaro"
license=('GPL')
depends=('imagemagick' 'kdegraphics-kolourpaint' 'git' 'manjaro-tools-base' 'gtk3')
makedepends=()
conflicts=()
replaces=(b2im)
source=(http://download.tuxfamily.org/xcfaudio/MANJARO/build2isomanjaro/$pkgname-$pkgver.tar.gz)
sha256sums=('f1fb84250eff225e10c55edef3143b1eb58894e9ec92485ffcd3b16b469ec947')
build() {
  cd "$pkgname-$pkgver"
  ./autogen.sh
  make
package() {
  make DESTDIR="$pkgdir/" install
Administrator MANJARO FRANCE
Rejoignez la communauté francophone sur manjaro.fr.
