Author Topic: Manjaro Pantheon Shell Community Edition [0.8.13 pre2] released  (Read 36567 times)
Offline d_rail
  • Neuling
  • I'm nice. Be new!
  • Desktop: Pantheon
  • GPU Card: yes
  • Skill: Intermediate
Re: Manjaro Pantheon Shell Community Edition [0.8.13 pre2] released
« Reply #30 on: 19. May 2015, 03:25:11 »
Windows control error is mutter 3.16 fault it don't use metacity
but gala still need use metacity
Is there a launchpad bug open for this issue?
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
« Reply #31 on: 19. May 2015, 04:22:37 »
I think not, but it is not developmente fault once time they make gala for elemenrary os, and it still using mutter 3.14.
Hey good news I work in a geary integration with plank and now it show badges on icon when you receive email
some one can help me make a pkgbuild?
Offline d_rail
  • Neuling
  • I'm nice. Be new!
  • Desktop: Pantheon
  • GPU Card: yes
« Reply #32 on: 19. May 2015, 06:11:17 »
I wonder if a desktop environment that requires to exclude a major component of the DE from being upgraded  to the latest version  for an unforeseeable period of time is suitable for a rolling release distribution at all.
No wondering required, Pantheon is not made for rolling release.  However, I like wingpanel, slingshot, plank, pacman, and aur.  So, I'll make due.
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #33 on: 19. May 2015, 07:44:55 »
When I built pantheon pre2 I did not know I mutter 3.14 and above had installed 3.16. Everything worked well enough in the closing of some windows . Then you could leave mutter run and disable the buttons windows and forcing users to use [ Alt ] + [ F4 ] or use package xdotool and enable a special command of the mouse to close the window ... Alucryd makes porting Pantheon but only believe ... it should ensure that pantheon corrected faster development ..
I saw that on Arch quequotion made ​​packages with compiz you thinking , that would be another way to do the rolling wm ...
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #34 on: 19. May 2015, 07:48:59 »
Hello Lucas , what would you need ?
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #35 on: 19. May 2015, 11:39:58 »
Have you see at line 168 gtk 3.16 is implemented ..
http://bazaar.launchpad.net/~gala-dev/gala/trunk/view/head:/configure.ac
How make it ? ???
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #36 on: 19. May 2015, 18:56:24 »
I just open a issue on github for gala
https://github.com/alucryd/aur-alucryd/issues/24
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #37 on: 19. May 2015, 21:49:03 »
Alucryd confirm this bug ( mutter 3.16 ) recommend opening bug on launchpad because the elementary team has just put support for mutter 3.16
Opened : https://bugs.launchpad.net/gala/+bug/1456787
« Last Edit: 19. May 2015, 22:04:55 by Ste74 »
Canale IRC italiano
#manjaro-it
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
« Reply #38 on: 19. May 2015, 22:49:07 »
Done
my first package for arch
this is solve the missing badge notifications in geary
plz help me improve this package
https://aur.archlinux.org/packages/geary-plank-bzr/
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
« Reply #39 on: 20. May 2015, 00:32:10 »
Hi guys just forge about the others packages I found this project abondoned and adopt
and update
this package make the same thing than other
sorry for bad english
https://aur.archlinux.org/packages/geary-unity/
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #40 on: 20. May 2015, 19:56:13 »
and update
Hi , this packages need unity ?
Canale IRC italiano
#manjaro-it
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
« Reply #41 on: 20. May 2015, 20:52:06 »
Not all unity
just libunity
this provide integration with the unity, and plank use unity api
the code explain all
http://bazaar.launchpad.net/~yorba/geary/trunk/view/head:/src/client/notification/unity-launcher.vala
if HAVE_LIBUNITY
Offline d_rail
  • Neuling
  • I'm nice. Be new!
  • Desktop: Pantheon
  • GPU Card: yes
« Reply #42 on: 21. May 2015, 06:20:32 »
Quequotion also made a openbox version:
https://aur.archlinux.org/packages/pantheon-3d/
https://aur.archlinux.org/packages/pantheon-lite/
I'd rather stick with gala, but compiz and openbox are more mature and probably would be easier.  I see that openbox even has an elementary theme.  They both require pantheon workarounds that has some hacks to make pantheon apps work without gala.  Regardless, the workarounds package has gnome media keys fallback that is useful in getting media keys working on some keyboards.
Thanks for opening the bug on launchpad, I added my 6 points.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #43 on: 21. May 2015, 10:24:25 »
Thank you d_rail ... I have opened a github repo to build fork a mutter for install directly in a new iso ( pre3 )
https://github.com/Ste74/Pantheon-PKGBUILD-Repo
Any suggestion is appreciated ..
Canale IRC italiano
#manjaro-it
Offline ewolnux
  • Held Mitglied
  • Branch: Stable
  • Desktop: KDE (the best)
  • GPU Card: Intel HD4000
  • GPU driver: Free
  • Kernel: 4.1.x
« Reply #44 on: 21. May 2015, 20:03:59 »
Hi
Possible for the next iso add 'Open as Root' ?
See : http://ubuntuhandbook.org/index.php/2015/02/open-as-root-elementary-os-freya/
Administrator MANJARO FRANCE
Rejoignez la communauté francophone sur manjaro.fr.
