Author Topic: Manjaro cinnamon error at start manjaroISO  (Read 1139 times)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« on: 16. January 2015, 22:05:47 »
Hi guys , i have created a local repo folder and then i used
repo-add -n local-repo.db.tar.gz *.pkg.tar.xz and this is ok.
pacman -Syy works fine the repo is recognized.
The problem :
when start manjaro iso
Code: [Select]
==> (Unactivated Options) Validate deposits to: stable
==> Change kernel version to 314
==> buildiso processing ...
PATH =  /home/ste74/work/manjaroiso/configs/cinnamon
    _     _              _                  _
   | |   | |            (_)                (_)
   | | _ | | ____ ____   _  ____  ____ ___  _  ___  ___
   | || || |/ _  |  _ \ | |/ _  |/ ___) _ \| |/___)/ _ \
   | || || ( ( | | | | || ( ( | | |  | |_| | |___ | |_| |
   |_||_||_|\_||_|_| |_|| |\_||_|_|   \___/|_(___/ \___/
                      (__/      v0.8.11-2.1
 > Base installation (root-image)
 mkiso : Configuration Settings
        working directory:   work-x86_64
               image name:   none
====> Creating working directory: work-x86_64
====> Installing packages to 'work-x86_64/root-image/'
==> Creating install root at work-x86_64/root-image
==> Installing packages to work-x86_64/root-image
 core                       134.0 KiB   161K/s 00:01 [###########################] 100%
 extra                     1922.3 KiB   208K/s 00:09 [###########################] 100%
 community                    2.7 MiB   178K/s 00:15 [###########################] 100%
 multilib                   139.1 KiB   152K/s 00:01 [###########################] 100%
warning: skipping target: ecryptfs-utils
error: failed to prepare transaction (could not find database)
==> ERROR: Failed to install packages to new root
==> The script buildiso encountered an error
==> No ISO image has been created
==> End of process
[/code
this is my pacman.conf in cinnamon folder
[code]#
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
#CacheDir    = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
HoldPkg     = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst   = manjaro-system pacman
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#TotalDownload
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
[local]
SigLevel = Optional
Server = file:///var/local-repo
Thanks in advance  ;)
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
Re: Manjaro cinnamon error at start manjaroISO
« Reply #1 on: 16. January 2015, 23:15:47 »
Oh my God  :(
I have wrong the label in pacman.conf
my folder for repo iso local-repo no local
I have correct and its work
 8)
Canale IRC italiano
#manjaro-it
