Author Topic: Awesome WM & Variety  (Read 1522 times)
Offline moookino
  • Neuling
  • Skill: Intermediate
« on: 24. February 2015, 16:49:21 »
Hi, im using awesome wm with xfce-power-manager and i want to use variety to set wallpaper, as i used in xfce, can anyone help me or have had this thing solved/implemented? Thanks!
Offline flippy
  • Vollwertiges Mitglied
  • AKA "day|flip" manjaro irc
  • Branch: Testing
  • Desktop: xmonad & bspwm
  • GPU Card: nVidia GeForce GTX 550 Ti
  • GPU driver: Nvida
  • Kernel: Got 64?
Re: Awesome WM & Variety
« Reply #1 on: 25. February 2015, 15:45:13 »
I'm going start with. I know nothing about variety. And there more then one way to set wallpaper with manjaro.  I go with the two most common way. One using a gui called nitrogen. Very simple used and restore last session image. A good option for any window manager. Two. Feh. cli option that not to hard to used. "feh --bg-scale /the/file/to/imagename" But need to add the same command to autostart. And to restore last session image with nitrogen by using autostart: nitrogen --restore &.
http://awesome.naquadah.org/wiki/Autostart#Simple_way
Help with autostart if your using a DM like lightdm.
Offline Zileene
  • Held Mitglied
  • Branch: Stable
  • Desktop: awesomeWM,Gnome
  • GPU Card: various
  • GPU driver: the one that works
  • Kernel: 4.1
« Reply #2 on: 26. February 2015, 07:25:46 »
Culinax did the autostart thing quite well in the rc.lua on his respin.
Go check it out in a live session (then grab the file. :P )
(and if you go back a few pages in that stickie thread, you'll find the wallpaper switcher scriplet that I lifted from the arch forums and tidied up a bit 8) )
Have Fun! ^-^
Z.
While I may not always have the correct solution, my input could lead you in the right direction...
If you don't know what a command does, then type 'man <command>' or '<command> --help' to find out.
