Author Topic: New LXDE Community Edition has been released!  (Read 7047 times)
Offline ruziel
  • Held Mitglied
  • Those who know, laugh.
    • Coffee & Manjaro
  • Branch: Stable
  • Desktop: Xfce
  • Kernel: 4.4 / 4.9
  • Skill: Novice
Re: New LXDE Community Edition has been released!
« Reply #15 on: 06. March 2013, 12:45:03 »
fohrums, mmm blank screen @ boot up is not nice! i don't have anything to add on that one but am sure someone here will help you soon. welcome & great to have you as part of the community.
enjoy!
Ruziel.
"There is no complete theory of anything." (Robert Anton Wilson)
Offline fohrums
  • Neuling
« Reply #16 on: 06. March 2013, 14:54:12 »
I know it's horrid. It sucks to hear that LXDE is a community-based release. I grew very fond of LXDE when I found out it's the fastest with a full fledged desktop environment.
Offline tun in a cellar
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Hybrid graphic card (Intel/ATI)
  • GPU driver: free (the discrete card is switched off)
  • Kernel: linux313-x64 (the latest if possible)
  • Skill: Advanced
« Reply #17 on: 06. March 2013, 16:20:27 »
I have installed manjaro-lxde-0.8-r13-0218-i686.iso on my netbook via USB.
From installation everything went great and finished successfully.
When I restarted my netbook I get the green "OK" checklist then my screen goes blank right after. Is anybody else experiencing this headache?
1st of all, you have to try to boot in text mode. You can perform this as folliwng:
Code: [Select]
reboot your PC
when the grub menu is displayed, edit the entry which is selected by default (press 'E' )
change the "kernel command" line in order to avoid the DE (add the letter '3' at the end of the line) and start booting (press 'ctrl-X')
do you get a text mode prompt? Yes? let's go ahead...
Code: [Select]
login (input your credentials)
now, let's check the hardware and available video drivers...
tell us what you get when running this:
Code: [Select]
sudo mhwd -l
Code: [Select]
sudo mhwd -li
Why doing it yourself when manjaro-system can do it for you?
Offline fohrums
  • Neuling
« Reply #18 on: 11. March 2013, 04:30:31 »
What is to be expected? I just did a re-install of the older version. so it will work.
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #19 on: 11. March 2013, 08:28:30 »
 so im happy is worked for you mayby was went someting wrong with te installation. it always could happend...
Manjaro has also some fun :) like manjaroiso :) so you could also made a backup of latest iso....
i always backup some fresh iso time to time :)
Dutch go the dutch site :)
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Advanced
« Reply #20 on: 11. March 2013, 10:04:30 »
As the issue you described seemed to be related to graphic part, opening a text only session allows you to enter some commands... This may be useful for giving further information to the community/support and being helped.
You prefered to do a full reinstall? It's your choice
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« Reply #21 on: 21. March 2013, 11:04:56 »
AAAAnd..... solved
Offline fohrums
  • Neuling
« Reply #22 on: 04. April 2013, 03:07:29 »
AAAAnd..... solved
Is this fixed through external sources?
As far as I'm concerned, the issue I had with installing 0.8.4 is blank screen at boot up.
So is installing Manjaro uses the ISO for packages or does it get it from online source? Is this how the installation works? How else would it have been fixed if I'm still using the 0.8.4 ISO as installation?
