Author Topic: New AUR package "mhwd-chroot" to test !!!  (Read 14287 times)
Offline Loup
  • Vollwertiges Mitglied
  • Desktop: xfce
  • GPU Card: nvidia GeForce GT 520
  • GPU driver: non-free driver
  • Kernel: 4.4 x64
  • Skill: Novice
Re: New AUR package "mhwd-chroot" to test !!!
« Reply #15 on: 28. March 2015, 21:29:05 »
Thank's esclapion working now !
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
  • Skill: Intermediate
« Reply #16 on: 29. March 2015, 01:23:32 »
The gui causes my mousepad only to flash and crash. running in terminal produces
Code: [Select]
[zatox@zatox ~]$ sudo mhwd-chroot-shell
No linux system found !
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #17 on: 29. March 2015, 01:27:45 »
Code: [Select]
Which DE and wich terminal is installed ?
What's the value of COLORSHELL ?
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • GPU driver: free
« Reply #18 on: 29. March 2015, 03:46:38 »
Mousepad and xfce. I havent set any color values for the shell.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #19 on: 29. March 2015, 12:42:39 »
Sorry, error. What's the result of
Code: [Select]
echo $COLORTERM
mousepad is not a terminal, it's a text editor. I have also xfce, and it works...  :o
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • GPU driver: free
« Reply #20 on: 29. March 2015, 13:13:29 »
Code: [Select]
echo $COLORTERM
:D yes sorry, of course it is the xfce4 terminal, the evening got the better of me. Well for me after i put the password the screen flashes as if it would be opening a terminal window then crashing immediately.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #21 on: 29. March 2015, 15:41:36 »
I did a mix between COLORSHELL and COLORTERM for the same reason.  ;D
But I don't see what can happens... I have a 0.8.12 "Ascella", and it works fine.   ::)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #22 on: 31. March 2015, 00:18:14 »
New release 1.2. Complete rewriting of the terminals management. The package no more depends of gksu or kdesu. If none of both is present, it disappears from the menu.
Can be called from the terminal, under root or not, with available terminal emulator  or not.
konsole and kdesu are supported.
More than 10 partitions per disk are now authorized.
Offline Loup
  • Desktop: xfce
  • Kernel: 4.4 x64
  • Skill: Novice
« Reply #23 on: 31. March 2015, 01:32:15 »
Bonjour esclapion,
this is the result i have when i try to use the new version.
« Last Edit: 31. March 2015, 01:34:33 by Loup »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #24 on: 31. March 2015, 02:01:55 »
I don't understand.  ::) You do a manually chroot, so you go to the installed version, and after you call mhwd-chroot.
If you have only one installed system, it can't do again a chroot ?
From the live, install mhwd-chroot and use it directly ?
You absolutely don't need all those mounts...  :o mhwd-chroot is done to replace them.
(edit)
You can't do a chroot from the installed version to the live, because the live is not installed.
« Last Edit: 31. March 2015, 02:04:22 by Esclapion »
Offline Loup
  • Desktop: xfce
  • Kernel: 4.4 x64
  • Skill: Novice
« Reply #25 on: 31. March 2015, 02:53:31 »
(edit)
Sorry to disturb, misunderstanding of the tool and chroot.
Thank's for your time
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #26 on: 31. March 2015, 11:20:00 »
No disturb, thanks for the tries.  :)
Offline mermouy
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Kde (kf5)
  • Kernel: linux38-64
  • Skill: Novice
« Reply #27 on: 16. April 2015, 22:12:36 »
Just tried this tool, I must I'm actually with Enlightenment DE, so it may obviously come from it...  :P
Anyway i just look for any log but I can't find any...? Where should I look for log or any info?
About what it does (visually at least), it just does'nt want to stay on desktop, and appear almost 0.5 s then disapear as fast as it came...
Hope I can help in some way... We may have a look at this sometime, as I will not have much free times this days...
Ciao and, BTW it looks like a nice tool!
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #28 on: 16. April 2015, 22:26:44 »
dmesg must work. Now, the fact you have a journal or not... I don't know enlightenment.
Offline dhope
  • a dope with hope
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: Intel int.
  • GPU driver: Free
  • Kernel: linux4-x64
  • Skill: Novice
« Reply #29 on: 17. April 2015, 01:09:14 »
This'll make a really nice addition to the live iso, great work!  ;D
