Author Topic: Manjaro Pantheon Shell Community Edition [0.8.13 pre2] released  (Read 36000 times)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
Re: Manjaro Pantheon Shell Community Edition [0.8.13 pre2] released
« Reply #180 on: 02. August 2015, 22:30:42 »
Well .. i suggest to install first xfce up and running . After install pantheon and remove xfce component .
You compare this pkg in your installation
https://github.com/Ste74/manjaro-tools-iso-profiles/blob/master/pantheon/Packages-Pantheon
pkg modified for manjaro .
https://github.com/Ste74/Pkg-Dev
Keep in mind the wingpanel for now not work . In Manjaro Pantheon i use budgie-panel . For use it install dconf-editor and at the key
org.pantheon.desktop.cerbere
change wingpanel to budgie-panel.
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline AndrewTim
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #181 on: 03. August 2015, 11:52:13 »
So after running up xfce I should install all stuff from https://github.com/Ste74/Pkg-Dev  ? Sorry for annoying, maybe its simple things, but Im Neuling in Archlinux
« Last Edit: 03. August 2015, 11:55:14 by AndrewTim »
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #182 on: 03. August 2015, 16:12:34 »
No problem .. tonight or tomorrow upload an a ftp server the pkg's modified then write a little how-to for install it .. and change wingpanel . The ftp repo will used for next dev realese  ;)
Canale IRC italiano
#manjaro-it
Offline AndrewTim
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #183 on: 03. August 2015, 16:15:02 »
Thanks a lot
Offline AndrewTim
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #184 on: 04. August 2015, 16:02:51 »
Haven't you uploaded pgs yet?
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
Canale IRC italiano
#manjaro-it
Offline AndrewTim
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #186 on: 04. August 2015, 22:44:05 »
Will try to install it. Want to say you thanks for your work
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
Canale IRC italiano
#manjaro-it
Offline Alberto Aru
  • Neuling
    • Pump
  • Skill: Novice
« Reply #188 on: 13. August 2015, 13:30:02 »
Where should we report the errors?
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #189 on: 13. August 2015, 18:44:02 »
This release is old , new release is here
https://forum.manjaro.org/index.php?topic=25043.0
if not want reinstalled please read this
https://forum.manjaro.org/index.php?topic=24868.0
Ste
Canale IRC italiano
#manjaro-it
Offline Alberto Aru
  • Neuling
    • Pump
  • Skill: Novice
« Reply #190 on: 13. August 2015, 18:48:19 »
Ste
I think that that's the version I'm using right now (it includes these repositories and came as the other link shows: same aesthetic and packages)
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #191 on: 13. August 2015, 18:52:13 »
Well , report any issue only for pantheon shell in "other"  section or better in this tread
Ste
Canale IRC italiano
#manjaro-it
