Author Topic: big troubled with pantheon  (Read 1241 times)
Offline KALGAN
  • Vollwertiges Mitglied
  • Branch: testing
  • Desktop: Cinnamon
  • GPU Card: nvidia GT750M
  • GPU driver: non-free driver
  • Kernel: 3.19 3.16
  • Skill: Intermediate
« on: 18. April 2015, 11:41:59 »
hi guys!today i have installed pantheon DE to use it as secondary or trial DE. i make a minimal installation and now i can't do nothing with it.the real problem is that i can't logout from pantheon and there is no application menu! if i clik on the application manu,it's don't work....in the dock bar there is only google-chrome and there isn├Čt a terminal..i can do nothing! i have on the same pc another partition with another OS...can i delete pantheon from it?
ps.i haven't a desttop manager,thus when i i restart my computer manjaro log in in pantheon automatically.....
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
Re: big troubled with pantheon
« Reply #1 on: 18. April 2015, 17:46:26 »
Hi , where you have find the files of pantheon session?
Have you installed this file ?
Code: [Select]
##Pantheon files
pantheon-session-bzr
audience-bzr
contractor-bzr
#dexter-contacts-bzr
eidete-bzr
elementary-icon-theme-bzr
elementary-scan-bzr
elementary-wallpapers-bzr
elementary-dpms-helper-bzr #need for use switchboard-plug
gtk-theme-elementary-bzr
geary
indicator-pantheon-session-bzr
lightdm-pantheon-greeter-bzr
maya-calendar-bzr
midori-granite-bzr
noise-bzr
pantheon-backgrounds-bzr
pantheon-calculator-bzr
pantheon-default-settings-bzr
pantheon-files-bzr
#pantheon-notify-bzr
pantheon-print-bzr
pantheon-terminal-bzr
plank-theme-pantheon-bzr
scratch-text-editor-bzr
snap-photobooth-bzr
switchboard-bzr
indicator-session-systemd #from Aur for patch indicator session pantheon
##Plugin for switchboard
switchboard-plug-default-applications-bzr
switchboard-plug-power-bzr
switchboard-plug-elementary-tweaks-bzr
switchboard-plug-pantheon-shell-bzr
switchboard-plug-keyboard-bzr
switchboard-plug-about-bzr
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
