Author Topic: [ Build 2 Iso Manjaro ( b2im ) ] manjaro-tools in GUI  (Read 8340 times)
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
  • GPU Card: nVidia GeForce GTS 450
  • Kernel: linux318-x64
  • Skill: Intermediate
Re: [ Build 2 Iso Manjaro ( b2im ) ] manjaro-tools in GUI
« Reply #15 on: 22. May 2015, 19:40:27 »
@fassil,
This error because you have not applied
Code: [Select]
$ sudo make install
Offline fassil
  • Support Team
  • Branch: stable/unstable
  • Desktop: E19/E20
  • GPU driver: free
  • Kernel: Linux314 & 318
« Reply #16 on: 22. May 2015, 21:09:11 »
Strange, I did it.. :o
I'll retry later
"Are you enlightened ?"
Offline Holmes
  • Mirror Support Team
  • Brazilian and Hispanic Support Team
    • Manjaro Brasil
  • Branch: Stable
  • Desktop: Manjaro XFCE
  • GPU Card: Mobile Intel (R) 945
  • GPU driver: Non-free
  • Kernel: kernellinux
  • Skill: Novice
« Reply #17 on: 22. May 2015, 21:46:53 »
hi @xcfaudio, i did the translation for PT-BR (portuguese of Brazil). the translation file is in the link below
https://meocloud.pt/link/dcdfc485-ecde-49a4-9221-39a99f62d82f/pt-br.po/
congratulations on the creation of b2im... ;)
vlw fwi, Holmes :)
==> Manjaro Brasil I Manjaro Hispano
==> IRC Manjaro Brasil: #manjaro-br I IRC Manjaro Hispano: #manjaro-es
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #18 on: 22. May 2015, 21:59:51 »
Translation pt-br is ok for the next b2im version @Holmes
Thank's
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #19 on: 22. May 2015, 22:58:01 »
@fassil,
If the '/usr/share/pixmaps/b2im/' folder does not exist, the command 'sudo make install' has not been applied   :(
Offline ewolnux
  • Held Mitglied
  • Branch: Stable
  • Desktop: KDE (the best)
  • GPU Card: Intel HD4000
  • GPU driver: Free
  • Kernel: 4.1.x
« Reply #20 on: 23. May 2015, 09:48:46 »
Salut
I tried it and it works very well. Congratulations.
Administrator MANJARO FRANCE
Rejoignez la communauté francophone sur manjaro.fr.
Offline fassil
  • Support Team
  • Desktop: E19/E20
  • GPU driver: free
« Reply #21 on: 23. May 2015, 10:21:35 »
'LLo xcfaudio,
So it works nows (a few time..), but is kdegraphics-kolourpaint package mandatory for b2im ?
(On my system, It just needs 400 MB of dependancies, pfuuu..  :-\)
« Last Edit: 23. May 2015, 10:52:48 by fassil »
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #22 on: 23. May 2015, 11:13:17 »
@ewolnux,
  Good  ;)
@fassil,
kolourpaint is not mandatory but recommended  ;)
Offline fassil
  • Support Team
  • Desktop: E19/E20
  • GPU driver: free
« Reply #23 on: 23. May 2015, 11:17:23 »
So, it's an other problem...
Any log somewhere ?
Ps: Could we continue in french in an other place (other language)/forum ?
« Last Edit: 23. May 2015, 11:20:18 by fassil »
Offline ewolnux
  • Held Mitglied
  • Branch: Stable
  • GPU driver: Free
  • Kernel: 4.1.x
« Reply #24 on: 23. May 2015, 11:29:15 »
Salut
Tu voudrais poursuivre en "fassilien" ?  ;)
Continue ici et tu postes les deux langues.
Ça m'étonnait ton kolourpaint, vu que ce n'est pas installé chez moi.
Hi
You would continue in "fassilien" ? ;)
Continue here and you positions both languages.
It astonished me your kolourpaint, since it is not installed in my home.
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #25 on: 23. May 2015, 11:36:16 »
No problem  ;)
(kolourpaint est recommandé mais pas obligatoire)
Offline fassil
  • Support Team
  • Desktop: E19/E20
  • GPU driver: free
« Reply #26 on: 23. May 2015, 11:52:29 »
Bon, j'ai trouvé les *chmouly* en lançant l'histoire en CLI:
C'était 1 paquet introuvable,1 en double, un point de trop pour le kernel & une demande de pwd en CLI ??
Ca mouline (mirrorlist interminable pour l'instant..), A suivre...
It works from CLI, for the moment...  :)
Faulty -> arj (missing), ecrypt-utils (twice), a dot in the kernel name & pwd in CLI ??
Ps: Je rebuilde dans /home/work d'habitude & il doit y avoir des permissions qui coincent avec le profil que j'ai importé dans b2im dans ~, n'est-il pas ?
« Last Edit: 23. May 2015, 11:57:02 by fassil »
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #27 on: 23. May 2015, 12:10:01 »
I am trying to produce a 'enlightenment' after an update with 'Manjaro-tools-git-r1077.cfde2da-1-any.pkg.tar.xz' and it works well   :)
Je suis entrain de produire une 'enlightenment' après une mise à jour avec 'manjaro-tools-git-r1077.cfde2da-1-any.pkg.tar.xz' et ça fonctionne bien
==> Done [Build ISO]
==> Creating [md5sum] ...
  -> md5sum: f5aa51a5095b03f6eb50b48dcf7a7b35  manjaro-enlightenment-0.10.0-x86_64.iso
Offline xcfaudio
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
« Reply #28 on: 23. May 2015, 12:23:15 »
I must take the time to make a PKGBUILD for b2im: it will be more fun  ;)
Il faudra que je prenne le temps de faire un PKGBUILD pour b2im : ce sera plus fun
Offline darso
  • Held Mitglied
  • Keep 'er between the hedges!
  • Branch: OpenRC-Stable
  • Desktop: OpenBox+XFCE
  • GPU Card: nVidia GT610
  • GPU driver: non-free
  • Kernel: linux43-x64
  • Skill: Novice
« Reply #29 on: 23. May 2015, 16:37:44 »
Hi guys,
First of all let me say thank you to ya xcfaudio for this great idea, thank you kindly  ;D
I have a little problem with it though, I get as far as "Generate ISO" and the application quits and the terminal I ran it from just says "Segmentation fault" if I run it through the programs desktop file or a menu item in Openbox it quits also.
I read the post from fassil,
'LLo xcfaudio,
Just install & following happens just after briefly opening windows ?
Code: [Select]
(b2im:499): GdkPixbuf-CRITICAL **: gdk_pixbuf_new_from_file_at_scale: assertion 'filename != NULL' failed
(b2im:499): GLib-CRITICAL **: g_path_get_dirname: assertion 'file_name != NULL' failed
Erreur de segmentation (core dumped)
Any Idea ?
and installed kdegraphics-kcolourpaint form the repositories but alas it still doesn't build my ISO.  One thing I did notice upon running b2im was an error within the program about GTK and GLib-GObject, see below:
Code: [Select]
[darso@manjaman ~]$ b2im
main.c :: main (line = 58)
b2im 0.9.16
b2im 0.9.16 compiled at May 23 2015 14:21:32
Compiler: gcc 4.9.2 20150304 (prerelease)
Gtk version  = 3.3.16
Glib version = 2.0.44
ENABLE_NLS OK
    GETTEXT_PACKAGE    = b2im
    LOCALE_DIR         = /usr/share/locale
WIN_POS_X                        = 10
WIN_POS_Y                        = 10
WIN_WIDTH                        = 816
WIN_HEIGHT                       = 645
CHOICE_KERNEL_XX_BITS            = 32
CHOICE_TYPE_IMAGE                = 0
CHOICE_NUM_LANGUAGE              = 18
CHOICE_NUM_IMAGE_BOOT            = 0
MENU_NORMAL_FG_LIST_0            = 0.000000
MENU_NORMAL_FG_LIST_1            = 0.000000
MENU_NORMAL_FG_LIST_2            = 0.000000
MENU_SELECTED_FG_LIST_0          = 1.000000
MENU_SELECTED_FG_LIST_1          = 1.000000
MENU_SELECTED_FG_LIST_2          = 1.000000
MENU_BAR_COLOR_LIST_0            = 0.000000
MENU_BAR_COLOR_LIST_1            = 0.000000
MENU_BAR_COLOR_LIST_2            = 0.000000
BOOL_IMPORT_PICTURE              = FALSE
PATH_CACHE_ISO                   = /home/darso
PATH_FOLDER_MANJARO_PROFILES     = /home/darso
STRING_CHOICE_DESKTOP            =
PATHNAME FILE wind_main.glade: /usr/share/b2im/wind_main.glade
(b2im:9063): GLib-GObject-WARNING **: The property GtkImageMenuItem:use-stock is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkSettings:gtk-menu-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkWidget:margin-left is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkWidget:margin-right is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkAlignment:left-padding is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkButton:xalign is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): Gtk-WARNING **: Failed to set text from markup due to error parsing markup: Error on line 1 char 34: '/' is not a valid character following the close element name 'b<'; the allowed character is '>'
(b2im:9063): GLib-GObject-WARNING **: The property GtkImage:stock is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkAlignment:top-padding is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkAlignment:bottom-padding is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkAlignment:right-padding is deprecated and shouldn't be used anymore. It will be removed in a future version.
(b2im:9063): GLib-GObject-WARNING **: The property GtkContainer:resize-mode is deprecated and shouldn't be used anymore. It will be removed in a future version.
xdg.c :: xdg_print_list_config_path (line = 247)
! FreeDesktop integration
! http://www.freedesktop.org/wiki/
! http://fr.wikipedia.org/wiki/Freedesktop.org
    Lcur->data = /home/darso/.config/b2im/b2im.conf
    Lcur->data = /etc/xdg/b2im/b2im.conf
xdg.c :: xdg_print_list_data_path (line = 148)
    Lcur->data = /home/darso/.local/share/b2im
    Lcur->data = /usr/local/share/b2im
    Lcur->data = /usr/share/b2im
    Lcur->data = /usr/share/b2im/glade
    Lcur->data = /usr/share/pixmaps
    Lcur->data = /usr/share/pixmaps/b2im
This is maybe unrelated to the problem running b2im but i feel that the line in the code above "(b2im:9063): Gtk-WARNING **: Failed to set text from markup due to error parsing markup: Error on line 1 char 34: '/' is not a valid character following the close element name 'b<'; the allowed character is '>'" has something to do with this:
I will deffinately be keeping an eye on this application, it's a brilliant idea and thanks again xcfaudio, and all the guys involved, for all your hard work.  ;D
Cheers,
darso.
« Last Edit: 23. May 2015, 16:39:32 by darso »
It must be difficult... for those who have taken authority as the truth, rather than truth as the authority.
-G. Massey, Egyptologist.
Linux Counter Reg Number #578558
