Author Topic: Manjaro Pantheon Shell Community Edition [0.8.13 pre2] released  (Read 34452 times)
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
Re: Manjaro Pantheon Shell Community Edition [0.8.13 pre2] released
« Reply #15 on: 16. May 2015, 22:39:46 »
hi AJSlye ,
wingpanel ( panel of elementary ) not work fine many applet/indicator function not working . Only date/time , application menù and sound applet works fine . The session manager work only for shutdown i remember .
I tried to try to correct a panel that was nice to see, and transparent and bring it resulted from gnome et voila : budgie-panel. It works well and is aesthetically nice ...
Yes, since Elemetary is based on 14.04 LTS, the indicators are coded for the 12.10 version of indicators, also indicator-session is coded around upstart and not systemd.
There is a hacked version of indicator-session to work with systemd in the AUR here: https://aur.archlinux.org/packages/indicator-session-systemd/
Reference: https://wiki.archlinux.org/index.php/Pantheon#Indicators_not_working_in_wingpanel
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #16 on: 16. May 2015, 22:43:08 »
I know that wiki unfortunately do not work the same ..
https://bbs.archlinux.org/viewtopic.php?pid=1504316#p1504316
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #17 on: 16. May 2015, 23:03:17 »
Windows control error is mutter 3.16 fault it don't use metacity
but gala still need use metacity,
Just donwgrade for mutter 3.14.3-3,
Get the code from gala
bzr branch lp:gala
compile and install
and exec gala --replace
I tried. regressed to mutter 3.14.2 because the repo Manjaro is that, reinstalled gala , went out and came back but all crashes
Canale IRC italiano
#manjaro-it
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #18 on: 16. May 2015, 23:23:25 »
To make it work correctly you have to use gnome 3.14 because Pantheon Shell  is based on Ubuntu and that is what Ubuntu uses or be a very good hacker you will encounter the same problems as Unity trying to use ubuntu based desktops best of luck
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
  • Skill: Intermediate
« Reply #19 on: 17. May 2015, 03:40:11 »
You need downgrade and recompile mannualy
try get package in rolling back and test,
you can't just reinstall gala from bzr it will not work
http://seblu.net/a/arm/packages/m/mutter/
Offline lucasnota
  • Jr. Mitglied
  • I'm new. Be nice!
« Reply #20 on: 17. May 2015, 04:06:04 »
try this
Code: [Select]
$ cd /tmp/ && wget seblu.net/a/arm/packages/m/mutter/mutter-3.14.3-3-x86_64.pkg.tar.xz && sudo pacman -U mutter-3.14.3-3-x86_64.pkg.tar.xz && cd /tmp/ && bzr branch lp:gala && cd gala && ./configure --prefix=/usr && make && sudo make install
$ gala --replace
Offline d_rail
  • Neuling
  • I'm nice. Be new!
  • Desktop: Pantheon
  • GPU Card: yes
« Reply #21 on: 17. May 2015, 09:21:33 »
Thank you Ste74 for putting this together.  I installed it on my laptop and it runs pretty smooth.  However, I'm using wingpanel instead of budgie-panel.  What is nice is caffeine-ng and variety indicators are working even though they haven't worked in the past.  Not sure what the difference is.
try this
Code: [Select]
$ gala --replace
Thanks, but I had to run autogen.sh before configure inside of the gala directory.  However, it fixes the window buttons and and dark shadow around some windows.  Also, I had to add mutter to pacman's IgnorePkg config.
Code: [Select]
$ cd /tmp/ && wget seblu.net/a/arm/packages/m/mutter/mutter-3.14.3-3-x86_64.pkg.tar.xz && sudo pacman -U mutter-3.14.3-3-x86_64.pkg.tar.xz && cd /tmp/ && bzr branch lp:gala && cd gala && ./autogen.sh && ./configure --prefix=/usr && make && sudo make install
here are minor bugs i have noticed:
- after i have installed manjaro pantheon, it boots to lightdm (the login manager). there, i have to choose "pantheon" as DE in the lower right corner. lightdm wants to start gnome as default DE.
once i have done this, lightdm always starts pantheon.
- when i first boot manjaro pantheon, it asks me, whether i want to rename the folders in my home directory to my own language. i agreed / did it. even after a reboot the file manager (the links on the left side) shows the folder names in spanish (i assume it is spanish), but all folder names in my home directory are in my own language.
- when opening the calendar, it uses a very small font. this is ok, but it is much smaller than the font of other panel icon menus.
- i cannot add a virtual desktop. this might be a limitation of virtualbox, but i am not sure about it. did anybody install manjaro pantheon on real hardware and can share his/her experience?
- In /etc/lightdm/lightdm.conf, I noticed user-session is set to gnome.  Maybe set it to pantheon to fix the first time login issue.  Also, I suggest using lightdm-pantheon-greeter for greeter-session.
- This is a weird one.  It seems your user "manjaro" is hardcoded.  In files, the home directory shortcuts are pointing to /home/manjaro.  Example: Documenti(in Italian) links to /home/manjaro/Documents, instead of /home/myname/Documents.  I removed the existing ones and created new links to fix.
- I was able to add a desktop.  In Pantheon, you have to have a window open in order to add a desktop, so maybe that is what is happening.
Overall, I'm very happy.  Good job.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #22 on: 17. May 2015, 11:19:42 »
Thank you d-rail for the positive feedback .. any help to improve not appreciated , is welcome  ;D . Any positive news is to try to bring Manjaro - pantheon in stable release and use by newbie ..
We continue to help us out .
Sorry for my not perfect english ..
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #23 on: 17. May 2015, 11:23:01 »
Quote
I forgot, what indicators work on the laptop ?
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #24 on: 17. May 2015, 12:22:08 »
try this
Code: [Select]
$ gala --replace
Yeeess right .. works fine ..
yes it exchanged with autogen configuration settings but not a problem .. but it's true now must ignore updates to mutter ?
But this long?
Thank you lucas for share your solution ..  ;D
Canale IRC italiano
#manjaro-it
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • Desktop: Plasma 5, Gnome, Cinnamon, Deepin, Unity,
  • GPU Card: Intel
  • GPU driver: free driver
  • Kernel: linux 4.1
  • Skill: Novice
« Reply #25 on: 17. May 2015, 19:48:04 »
Any 32bit thanks
good&nice
American dream. welcome to Guantánamo civil-isation
we are all different ... this is our common
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #26 on: 17. May 2015, 20:05:41 »
Any 32bit thanks
good&nice
Yes next version try to  build also 32bit .. It was already my intention  ;)
Canale IRC italiano
#manjaro-it
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • GPU Card: Intel HD4000 + Nvidia 620M / Geforxe GTX 970
  • GPU driver: nonfree
  • Kernel: Latest
« Reply #27 on: 18. May 2015, 00:14:52 »
I can upload a package called mutter314 to the manjaro repos, I will do that tomorrow.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #28 on: 18. May 2015, 22:02:00 »
Thank you Kirek ..
Today, however, I thought one thing : one day as you will understand if mutter upgrade or not? When new version of elementary ?
Canale IRC italiano
#manjaro-it
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
« Reply #29 on: 18. May 2015, 23:23:09 »
I wonder if a desktop environment that requires to exclude a major component of the DE from being upgraded  to the latest version  for an unforeseeable period of time is suitable for a rolling release distribution at all.
J.
Hitten by the door in the back when I left Manjaro.
