tropper, have you heard of
yaourt-gui? it is very similar to pacli.
you can install it with
pacman -S yaourt-gui-manjaro
to start it, type "yaourt-gui" in your terminal.
here is the source code for it. i found it an interesting read:
#!/bin/bash
# Yaourt-Gui is a bash gui for yaourt
# Creation-Date: 2011-02-28
# Revision-Date: 2014-08-26
# Support: http://www.alexiobash.com
### Set ###
TEXTDOMAINDIR=/usr/share/locale
TEXTDOMAIN=yaourt-gui
VER=1.1
BLUE="\033[7;34m"
BLU="\033[1;34m"
RED="\033[1;31m"
LRED="\033[7;31m"
WHI="\033[1;37m"
NC="\033[0m"
YELLOW="\033[1;33m"
GREL="\033[7;32m"
GRE="\033[1;32m"
PROFD=/etc/profile.d
CONFIG=/usr/share/yaourt-gui
# export
export TEXTDOMAINDIR=/usr/share/locale
export TEXTDOMAIN=yaourt-gui
### Start Script ###
gost () {
if [ -f $PROFD/proxy.sh ]; then
source $PROFD/proxy.sh
fi
clear
if [ -f $CONFIG/yglogo ]; then
$CONFIG/yglogo
echo -e ""
else
echo -e ""$RED"$CONFIG/yglogo $(gettext 'not found')!!!$NC"
fi
echo -e "$GREL YAOURT-GUI $VER - A bash GUI for Yaourt $NC"
echo -e ""
echo -e "$(gettext '[1] Sync DB [9] Search & Install [17] Set Proxy')"
echo -e "$(gettext '[2] Update System [10] Belongs To Files [18] Remove Proxy')"
echo -e "$(gettext '[3] Update force mode [11] Info Packages [19] Edit pacman.conf')"
echo -e "$(gettext '[4] Install Packages [12] Clear Cache [20] Edit yaourtrc')"
echo -e "$(gettext '[5] Remove Packages [13] PacDiffViewer [L] Log Pacman')"
echo -e "$(gettext '[6] Update Packages [14] Pacman DB Upgrade [H] Help yaourt-gui')"
echo -e "$(gettext '[7] Remove Dependencies [15] Pacman Optimize [Q] Quit')"
echo -e "$(gettext '[8] Search Packages [16] Yaourt Stats')"
echo -e ""
echo -e ""$YELLOW"$(gettext 'Run a Command or Number'):$NC"
read opt
case $opt in
### SyncDB ###
1|"yaourt -Sy")
echo -e "$GRE==> $(gettext 'DB Synchronization in progress...')$NC"
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -Sy $NC "
yaourt -Sy
echo -e ""
echo -e ""$GRE"$(gettext 'Press ENTER to display the Menu')$NC"
function pause(){
read -p "$*"
pause
gost
#### UpdateSystem ####
2|"yaourt -Syua")
echo -e ""
echo -e "$GRE==> $(gettext 'Update in progress.... !!!Please Wait!!!')$NC"
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -Syua $NC"
yaourt -Syua
echo -e ""
function pause(){
read -p "$*"
pause
gost
#### UpdateSystem Force mode ####
3|"yaourt -Syuaf")
echo -e ""
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -Syuaf $NC"
yaourt -Syuaf
echo -e ""
function pause(){
read -p "$*"
pause
gost
### InstallPackages ###
4|"yaourt -S")
echo -e "$GRE $(gettext 'Which packages do you want install?')$NC"
read PKG
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -S $PKG $NC"
yaourt -S $PKG
echo -e ""
function pause(){
read -p "$*"
pause
gost
### RemovePackages ###
5|"yaourt -R")
echo -e "$GRE $(gettext 'Which Package do you want remove?')$NC"
read PKR
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -R $PKR $NC"
yaourt -R $PKR
echo -e ""
function pause(){
read -p "$*"
pause
gost
### UpdatePackages ###
6|"yaourt -U")
echo -e "$GRE $(gettext 'Which packages do you want upgrade?') $NC"
read PKAG
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -U $PKAG $NC"
yaourt -U $PKAG
echo -e ""
function pause(){
read -p "$*"
pause
gost
### RemoveDependencies ###
7|"yaourt -Qdtq")
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -R "\$"(yaourt -Qdtq) $NC"
yaourt -R $(yaourt -Qdtq)
echo -e ""
function pause(){
read -p "$*"
pause
gost
### Search Packages ###
8|"yaourt -Ss")
echo -e "$GRE $(gettext 'Which packages do you want search?') $NC"
read PKAGE
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -Ss $PKAGE $NC"
yaourt -Ss $PKAGE
echo -e ""
function pause(){
read -p "$*"
pause
gost
### Search & Install ###
9|"yaourt")
echo -e "$GRE $(gettext 'Which packages do you want search and install?') $NC"
read PKAGE
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt $PKAGE $NC"
yaourt $PKAGE
echo -e ""
function pause(){
read -p "$*"
pause
gost
### belong file ###
10|"yaourt -Qo")
read PKAGE3
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -Qo $PKAGE3 $NC"
yaourt -Qo $PKAGE3
echo -e ""
function pause(){
read -p "$*"
pause
gost
### InfoPackage ###
11|"yaourt -Qi")
echo -e ""$GRE" $(gettext 'Which packages do you want search?')$NC"
read PKS
clear
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -Qi $PKS $NC"
echo -e ""
yaourt -Qi $PKS
echo -e ""
function pause(){
read -p "$*"
pause
gost
### ClearCache ###
12|"yaourt -Scc")
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -Scc $NC"
yaourt -Scc
echo -e ""
function pause(){
read -p "$*"
pause
gost
### PacDiffViewer ###
13|"yaourt -C")
clear
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt -C $NC"
echo -e""
yaourt -C
echo -e ""
function pause(){
read -p "$*"
pause
gost
### pacman-db-upgrade ###
14|"yaourt -C")
echo -e "$YELLOW==> $(gettext 'COMMAND'): pacman-db-upgrade$NC"
echo -e""
sudo pacman-db-upgrade
echo -e ""$GRE"$(gettext 'Upgrade successfully')$NC"
sleep 3
gost
### pacman-optimize ###
15|"yaourt -C")
clear
echo -e "$YELLOW==> $(gettext 'COMMAND'): pacman-optimize$NC"
echo -e""
sudo pacman-optimize
echo -e ""
function pause(){
read -p "$*"
pause
gost
### Yaourt Statistic ###
16|"yaourt --stats")
clear
echo -e "$YELLOW==> $(gettext 'COMMAND'): yaourt --stats $NC"
echo -e""
yaourt --stats
echo -e ""
function pause(){
read -p "$*"
pause
gost
### SetProxy ### user:password@
17|"set proxy")
echo -e "$GRE $(gettext 'Is a Auth Proxy? y/n [default yes]')$NC"
read SNI
case $SNI in
$(gettext 'y')|"")
echo -e ""
echo -e "$YELLOW$(gettext 'Write Username')$NC"
read USRNAME
echo -e "$YELLOW$(gettext 'Write Password')$NC"
read -es PASSWPR
echo -e ""
echo -e "$YELLOW$(gettext 'Write Ip or Hostname Proxy')$NC"
read PROXY
echo -e "$YELLOW$(gettext 'Write port Proxy')$NC"
read PORT
echo -e "#!/bin/bash" > /home/$USER/proxy.sh
echo -e "export http_proxy='"http://$USRNAME:$PASSWPR@$PROXY:$PORT"'" >> /home/$USER/proxy.sh
echo -e "export https_proxy='"http://$USRNAME:$PASSWPR@$PROXY:$PORT"'" >> /home/$USER/proxy.sh
echo -e "export ftp_proxy='"http://$USRNAME:$PASSWPR@$PROXY:$PORT"'" >> /home/$USER/proxy.sh
sudo mv /home/$USER/proxy.sh $PROFD
sudo chmod +x $PROFD/proxy.sh
sudo chown root:root $PROFD/proxy.sh
if [ -f $PROFD/proxy.sh ];then
echo -e ""
echo -e "$GRE==> $(gettext 'Proxy set successfully')$NC"
echo -e ""
function pause(){
read -p "$*"
pause
gost
else
echo -e ""
echo -e ""$RED"==> $(gettext 'The proxy is not set!!!!'):$NC"
echo -e ""
sleep 2
gost
fi
# NO PROXY AUTH
n|N)
echo -e ""
read PROXY
read PORT
echo -e "export http_proxy='"http://$PROXY:$PORT"'" >> /home/$USER/proxy.sh
echo -e "export https_proxy='"http://$PROXY:$PORT"'" >> /home/$USER/proxy.sh
echo -e "export ftp_proxy='"http://$PROXY:$PORT"'" >> /home/$USER/proxy.sh
echo -e ""
echo -e ""
function pause(){
read -p "$*"
pause
gost
else
echo -e ""
echo -e ""
echo -e ""
function pause(){
read -p "$*"
pause
gost
fi
echo -e ""
echo -e ""$RED"$(gettext '!!!WARNING!!! Unknown command!!') $NC"
sleep 1
gost
esac
### Remove Proxy ###
18|"remove proxy")
echo -e "$GRE$(gettext 'Do you really want remove proxy? y/n [default yes]')$NC"
read SNE
case $SNE in
$(gettext 'y')|"")
sudo rm -rf $PROFD/proxy.sh
echo -e ""
echo -e "$RED==> $(gettext '!!! Proxy Removed !!!') $NC"
echo -e ""
function pause(){
read -p "$*"
pause
gost
n|N)
gost
echo -e ""
sleep 1
gost
esac
### edit pacman.conf ###
19|"edit pacman.conf")
echo -e ""$GRE"$(gettext 'Which programs do you want use?')$NC"
echo -e ""$GRE"$(gettext 'Write'): [N]nano [V]vim $NC"
read PROGRAM
case $PROGRAM in
N|n|nano)
sudo nano /etc/pacman.conf
gost
V|v|vi|VI|vim|VIM)
if [ -f /usr/bin/vim ]; then
sudo vim /etc/pacman.conf
else
sudo vi /etc/pacman.conf
fi
gost
esac
gost
### edit yaourtrc ###
20|"edit yaourtrc")
read PROGRAM
case $PROGRAM in
N|n|nano)
sudo nano /etc/yaourtrc
gost
V|v|vi|VI|vim|VIM)
sudo vim /etc/yaourtrc
else
sudo vi /etc/yaourtrc
fi
gost
esac
gost
### Log Pacman file ###
l|L|log|"log pacman")
echo -e ""$GRE"$(gettext 'Write'): [M]more [C]cat [L]less]$NC"
read PROGRAM
case $PROGRAM in
l|L|less)
clear
sudo less /var/log/pacman.log
echo -e ""
function pause(){
read -p "$*"
pause
gost
m|M|more)
sudo more /var/log/pacman.log
echo -e ""
function pause(){
read -p "$*"
pause
gost
c|C|cat)
sudo cat /var/log/pacman.log
echo -e ""
function pause(){
read -p "$*"
pause
gost
esac
gost
### Help ###
H|h)
clear
echo -e ""
echo -e "$GREL !!!$(gettext 'GUIDE USE SCRIPT')!!! $NC"
echo -e ""
echo -e "$YELLOW==>$GRE [1]$NC "$(gettext 'To synchronize DB')""
echo -e "$YELLOW==>$GRE [2]$NC "$(gettext 'To update the system')""
echo -e "$YELLOW==>$GRE [3]$NC "$(gettext 'To update the system in force mode')""
echo -e "$YELLOW==>$GRE [4]$NC "$(gettext 'To install a packages')""
echo -e "$YELLOW==>$GRE [5]$NC "$(gettext 'To remove a packages')""
echo -e "$YELLOW==>$GRE [6]$NC "$(gettext 'To update a packages')""
echo -e "$YELLOW==>$GRE [7]$NC "$(gettext 'To remove unused dependencies')""
echo -e "$YELLOW==>$GRE [8]$NC "$(gettext 'To search a packages')""
echo -e "$YELLOW==>$GRE [9]$NC "$(gettext 'To search and install a packages')""
echo -e "$YELLOW==>$GRE [10]$NC "$(gettext 'To view a file belonging')""
echo -e "$YELLOW==>$GRE [11]$NC "$(gettext 'To query local database e info packages')""
echo -e "$YELLOW==>$GRE [12]$NC "$(gettext 'To clean a cache')""
echo -e "$YELLOW==>$GRE [13]$NC "$(gettext 'To Manage .pac* files')""
echo -e "$YELLOW==>$GRE [14]$NC "$(gettext 'To run pacman-db-upgrade')""
echo -e ""
echo -e ""$GRE"==> $(gettext 'Press ENTER to continue')$NC"
function pause(){
read -p "$*"
pause
clear
echo -e ""
echo -e "$YELLOW==>$GRE [15]$NC "$(gettext 'To optimize pacman')""
echo -e "$YELLOW==>$GRE [16]$NC "$(gettext 'To see the statistic of yaourt')""
echo -e "$YELLOW==>$GRE [17]$NC "$(gettext 'To set a proxy')""
echo -e "$YELLOW==>$GRE [18]$NC "$(gettext 'To remove a proxy')""
echo -e "$YELLOW==>$GRE [19]$NC "$(gettext 'To modify') /etc/pacman.conf""
echo -e "$YELLOW==>$GRE [20]$NC "$(gettext 'To modify') /etc/yaourtrc""
echo -e "$YELLOW==>$GRE [L]$NC "$(gettext 'To view a log file')": /var/log/pacman.log"
echo -e "$YELLOW==>$GRE [H]$NC "$(gettext 'To see this menu')""
echo -e "$YELLOW==>$GRE [Q]$NC "$(gettext 'To exit the script')""
echo -e ""
function pause(){
read -p "$*"
pause
gost
### Quit ###
Q|q|quit|exit)
echo -e ""$GRE"$(gettext 'Do you really want exit? y/n [default yes]')$NC"
read SNE
case $SNE in
$(gettext 'y')|"")
clear
exit
n|N)
gost
echo -e ""
sleep 1
gost
esac
### error ###
echo -e ""
sleep 1
gost
esac
gost
### end script ###
