Hello i have installed manajro-tools , i have decommeted the line only for user and password (for try) in .conf file in .config folder.
1) manjaro-tools use my pacman.conf in /etc folder ?
2) the iso profile is in /usr/share/etcetera .... you have to edit the files in this folder with root permissions?
Thank you in advance.
1) no, manjaro-tools use pacman.conf in /usr/share/manjaro-tools.
pacman-default.conf for i686, and pacman-multilib.conf for x86_64
If you need a custom pacman.conf for your iso, you simply use same names and put them in your profile
2) best for the moment is to clone the profiles git repo
